Mechanical fan clutch or electric on 2016?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by cmf21, Jan 17, 2015.
  1. Jan 17, 2015 at 1:01 PM
    cmf21
    cmf21 [OP] Well-Known Member
    Arizona
    04 4x4 dbl cab trd
    Can't find any good of pictures of the engine bay. Does the 2016 still have a mechanical fan clutch or is it now electric?
  2. Jan 18, 2015 at 2:30 AM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    Mechanical
  3. Jan 18, 2015 at 7:53 AM
    Lord Helmet
    Lord Helmet Prepare To Attack
    Nick
    '24 X3 M40i
    X2
  4. Jan 18, 2015 at 9:42 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    I'd much prefer mechanical for a truck application anyways. Hell I don't think you will find a current truck with an electric fan anyways.
  5. Jan 18, 2015 at 11:21 AM
    Alloutdrs1
    Alloutdrs1 Well-Known Member
    Andrew
    Virginia Beach, VA
    12' Mag gray Doublecab 4x4
    Distinct Offroad light bar, Rigid E-series and amber duallys, Leer 100xq, Oem roof rack, Oem bed mat, Bullculla trailer plug relocate bracket, Rear diff vent mod, front mud flap chop, Color matched Grille w/Andres devil horns, Wet okoles and weathertechs
    New Colorado comes with an efan I think, not 100% sure though.
  6. Jan 18, 2015 at 11:25 AM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    I'd bet an Electrical fan. More CFM at idle, and the computer can adjust speed as cooling needs increase/decrease.
  7. Jan 18, 2015 at 11:27 AM
    Alloutdrs1
    Andrew
    Virginia Beach, VA
    I just googled it, Colorado has electric fan. While I prefer a mechanical fan in a truck the energetic fans have some positives to them as well.
  8. Jan 18, 2015 at 11:32 AM
    Lord Helmet
    Nick
    '24 X3 M40i
    You can see the fan clutch on the limited Tacoma:
    It's mechanical :thumbsup:
  9. Jan 18, 2015 at 12:34 PM
    cmf21
    Arizona
    04 4x4 dbl cab trd
    Thanks!
  10. Jan 18, 2015 at 5:59 PM
    DVexile
    DVexile Exiled to the East
    Ken
    2015 DCSB V6 TRD OR 4X4
    Huh, I would of expected electric on the perhaps flawed basis of slightly more efficient for MPG. Of course probably it amounts to like 0.02 MPG. Electrics are nice for water crossing as you can disable them for the crossing and not shred your fan if the nose dips unexpectedly while the mechanical clutch is engaged.
    Good find on the photo - definitely looks mechanical!
  11. Jan 18, 2015 at 7:32 PM
    nd4spdbh
    SoCal
    till the bearings in the fan fail due to water intrusion. Buddy did an efan setup on his 3rd gen 4 runner, hes back at a mechanical fan now due to it being tons more reliable
  12. Jan 18, 2015 at 7:41 PM
    unclemat
    unclemat Well-Known Member
    2012 TX Baja
    Really? Never had an electric fan fail in any of my cars. I like the simplicity of removing them and the extra space between the engine and the radiator.
  13. Jan 21, 2015 at 4:25 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    You haven't owned them long enough. They will fail.
  14. Jan 21, 2015 at 5:15 PM
    DVexile
    Ken
    Yeah, there really isn't a 100% good solution. But in general you gamble with with a mechanical clutch and water - and if the blade shreds it can take your radiator with it. Personally I wouldn't go out of the way to replace a mechanical with an electrical. But if came with electrical from the factory I'd add a kill switch for crossings.
