Mechanical possitraction for my 2017 TRD PRO.
Discussion in '3rd Gen. Tacomas (2016-2023)' started by camoarcher, May 10, 2019.
  1. May 11, 2019 at 7:02 AM
    camoarcher
    camoarcher [OP] Member
    2017 TRD Pro
    Leveling lift, M/T Deagan 38 tires 33”, ProComp rims.
    No thanks.
    GreyBaldTaco likes this.
  2. May 11, 2019 at 7:40 AM
    ToolPac
    ToolPac Well-Known Member
    Show Low, AZ
    2018 TRD Pro, 1998 TRD
    Wow. That's all the more reason not to screw it up then. OP, leave your diff alone. It's better how it is.
    I have a manual in my 18 cavalry blue pro too. Is there a list posted for every year? I bet taking color into account makes them even more rare.
    camoarcher[OP] likes this.
  3. May 11, 2019 at 7:54 AM
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    As things stand right now, you would have to lose the locker to get a Torsen or clutch pack type LSD in there. Last I looked, there was not much out there for the Taco 8.75". There is a smattering of traction devices for the 8.75/220mm version of this diff for the old TT MKIV Supra, but they will need to spec'd with different side gears for the smaller 32 spline Taco axle shafts, and possibly a different offset for the carrier. Not terribly difficult changes for a manufacturer of a existing/well developed application.
  4. May 11, 2019 at 7:58 AM
    Lt. Dangle
    Lt. Dangle RIP @stun gun 2016-2020
    Ohio
    2025 Tundra Platinum OR
    Not here it isn't. Toyota may only make 10% of pros as manuals*, but 90% of the owners are here it seems.
    * No idea on actual figures, just an example.
    It's just like when someone comes here saying they ordered a special trim level. No they didn't.
    stun gun and oconnor like this.
  5. May 11, 2019 at 8:41 AM
    ToolPac
    Show Low, AZ
    It would take an enthusiast to buy a truck like that with a manual. So it stands to reason that we'd all be here.
    Lt. Dangle[QUOTED] likes this.
  6. May 11, 2019 at 8:46 AM
    Lord Humongous
    Lord Humongous The Ayatolah Of RockNRolla
    AZ
    Inferno 3rd gen trd offroad 4x4
    https://www.tacomaworld.com/threads/lord-humongous-gigahorse-build.436524/
    Weld the spider gears
  7. May 11, 2019 at 10:00 AM
    Lt. Dangle
    Ohio
    No doubt.
  8. May 11, 2019 at 1:07 PM
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    i want the same as the OP. reason the locker is only for off road which i do not do. a LSD is full 2WD on the highway.
    just like the 456 posi traction i put in my 59 348 Chevy when i was a 20, smoked both rear tires.
  9. May 11, 2019 at 1:21 PM
    BillyToy
    BillyToy Well-Known Member
    PNW
    2017 Tacoma TRD Pro 6MT
    You know, I may be mistaken. It may have been 240 for that year with 80 in each color. I can't remember
  10. May 11, 2019 at 1:39 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    2020 Jeep Wrangler JLUD
    Nah
  11. May 11, 2019 at 1:42 PM
    Alesimo
    Alesimo Jeeper
    Alec
    Houston, Texas
    I did drive out of state for it though
  12. May 11, 2019 at 1:49 PM
    elduder
    elduder Well-Known Member
    Van WA
    2019 Voodoo Blue Tundra TRD Pro
    This is the extent of it.
    I imagine you would have to be getting pretty technical for 4lo and ATRAC not to work for you with the MT. 4Lo gearing will keep you from rolling back or roasting the clutch on anything that doesn't also come with the risk of body damage. If you havent tried 4Lo, get out an do it, should get rid of most concerns.
  13. May 11, 2019 at 3:20 PM
    kahanabob
    Maui
    16 TRD 2WD 4DR
    thanks for the in depth info, have been trying to find out the in's and out's you explained it perfect.
  14. May 11, 2019 at 6:35 PM
    Aldo98229
    Aldo98229 Well-Known Member
    Aldo
    Bellingham, Washington
    2019 Tacoma TRD Off-Road
    I’m a big fan of TrueTrac LSDs. They are virtually indestructible; they are great on the trail for anything but the most extreme off-roading, and if you have to cover great distances in winter conditions an LSD actually works better than a locker.
    Having said that, I wouldn’t swap the locker out of a Pro for a TrueTrac. That’d be a waste.
