Mechanical Question
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MuleyHNTR, Oct 17, 2022.
  1. Oct 17, 2022 at 1:21 PM
    MuleyHNTR
    MuleyHNTR [OP] Member
    I have a 2009 Tacoma and lately it has had a problem where sometimes when it gets high in rpms when I stomp on it the engine will cut out for just a second sometimes a few times in a row til I let off, what would cause this, MAF? Throttle body?
  2. Oct 17, 2022 at 2:10 PM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    fuel pump / fuel pump relay.
    NORCAL50, TnShooter and Dm93 like this.
  3. Oct 18, 2022 at 10:43 AM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    Rev Limiter.
    Brake Light Switch.
    winkel and b_r_o like this.
  4. Oct 18, 2022 at 10:55 AM
    Chuy
    Chuy Well-Known Member
    Lakeside, CA
    07 V6 DCLB 4X4 Sport
    Silver Taco
    Clogged air filter. Also worn out or oil coated spark plugs. I want to say a bad coil but I think that would generate CEL.
  5. Oct 18, 2022 at 12:41 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    How high rpms are we talking? :popcorn:
    winkel and Jimmyh like this.
  6. Oct 19, 2022 at 4:24 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    You know like in High Man....
    :rasta:
    winkel and TnShooter like this.
  7. Oct 19, 2022 at 5:41 PM
    NORCAL50
    NORCAL50 Active Member
    2014 Toyota Tacoma SR5 V6 4x4
    Could also be a clogged fuel pump filter. No CEL?
  8. Oct 19, 2022 at 5:45 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    Random guy: How many rpm’s that thing turning?
    Me: All of them :D
    Yes, it was indeed a real conversation.
    The answer was “about 13k rpm”. But track secrets are track secrets.
    Never give out information to those you don’t know.
    Jimmyh[QUOTED] and Leomania like this.
  9. Apr 12, 2024 at 2:17 PM
    MuleyHNTR
    Hey guys, thought I’d revive this and see if you had anymore info, So eventually it got worse and worse to the point where it would very often cut out when accelerating, and soon after, wouldn’t start, obvious bad fuel pump, replaced the fuel pump, fired right up but was cutting out again, heard a weird noise at the fuel pump, determined there was a vacuum leak and sealed it up, then it was running great, I thought. Now it cuts out only every once in a while when accelerating at random rpm’s, only happens like once a drive but still bugs me, after this extra info, what should I try next? Do you think it’s a vacuum leak? Bad spark plugs? Bad coil? I ran some injector cleaner through it and I’m gonna replace the MAF just cause it’s cheap but what do you guys think?
  10. Apr 13, 2024 at 4:02 AM
    AJwisco
    AJwisco Well-Known Member
    2005 Tacoma sport
    You checked the fuel pump relay?.. I don’t know how it happened , but I went to start my truck one morning on the way out hunting and it would fire, just cranked. Popped the hood , opened the fuse box and the relay was like half sticking up‍♂️, pushed it down and away I went
    Marc70 likes this.
  11. Apr 13, 2024 at 4:03 AM
    AJwisco
    2005 Tacoma sport
    Edit—*wouldn't fire
