Medium or Heavy OME Leaf pack?!?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by PirateMedic3, Apr 22, 2024.
  1. Apr 22, 2024 at 7:44 PM
    PirateMedic3
    PirateMedic3 [OP] Well-Known Member
    Colorado
    BAMF Hybrid Front bumper OutGear Solutions Rear Heretic Lighting RCI Skids
    Forgive me, I’ve read so many threads in this but no one has the set up I’m running. Currently have the OME HD 660. These were great with my older set up. (Ikamper, rack, decked, tire, etc.) I now have a GFC with minimal camp gear. Doesn’t anyone run the medium load? Or recommend a different leaf pack? TYIA
  2. Apr 22, 2024 at 9:32 PM
    TacoTuesday1
    SD CA
    can’t say I have OME
    I heard they have Dakar that everyone says to avoid so I got Icon
    icon says lift in op3 drops to 1.75” loaded
    which I am sometimes
    Figured keep it there. If my front is 2” max.
    So far it works.
    only issue I’ve heard was from the previous owner basically went from a camper to putting near a whole entire house on the back of his truck and said the RXT no longer cut it for that much more weight so he switched to something from Deaver specifically configured for that. Which costs more.
  3. Apr 22, 2024 at 10:03 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 84K miles
    FOX 2.5, Deavers, ARB, OTT, 4xInnovations
    Deaver U402 stage III's here, rated 700-1000 lbs per pair.
    I currently have about +400 lbs of permanently-affixed gear on back (utility cap, tools, spare tire, lumber rack). There's no question that with only 400 lbs the rear is bouncy as hell & the shocks don't get to do their damping job because the leaf springs barely flex.
    I throw another +350-400 lbs of steel ballast in back to get a comfortable ride.
    Point being, be sure whatever springs you choose are rated for your approximate normal bed weight. Try to avoid being oversprung or undersprung.
  4. Apr 23, 2024 at 7:40 PM
    PirateMedic3
    Colorado
    Ive heard good things about ICON but want to make sure they achieve enough lift. The 1.25 doesnt seem like a lot, especially for the random times I haul more than usual weight.
  5. Apr 23, 2024 at 7:42 PM
    PirateMedic3
    Colorado
    Yeah I used to be super heavy, now im light with the occasional heavy haul for house things. Considering just a step down in leaf pack range to see where that gets me. Seems every GFC guy out there is pushing super heavy loads so they all go with Deaver 3.
  6. Apr 24, 2024 at 4:39 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    I've got OME Mediums and Firestone airbags with the A/T Habitat. The performance of the OME springs has always been mixed and honestly, I wouldn't think to run them without the airbags while moderately loaded (I'm a backpacker/moto tourer so tend to pack lighter for a weekend of camping than a lot of other setups I've seen). Airbags are nice for their load adjustability but they do limit up-travel but either way, after 7 years of use, feel there are likely better choices out there for the money than OME Dakar's.
    GilbertOz likes this.
  7. Apr 25, 2024 at 11:34 AM
    WillyTtaco
    WillyTtaco Well-Known Member
    Bill
    So Cal
    2014 DCSB TRD OFFROAD 4X4
    265/75/16 AT2 BILSTEIN,SNUGTOP MBRP,SPC UCA
    I had ome medium pack for years before changing to a simple add a leaf. Ome medium was stiff af and uncomfortable. Unless you have 200+ pounds back there all the time I would go with something softer.
  8. Apr 25, 2024 at 12:37 PM
    Naveronski
    Naveronski Well-Known Member
    Fort Worth
    2014 MGM DCSB TRD:OR
    People have a very wild imagination trying to guess what things weigh.
    Stop it.
    Load up your truck, then go weigh it. Drive to a CAT scale and get the actual weights per axle of your truck, then you can accurately determine which springs you need.
