Mega timing advance = mega power gains?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by howdat333, Dec 22, 2022.
  1. Dec 22, 2022 at 1:11 PM
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
    It is a real number. However , I only see it under a light load 10-15% 1300-1600 rpms
  2. Dec 22, 2022 at 1:11 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    Sure. The onboard stuff might be far from the precision target, but being completely missing is an odd one, esp for oil temp. Like, why bother reporting estimated oil temps over OBD if the sensor isn't even there.
  3. Dec 22, 2022 at 1:16 PM
    woodsy
    woodsy Well-Known Member
    Ohio
    2021 Tacoma TRD Sport Premium
    If you go above 52 degrees you will need a CMC.
    vivid02, Squirt, atc250r and 8 others like this.
  4. Dec 22, 2022 at 1:32 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    Huh? I'm just reacting to another crazy thread started by the same OP and wondering if he just trolling us.
    In any case VVTI is Variable Valve Timing and Intelligence which is a fairly new tech. Variable ignition timing has been around a very very long time. I think I personally first encountered it on my 1974 Datsun vacuum advance system, but I think it is far older than that.
    vivid02 and Chew like this.
  5. Dec 22, 2022 at 1:34 PM
    RX1cobra
    RX1cobra Well-Known Member
    19 OR
    Model Ts had adjustable (manually) ignition timing. Just about every engine ever made has it in some form.
    TexasG and gudujarlson[QUOTED] like this.
  6. Dec 22, 2022 at 1:35 PM
    vicali
    vicali Touch my camera through the fence
    mike
    Kam,BC
    2017 TRD Sport 1D6
    Now you can leave your wipers up in the air 24/7 like all the other winter wannabes..
  7. Dec 22, 2022 at 1:39 PM
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    No sirrie
    wilcam47 likes this.
  8. Dec 22, 2022 at 1:47 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Don't need coolant temp gauge either. My Subaru has just two idiot lights - blue for cold, red for hot, and no light at normal temp.
  9. Dec 22, 2022 at 1:57 PM
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    The "Ignore" feature on the forum can be a very useful tool. :anonymous:
  10. Dec 27, 2022 at 7:44 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    OP in another few threads:
    vivid02, Dawelda, TexasG and 5 others like this.
  11. Dec 27, 2022 at 8:00 AM
    Firn
    Firn Well-Known Member
    White OR
    Not sure what the normal range is for the Tacoma but high numbers are not unusual for light load or deceleration conditions.
    I know you say you see higher numbers with 91 but the test will be what the numbers are under load. In my testing on a stock tune my timing under load did not change regardless of 87,91, or 93 (top tier included).
    You really need to do data logging and compare on a computer or graphical display, looking at a value at one time isn't terribly informative.
  12. Dec 27, 2022 at 10:58 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Im baffled by his geniuso_O
  13. Dec 27, 2022 at 11:18 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    can you tell me... what would the correct ignition timing be on a 1955 Bel Air Chevrolet, with a 327 cubic-inch engine and a four-barrel carburetor?
  14. Dec 27, 2022 at 11:23 AM
    wilcam47
    Will
    Bourbon state
    8-12°
  15. Dec 27, 2022 at 11:27 AM
    #35
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Chevy didn't make a 327 in '55, the 327 didn't come out till '62. And it wasn't offered in the Bel Air with a four-barrel carb till '64. However, in 1964, the correct ignition timing would be four degrees before top-dead-center.
    Ms. Mona Lisa Vito has spoken.
    blu92in99, ktbell444, Rusty66 and 2 others like this.
  16. Dec 27, 2022 at 11:29 AM
    #36
    Firn
    White OR
    You never specified all original...
  17. Dec 27, 2022 at 11:29 AM
    #37
    wilcam47
    Will
    Bourbon state
    :thumbsup:now we know i was guessing:D
    hiPSI and FL_TRD Sport[QUOTED] like this.
  18. Dec 27, 2022 at 11:32 AM
    #38
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Ok so maybe I've watched My Cousin Vinny one too many times......:anonymous:
    ktbell444 and wilcam47 like this.
  19. Dec 27, 2022 at 11:35 AM
    #39
    harleypower69
    harleypower69 Petrol head for life
    Nature Coast of FL
    2022 SR5
    The Wing Tip Speed Framulator Adjustment Sleeve has to be carefully tightened when advancing timing otherwise “the thing” happens.
  20. Dec 27, 2022 at 11:38 AM
    #40
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    harleypower69[QUOTED] likes this.
