Melted wire harnesses on v6 coils
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Geo2199, Nov 24, 2015.
  1. Dec 3, 2015 at 3:54 PM
    #41
    Geo2199
    Geo2199 [OP] Active Member
    Jeovanni
    Atlanta, ga
    Prerunner V6 SR-5 Auto
    Limo Tint, 265/75/16 Bridgestone Duelers, Sylvania Silverstar headlights, Lo-Jack, AVS Vent Visor Windows, Draw-Tite Hitch, and some dents & scratches which add "personality"
    It ran fine when i took it to my mechanic but the next morning the truck threw a cel and went into limp mode. Babied it to the dealership and the new spark plug I put in cylinder #4 was defective from the factory and had a slight crack in it. Since i bought the plugs from them they gave me a new one for free and it runs fine. So no bad injector or bent valves. Just needed a new coil.
    DoorDing likes this.
  2. Dec 3, 2015 at 5:04 PM
    #42
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    A poor connection will cause that they can get very hot and cook the plug. The coils draw enough current to cause an over heat of a poor connection.
  3. Dec 3, 2015 at 5:16 PM
    #43
    12TRDTacoma
    Rob
    Concordia
    Boosted
    I don't know what's going on other than the fact you replaced your spark plug but if I was in your shoes I would do this about my plug:
    De-pin the connectors from your old plug and examine them, if they look fine, perfect. Go to a local junkyard, de-pin the plug from the junked Taco, then go home and install the new plug on the old connectors. If that is not a viable option and your connector pins are shot to hell, I would cut the new plug with a decent amount of length on the old wires then solder it all up.
    Either way, glad to hear nothing hardware wise is wrong.
  4. Dec 3, 2015 at 5:17 PM
    #44
    Sandman614
    Tim
    Garner, NC/Boone, NC
    '06 SR5 Off Road
    I'd just fix it no matter that it was a problem with the sparkplug.
  5. Dec 3, 2015 at 5:19 PM
    #45
    12TRDTacoma
    Rob
    Concordia
    Boosted
    What i'm saying is that there is no need to drop over $1400 on a whole new wiring harness assembly from the dealer just because a connector melted. It happens all the time with other vehicles. Easily repairable.
  6. Dec 3, 2015 at 5:20 PM
    #46
    Sandman614
    Tim
    '06 SR5 Off Road
    Especially if it's a $9 fix
    12TRDTacoma[QUOTED] likes this.
