Melting side rear view mirrors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MARKDESMO, Feb 10, 2013.
  1. Feb 10, 2013 at 2:09 PM
    MARKDESMO
    MARKDESMO [OP] Well-Known Member
    Mark
    Southern California
    2007 Tacoma TRD
    Is there a thread on the side rear view mirrors that the plastic case melts?
  2. Feb 10, 2013 at 2:26 PM
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    I just searched it and came up with nothing.
  3. Feb 10, 2013 at 2:47 PM
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I'm sure it could melt if heated enough. Are yours melting? It would take a great deal of heat in order for that to happen. The sun isn't going to do it if that is what you are thinking. It is more than likely ABS Plastic that has no real " melting point " as what you would see in a regular plastic material.
    Its " glass transition " temperature is approximately 105 °C (221 °F). ABS is amorphous and therefore has no true melting point.
    105 degrees C is 221 degrees F.
  4. Feb 10, 2013 at 4:32 PM
    MARKDESMO
    Mark
    Southern California
    2007 Tacoma TRD
    Yes, both have I guess melted in the sun. I live in Southern California and my son also ha the car in Waco, TX when he was going to college. I have actually seen other Toyota side rear view mirrors while driving down the freeway, here's a pic.
  5. Feb 10, 2013 at 4:36 PM
    Mattnatti
    Mattnatti TEQ HED
    Cincinnati, Ohio
    12' reg cab 4x4 2.7L auto
    Wow! That is F'ed up.
  6. Feb 10, 2013 at 5:17 PM
    theredofshaw
    :eek:
    this worries me with the way our summer here was last year...
  7. Feb 10, 2013 at 6:43 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    The sun did not do that.
    Neither Southern California or Waco Texas get up over 212 Degrees F even in the worst summer sun. That was exposed to something very hot. Notice it didn't melt all over, mainly in one area. It looks like someone used a propane torch on it.
    I have never seen any ABS Plastic melt in that way from the sun.
    Torspd likes this.
  8. Feb 10, 2013 at 6:51 PM
    ItalynStylion
    ItalynStylion Sounds Gooooood
    Steven
    DFW, Tx.
    09 Double Cab TRD Sport 4x4
    I live in Dallas Texas. Although I have a garage I don't park in it. My truck has 75k miles on it and has spent nearly every single day/night outside. My mirrors look just fine. This is honestly the first I've heard of this issue.
  9. Feb 10, 2013 at 6:55 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Heated mirrors gone wrong? maybe motor malfunction.
  10. Feb 10, 2013 at 7:02 PM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    :eek: never seen or heard of that before.
    But my guess is this ^
  11. Feb 10, 2013 at 7:05 PM
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    Do you park your truck in front of any glass buildings or something like that? ... reflective sun damage?
    Torspd likes this.
  12. Feb 10, 2013 at 7:18 PM
    MARKDESMO
    Mark
    Southern California
    2007 Tacoma TRD
    Usual wear and tear, it happened on both sides and each motor works fine. Like I said before. driving down the freeway here in SoCal I spotted another Toyota, not a Tacoma, with a similar mirror and it had the same warping.
  13. Feb 10, 2013 at 7:22 PM
    MARKDESMO
    Mark
    Southern California
    2007 Tacoma TRD
  14. Feb 10, 2013 at 7:23 PM
    ImplicitlyAlberta
    David
    edmonton
    Hmmm check with the dealership. Ive heard of a mirror heater mod. Maybe someone botched it.
  15. Feb 10, 2013 at 7:23 PM
    File IFR
    Central MA
    I agree. Heat damage would just sag the housing and make it kinda glossy. That looks like aa actual burn to me.
  16. Feb 10, 2013 at 7:25 PM
    ImplicitlyAlberta
    David
    edmonton
  17. Feb 10, 2013 at 7:46 PM
    akhermit
    akhermit Well-Known Member
    Anchorage Alaska
    12 DCSB Magnetic Gray Metallic TRD Offroad
    That was obviously near a heat source besides the sun. I lived in El Paso for 2 1/2 years, never had any issues like that. Although, the Mercury Tracer I had at that time, had the Mercury emblem glued in the middle of the grill, and one day it just fell off from the heat.
    Well, did some searching, and yes, there are a lot of cases of melting plastic on vehicles caused by energy efficient glass on buildings. Apparently, when cold, the double paned glass can become concave, concentrating the reflection into a beam of heat, just light a magnifying glass.
    It is not from direct sunlight, but the reflection of the sun.
  18. Feb 10, 2013 at 7:56 PM
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    +1
    That's not from the sun.
    It's from a torch, or magnifying glass, or even a compressor exhaust.
    If it were from the sun, then every black Tacoma in Southern California, Arizona, New Mexico, and Texas would have their badges falling off, and the grille melting in the same manner (same material).
  19. Feb 11, 2013 at 5:15 AM
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
  20. Feb 11, 2013 at 9:54 PM
    Jimmyh
    SC
    2012 Prerunner SR5
    I agree. The ABS Plastic doesn't reach the Glass Transition Stage until it gets to ~ 105 degrees C or 212 Degrees F. There would be other damage to the vehicle if the reflection from a window were causing it. That mirror looks burned like a torch or some other concentrated heat source was applied just to that area of the mirror.
    Gotta throw the old "Bull Shit Flag" on this story.
