Melting side rear view mirrors?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by MARKDESMO, Feb 10, 2013.
  1. Feb 13, 2013 at 9:21 AM
    #41
    MomsTacoma
    MomsTacoma Member
    Western Slope, Colorado
    AC 2.7 SR5 4WD
    I have noticed this same melting effect on a small portion of the front grill on my mother's '07. The grill is made from the same black plastic material as the side view mirrors. Maybe ABS, I don't know...
    It took me a while to figure it out but the only conclusion I could come to is that it is reflective glare off of the energy efficient windows at her house. Window technology nowadays is much more reflective to minimize the greenhouse effect within buildings. Under the right conditions on a hot summers day and at just the right angle the reflection off of these windows can superheat whatever it hits... The fact that the material is black probably doesn't help either as it absorbs even more heat.
  2. Feb 13, 2013 at 9:24 AM
    #42
    Utard
    Utard Well-Known Member
    Mark
    Nyssa, Oregon
    2012 DC LB 4WD TRD SPORT NAVI
    ------------------------------------------------------------ Stabilus.EZDown.Tailgate http://www.ezdown.com/home.php ----------------------------------------------- Tekonsha.Primus.IQ.Trailer.brake http://www.tekonsha.com/content/default.aspx---------------------------------------------------------------- Leer 180 CC http://www.leer.com/Truck-Caps#------------------------------------------------ Firestone Air Rite Air Bags--------------------------------------Kargomaster Rack
    I think Dr Evil is putting Lazer beems on Pigeons.
    But to be serious. Have you taken apart the mirror? If it was reflected sun it would not be concentrated like that. It would be the whole cover.
    If you look at the intensity of the burn it is concentrated on one location. So that means the heat source is concentrated. Like if someone held a magnifying glass or a torch in that middle spot. Or the motor/wiring is going bad in the mirror casing.
    So with all that being said take it apart and i would just about guarantee the mirror motor is right at that center bubbled/burned spot.
    And just remember there are a lot of bullshiiters on this site so just take them with a grain of salt and beat back with a big stick. And sometime BS threads are started just for fun. So you need thick skin around here.
    And i see some people talking about windows? If its a flat window then it just reflects the same light that would be shining as if in direct sun light. If its a parabolic window pointed at your truck then you have a problem.
  3. Feb 13, 2013 at 9:25 AM
    #43
    DEEVON911
    DEEVON911 Semi-Pro
    Dave
    Bethel Park, PA. Burb of da Burgh.
    2010 MGM Mostly Stock Off-Road 4x4
    TRD Cat-back Exhaust. Semi-Debadged. Trimmed down stock Antenna. Weathertech vent visors. TRD FJ Cruiser Center Cap Wheel Mod. 265/75/16 Firestone Destination A/T,s . Inverter tapped into for outlet in cab. Tacomaworld sticker which adds 5 hp.
    Kinda coming back a little rude. I'm out. Good luck with the mirrors.
  4. Feb 13, 2013 at 9:31 AM
    #44
    127.0.0.1
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    well, with plastics, odds are in favor of OEM vs Aftermarket.
    engineered resins are more expensive than ordinary resins
    and there are 1000 molding outfits in China who would love to
    make you a 10,000-50,000 part run for very low cost
    forgot about the little mirror motors...they should blow a fuse
    before they draw enough current to melt the housing...I mean
    the housing is air gapped from the motor...would take a serious
    motor problem (fuse blowing level) to melt that
  5. Feb 13, 2013 at 9:32 AM
    #45
    2004TacomaSR5
    2004TacomaSR5 Nemesis Prime
    Jon
    Montana
    2004 Tacoma DCSB & 1980 Toyota Pickup 4WD
    Tacoma is stock and staying that way, Pickup is TBA as of now.
    Wow, how hot does it get there? That's insane, idk how it could do that unless heat is building up inside the mirror casing itself.
  6. Feb 13, 2013 at 9:49 AM
    #46
    medusa1066
    medusa1066 Well-Known Member
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
  7. Feb 13, 2013 at 10:04 AM
    #47
    MARKDESMO
    MARKDESMO [OP] Well-Known Member
    Mark
    Southern California
    2007 Tacoma TRD
    I am going to go with the story my son told me while he was at college, "Dad it must have been the library windows I go there everyday"......
  8. Feb 13, 2013 at 10:18 AM
    #48
    medusa1066
    Jonathan
    Morgantown, WV
    2007 4x4 TRD Sport
    :rofl: more like:cheers:
  9. Feb 13, 2013 at 12:27 PM
    #49
    dtopgun515
    dtopgun515 Well-Known Member
    Darrell
    Hey Yall Georgia
    13 TRD Sport
    5100's up front set to 1.75, SCS Stealth 6 wheels, Nitto Terra Grappler AT's
    :drunk: :rockband: :drunk::puke:
  10. Feb 13, 2013 at 2:40 PM
    #50
    Jimmyh
    Jimmyh Well-Known Member
    SC
    2012 Prerunner SR5
    I didn't call anyone a name. ?? I only called BS on the fact that it is a mfg defect. I'm not sayiing that you don't have an issue with your mirror.
    You do seem to be rather sensitive. ( Note: This is not a "putdown", just an observation. Sorry if it hurt your feelings. Seriously.
    Toyota uses the same ABS Thermoplastic that all mfgs use. No one on this ( or any other forum) has a crystal ball to tell you what happened to your mirror housings. We do not have enough information.
    What we do know is:
    1. Your mirror housing(s) got burned. Seems concentrated in one area.
    2. ABS Plastic reaches glass transition at 212 F.
    3. The sun doesn't get this hot on its own ( unless through a magnifying glass etc...)
    4. If this was a common phenomenon it would be all over this forum ( and all other Toyota forums) in spades.
  11. Feb 13, 2013 at 2:44 PM
    #51
    Jimmyh
    SC
    2012 Prerunner SR5
    Did you read the article?
    That doesn't equal defective ABS Plastic. Sun + Mirror + Concentrated Energy = Oven.
  12. Feb 13, 2013 at 3:42 PM
    #52
    File IFR
    File IFR "... Intercepting The Localizer"
    Central MA
    2012 MGM 4X4 DC-LB TRD Sport
    After you posted (#13), do you realize that you have solved the mystery... given the fact that the woman's mirrors in the video appear to have the same damage yours has?
    It would be illogical to assume Toyota uses a 'lesser grade' plastic for their exterior body parts if you search for the same problem on here.
    When you park your truck, turn it around for a month...... until the sun will be at a different angle... then park as you wish later in the season.
  13. Feb 13, 2013 at 5:59 PM
    #53
    MARKDESMO
    Mark
    Southern California
    2007 Tacoma TRD
    I actually like the look of my melted superior grade plastic rear side view mirror that aliens came down and replaced the stock mirror with an after market one, torched it, poured acid on it and left me a note to park it at a different angle or they would start calling me names.
  14. Feb 13, 2013 at 7:03 PM
    #54
    theredofshaw
    theredofshaw Well-Known Member
    Somewhere on the East coast
    not a taco (guess that means I can be a MOD now)
    (totaled) 2011 Tacoma DC
    :rofl:
  15. Feb 14, 2013 at 7:41 AM
    #55
    Utard
    Mark
    Nyssa, Oregon
    Looks like the perfect job for an infrared temperature gun to check the temps of the spots.
  16. Feb 15, 2013 at 3:30 PM
    #56
    Rich91710
    Rich91710 Well-Known Member
    Rich
    Los Angeles
    08 Base
    Seems like it would be a fire risk.
  17. Mar 19, 2013 at 11:09 PM
    #57
    xguntherc
    xguntherc Taco Time
    Cory
    East Dallas
    11 TRD Off Road - Black
    Icon Stage 5, Nexen Roadian MTX, Fuel KB43 Block wheels, Baja Design XL 80s, Baja Squad Pro WC fogs, TacoVinyl grill, "dudebro" lights, Prinsu rack, trail rash pinstripes, BAMF hybrid bumper, sliders, and LCA skids, and a few other things I can't think of.
    Time to resurrect this thread.
    My Tacoma (2011) I've had for 4 months is starting to have this same issue. I'm in Vegas and it gets over 110 degree's, yet the past two years nothing has happened.
    Since owning it myself, and parking next to my apartment with big window reflections, my grill and side mirror is starting to melt. I'll get pictures tomorrow, but it looks absolutely awful. I'm not sure what is causing this but I won't be parking by the windows any more. I'd hate to see what the 110 degree days with window glare does to the plastic. Maybe I should just as a test.
    lol
  18. Mar 19, 2013 at 11:27 PM
    #58
    jw1983
    jw1983 Well-Known Member
    Alberta
    13' Tacoma Access 4x4 OR
    Is this happening to members who only have black colored mirrors? Heated mirrors(Tacoma Limited)? Only people who live in really hot climates like Arizona?
  19. Mar 19, 2013 at 11:28 PM
    #59
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
  20. Mar 19, 2013 at 11:33 PM
    #60
    majorhavok
    majorhavok Rabid Conservative
    Mike in Cali..
    Peoples Republic of Caulifournia
    '13 TRD Sport DoubleCab 4x4
    Ultragauge, ImMrYo mirror, Tailgate lock, Snugtop Rebel Shell.
    Did you read previous helpful posts? It's caused by a crazed lunatic with a blowtorch and acid, not window reflections. It's YOUR fault for questioning the injection molded thermoplastic quality and parking in whatever orientation you have been. Whatever you are doing, stop.. if you back in your spot, stop it! if you pull straight in, you are a moron! lol
    :stirthepot:
