memario1214's JAFR Build
Discussion in '2nd Gen. Builds (2005-2015)' started by memario1214, Oct 6, 2011.
  1. Apr 30, 2013 at 8:49 AM
    #801
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Basically, if the s/c is pushing more air than the Oem components can handle, it will cause the effective reading to be higher than it would be if it could flow more freely. Due to a back pressure.
    Increasing the efficiency of the header design. Just because it it at a lower psi doesn't mean that it is flowing less. It could very well mean that it is flowing more. Relative to the components at play.
    Flow=CFM=Power. Not PSI.
  2. Apr 30, 2013 at 8:52 AM
    #802
    Blackdawg
    Blackdawg Dr. Frankenstein
    Monte
    Wyoming/St. Louis
    The Trifecta of Taco's
    I get that too. Always had a hard time explaining to noobs on the supra forums that a bigger turbo at 8 psi is flowing more then the 12psi out of their stock turbo..lol
    Okay..i guess that makes more sense then..
    I need to just keep thinking turbo shit..lol SC stuff is a tad different..but not that different.
  3. Apr 30, 2013 at 9:02 AM
    #803
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Yup, you're right. If you think in turbo logic, it helps. :thumbsup:
    There is a difference there too though. The wastegate will always try to maintain the same atmospheric pressure of the manifold based off of the spring size. Increase efficiency of certain components and is still might read the same as before. But just make more power. But this is all relative to a specific scenario. To keep from really going off topic.
  4. Apr 30, 2013 at 9:10 AM
    #804
    Blackdawg
    Monte
    Wyoming/St. Louis
    gotcha.
    Yes..this is why if i ever FAI one of my truck..ill be doing turbo..just know them better :p haha
    and so i can beat my dads SC :D
  5. Apr 30, 2013 at 9:11 AM
    #805
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    The turbo system is not as dictated by the elevation changes correct because the turbo can build to a certain pressure and then release?
  6. Apr 30, 2013 at 9:12 AM
    #806
    Blackdawg
    Monte
    Wyoming/St. Louis
    No its still effected by elevation.
  7. Apr 30, 2013 at 9:30 AM
    #807
    memario1214
    Colton
    Missoula, MT
    A supercharger runs a fixed rpm and can only make a fixed amount of boost based on its inlet pressure. However, I wonder if a turbo can spool higher in thinner air due to the decreased density and theoretically achieve the same mass flow rates as sea level? Has anyone seen any data that turbo engines lose less power at altitude than superchargers?
  8. Apr 30, 2013 at 9:33 AM
    #808
    MadToy
    MadToy Well-Known Member
    Nick
    Huntersville, NC
    07 Midnight Blue TRD
    OME 886, Dakar leafs, LR UCA's, 16x8.5 Level 8 ZX, 315 MTR Kevlar, All-Pro sliders, BudBuilt skids, Undercoverhwms winch mount, Warn M8000 with synthetic rope, ATO Hi-Lift bed mounts, Diff locker override, Hitch harness relocated to bumper, Undercover bed cover, Gromm Aux adapter, Grillcraft grill, DT pipe bombs, Custom Magnaflow exhaust, Brute Force HC bumper, TRD Supercharger
    Dibs on the supercharger if this means you're going turbo.... :)
  9. Apr 30, 2013 at 9:33 AM
    #809
    Blackdawg
    Monte
    Wyoming/St. Louis
    oh..well yea..you can always just up the boost..with in a turbos limits that is..and your supporting mods(block, head, fuel, ect).
    But i know a few guys that ran full on stand alones and had different maps for different elevations to retain the same similar power out put..but the wastegate just stays closed longer and lets less exhaust out at higher elevations give more "boost" even tho the amount of o2 flowing into the motor itself is generally the same. So power is about the same.
  10. Apr 30, 2013 at 9:43 AM
    #810
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    8.7 psi on Garrett GT3582R, makes 396 whp at sea level. :cool:
  11. Apr 30, 2013 at 9:56 AM
    #811
    Blackdawg
    Monte
    Wyoming/St. Louis
    exactly..would take me like 10-12psi outa the same turbo to get that power.
  12. Apr 30, 2013 at 10:07 AM
    #812
    memario1214
    Colton
    Missoula, MT
    Haha ill be fine. Thanks for the offer though lol. Gonna drive again today in much less wind and see how it feels on a more level playing field. Where I'm moving is a few thousand feet lower elevation which will pick up the power too.
  13. Apr 30, 2013 at 6:18 PM
    #813
    memario1214
    Colton
    Missoula, MT
    And now I know why I am not thoroughly happy with the S/C... I don't think I am making boost (not much anyway), just more noise. Investigation time...
  14. Apr 30, 2013 at 6:19 PM
    #814
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    :spy:
    I be watching both forums
    lucky for you, Gadget is in ur thread on the go fast forum right now
  15. Apr 30, 2013 at 6:28 PM
    #815
    memario1214
    Colton
    Missoula, MT
    Gadget, Mark, and Tron... At least I am in good hands
  16. Apr 30, 2013 at 6:36 PM
    #816
    06 tacoma owner
    06 tacoma owner Well-Known Member
    Will
    Madisonville, KY
    2017 SR5 4x4
    Stock...for now
    Sweet truck!
  17. Apr 30, 2013 at 6:47 PM
    #817
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    ooooooo now I see Mark
    good hands indeed
    too bad we cant post vids for an obvious problem identifier.
    ur n/a time was waaaaay too close to ur f/i time
  18. Apr 30, 2013 at 6:52 PM
    #818
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    u seemed to rlly fall on ur face at 60
    and then someone threw an anchor out at 70
    wtf
  19. Apr 30, 2013 at 7:23 PM
    #819
    memario1214
    Colton
    Missoula, MT
    Thanks man! Too bad it's not running quite right at the moment :pout:
    WAY too close. 1 sec difference to 80 isn't shit.
    Yep... I noticed that too.
  20. Apr 30, 2013 at 7:29 PM
    #820
    NC15TRD
    NC15TRD Well-Known Member
    Nick
    PA
    16 Sierra SLT All Terrain
    Readylift, Truxedo, Husky Liners, Carven
    bad s/c?
