memario1214's JAFR Build
Discussion in '2nd Gen. Builds (2005-2015)' started by memario1214, Oct 6, 2011.
  1. Dec 2, 2013 at 12:15 AM
    #1241
    NORTHVAN08
    NORTHVAN08 Member
    Jake
    Vancouver
    2008 Toyota Tacoma TRD sport (RED)
    18in Rims Leer canopy
    I really like the Head lights how did you make those. I thinking if putting a set on mind
  2. Dec 2, 2013 at 7:15 AM
    #1242
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I took stock headlights and retrofitted FX-R projectors into them. There are DIYs around here on how to do it. Or else you could always pay someone to do it for you.
    For the build: Truck has been running real weird lately. After talking to a couple people on here and doing some research online as well as tearing the truck doen this weekend I have ironed it down to a couple things... either my TPS has gone bad or else I have a vacuum leak somewhere. Gonna replace the TPS tonight if I can get the part just to iron one thing out. If I take it to a shop it'll cost me as much as the part just to have them look at it. Got a 200mi drive on Friday and I need the truck running well. Wonder if this might be part of the stuff I would notice time to time this summer as well.
  3. Dec 2, 2013 at 7:27 AM
    #1243
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Was really to busy to really get into the texts these past few days, getting ready for the race. I apologize about that.
    Are there any strange fluctuations in the AFR's? Boost gauge reading differently? Explain a few more details if you don't mind.
  4. Dec 2, 2013 at 7:28 AM
    #1244
    BradyT88
    BradyT88 Well-Known Member
    TPS is throttle position sensor right? Mine is going out in my car (it is throttle by cable instead of wire like our Tacos) and it gets real finicky on occasion. I've had it throw the code a couple times but it goes right back to acting normal for months at a time between acting up so I have yet to replace it.
  5. Dec 2, 2013 at 8:05 AM
    #1245
    memario1214
    Colton
    Missoula, MT
    AFR has been doing some strange fluctuations from time to time as well. I will see it drop randomly and then come right back up. Boost guage reading fine, but sitting at 0 like all the time. The truck almost always wants to be in boost. Also, one more thing that I did notice today, which may have been going on forever and I just didn't know it was my dash lights would dim... ever so slightly every second or so
  6. Dec 2, 2013 at 9:37 AM
    #1246
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Boost gauge at idle is at "0"?
    Dash is dimming huh? Need to get that battery tested. Might have a bad cell or so.
  7. Dec 2, 2013 at 9:38 AM
    #1247
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    Could be electrical...ie bad battery or alternator...
    I'm on my 3rd battery...had loss in power last summer and also the alternator went out
  8. Dec 2, 2013 at 11:16 AM
    #1248
    memario1214
    Colton
    Missoula, MT
    Well... one issue solved. The battery tested good on the handheld, but failed the load test miserably. Put a new one in and took it for a drive... same thing. My stupid ass forgot to take into account that their little clock preserver thing that they plug into the OBDII will maintain the ECU and whatever party tricks it might have picked up. That dawned on me as I was on my way back. Disconnected the negative terminal and left it off for a few minutes. First time turning it over it caught and died right away. Tried it again and it seems to all be good in the hood. I will know for sure when I go home tonight.
  9. Dec 2, 2013 at 11:41 AM
    #1249
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Hope that was the issue!
  10. Dec 2, 2013 at 4:36 PM
    #1250
    memario1214
    Colton
    Missoula, MT
    I really can't believe that was the issue. It's not 100% confirmed and I will know for sure in the morning, but a few things seem to be ironed out for the better. I was able to stay out of boost on the way home and the hard starts seem to be gone. Tomorrow should be the true test.
  11. Dec 2, 2013 at 8:50 PM
    #1251
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hope you get it all ironed out buddy!
  12. Dec 3, 2013 at 4:51 AM
    #1252
    memario1214
    Colton
    Missoula, MT
    Trucks not all better :pout:
  13. Dec 3, 2013 at 4:52 AM
    #1253
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Still diagnosing huh?
  14. Dec 3, 2013 at 4:53 AM
    #1254
    memario1214
    Colton
    Missoula, MT
    Yeah... don't have the money to fix it atm, so its gonna have to wait. Seems like its better, but I think that shit battery put everything on the fritz.
  15. Dec 3, 2013 at 4:56 AM
    #1255
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hmmm..
    Are the lights still dimming?
  16. Dec 3, 2013 at 5:01 AM
    #1256
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    How long did you leave this battery disconnected?
  17. Dec 3, 2013 at 5:28 AM
    #1257
    memario1214
    Colton
    Missoula, MT
    The light issue is sorted out. Still sorta doing its weird shifting thing though. Battery was disconnected for about 3 min yesterday afternoon
  18. Dec 3, 2013 at 5:52 AM
    #1258
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Disconnect it for about 15 minutes. Let the capacitors drain to completely reset the computer.
  19. Dec 3, 2013 at 6:01 AM
    #1259
    memario1214
    Colton
    Missoula, MT
    When I put the truck in the garage tonight I'll disconnect the negative and leave it overnight.
  20. Dec 3, 2013 at 6:46 AM
    #1260
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    What's the shifting issue again?
