memario1214's JAFR Build
Discussion in '2nd Gen. Builds (2005-2015)' started by memario1214, Oct 6, 2011.
  1. Dec 5, 2013 at 4:14 PM
    #1281
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I think you should install an AFR gauge so you know what's actually going on. The ECU is guessing and trying to compensate for what it sees. Install the gauge and we can diagnose the issue from there.
  2. Dec 5, 2013 at 4:18 PM
    #1282
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Oh believe me I know I need it installed.. I have it already. Just need to have the sensor bung welded in. Why do you think I was asking questions? ;)
    I still think im gonna undo the fpr mod and see what it reads.
  3. Dec 5, 2013 at 4:22 PM
    #1283
    memario1214
    Colton
    Missoula, MT
    I would. Honestly. Get yourself a baseline first. The reflash is gonna leave you running rich as a pig so you really shouldn't run into issues there.
  4. Dec 5, 2013 at 4:41 PM
    #1284
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    And the FPR mod just makes it run more rich right?
  5. Dec 5, 2013 at 4:45 PM
    #1285
    memario1214
    Colton
    Missoula, MT
    The majority of the time yes... I don't know all the details on it, Tor would. It more or less balances out your fuel pressure to maintain consistent flow.
  6. Dec 5, 2013 at 4:48 PM
    #1286
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    Undid fpr mod.....
    Still bottoms out at 10
  7. Dec 5, 2013 at 4:49 PM
    #1287
    memario1214
    Colton
    Missoula, MT
    Put the smaller pulley on Brock
  8. Dec 5, 2013 at 4:55 PM
    #1288
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Come on over and lend some muscle
  9. Dec 5, 2013 at 5:32 PM
    #1289
    BradyT88
    BradyT88 Well-Known Member
    So between your username, all the problems you've had with your truck and this pic...
    Can we start calling your truck Polio and this is your new pic for the OP? ;)
  10. Dec 5, 2013 at 5:46 PM
    #1290
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    undid mine just now as well.. took it for a spin..
    cruising/idle sems to be a TAD higher.. consistently in the high 14.7's. WOT is still at 12.08.
    again.. this is all a real rough estimate with the Torque app. AFR gauge will be installed next weekend.
  11. Dec 5, 2013 at 7:28 PM
    #1291
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Torque app most likely won't read any more rich than 12.0:1. My scangauge II won't, when reading off of the OBD II. When the truck goes into Open Loop, it basically isn't reading the AFR's any more and is just dumping a preset amount of fuel, that is supposed to be really rich and thus safe. Probably the reason why the Scangauge doesn't read any lower than 12:1. Just a guess. Someone else might know that exact reason better.
    The FPR mod is best used for those who have the reflash, don't have an aftermarket ECU and cannot use larger than the TRD injectors, and need a means to get extra fuel for extra boost, based off of the previous limitations. The extra fuel to keep the AFR's in the 11's. Up to 8psi, it might not be necessary depending on the quality of the reflash. Sometimes the reflash is spot on, and sometimes it is way off in either direction. Watching your own AFR's is the only way to know if you need to do the mod.
  12. Dec 5, 2013 at 7:33 PM
    #1292
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Thanks man. makes sense. mind poppin over to my build to go over it a bit more.. dont want to thread jack Colton.. :eek:
  13. Dec 5, 2013 at 8:00 PM
    #1293
    memario1214
    Colton
    Missoula, MT
    You're more than welcome here
  14. Dec 5, 2013 at 8:01 PM
    #1294
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    just bein polite lol
  15. Dec 10, 2013 at 1:09 AM
    #1295
    monstajp
    monstajp Well-Known Member
    joshua
    las vegas
    2011 trd sport debadged
    Debadged, Blacked Out Taillights and 3rd Brakelight , Blacked Out Grille, Blacked Out Lower Valence, Hot Wheels Badges, Yellow Fog Lights, Rims and Tires. Undercover Swing Case, Pop-A-Lock on my Tailgate, N-FAB Step Bars, Extang Trifecta Bed cover, Aero Cat- Back Exhaust, PIAA Extreme white 4000k Bulbs, Readylift 2.25 Leveling Kit.
    beautiful
  16. Dec 10, 2013 at 10:47 AM
    #1296
    emilminasian
    emilminasian Well-Known Member
    Emil Minasian
    Glendale, CA
    2011 Trd sport double cab
    Did you get a noticeable difference with the headers and pully?
  17. Dec 10, 2013 at 10:51 AM
    #1297
    memario1214
    Colton
    Missoula, MT
    The pulley was definitely noticeable and a nice pick up on power. The headers were on before the S/C. They were good for more top end, but were garbage for the low end power of the truck.
  18. Dec 16, 2013 at 6:12 PM
    #1298
    AR15xAR10
    2013 TRD Sport 4x4 V6 ACLBFTMFW
    I'm sure people have askes 100 times over....but.....how does the dip hold up on the roof? :D
    DAMN good looking truck.
  19. Dec 17, 2013 at 1:33 PM
    #1299
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    I herp derped the audi...you would be proud
  20. Dec 17, 2013 at 3:48 PM
    #1300
    memario1214
    Colton
    Missoula, MT
    It actually has held up quite well. It has been on there for nearly 3 years now and I am just thinking of finally redoing it. Maybe a couple little chips on the leading edge from road debris, but good other than that.
    YESSSSSS!!!!! It's about time
