memario1214's JAFR Build
Discussion in '2nd Gen. Builds (2005-2015)' started by memario1214, Oct 6, 2011.
  1. Mar 27, 2014 at 11:35 AM
    #1381
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    That's how my truck felt, when the front passenger bearing was going bad. About a week before it blew out on me, on the freeway.....
  2. Mar 27, 2014 at 12:57 PM
    #1382
    memario1214
    memario1214 [OP] Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    GREEEEAT... Well the new hub assembly should hopefully be here within a few days and then I will hopefully get a couple hours free to replace it.
  3. Mar 28, 2014 at 7:08 PM
    #1383
    XPOTRPR
    XPOTRPR CNC Programmer/Machinist
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Hey man this is all good news. Its not the tranny.. AND there seems to be a good chance that the new wheel bearing will solve your issues. :thumbsup:
  4. Mar 28, 2014 at 7:19 PM
    #1384
    memario1214
    Colton
    Missoula, MT
    I am super skeptical that it will heal all... But I am up for trying just about anything. The crazy thing is that I would have never known it was an issue if I didn't do that axle replacement! It's making no noise, but it is a rusted dry mess in there. Now I am paranoid as fuck that it is gonna go out on me in the next couple days. :p
  5. Apr 1, 2014 at 7:07 PM
    #1385
    memario1214
    Colton
    Missoula, MT
    Bearing WILL NOT come free from the spindle. FUCK
  6. Apr 1, 2014 at 11:04 PM
    #1386
    memario1214
    Colton
    Missoula, MT
    Took me longer than expected and a trip to Wal-Mart late night for a 17mm socket (of course I had to buy a set), a chisel, and some pb blaster... but we are done!!! :yay:
  7. Apr 2, 2014 at 5:48 AM
    #1387
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Those front bearings are such a pain. Relieved that you got it finished. :thumbsup:
  8. Apr 2, 2014 at 6:12 AM
    #1388
    XPOTRPR
    Josh
    Chandler, AZ
    > BUILD LINKS >
    Fingers crossed that resolved your issues man :cheers:
  9. Apr 2, 2014 at 10:43 PM
    #1389
    mizzac
    mizzac Well-Known Member
    Mac
    Montana/CO
    Yota-less
    Stickers
    |Get some ceramic breaks while your at it.
  10. Apr 3, 2014 at 8:18 PM
    #1390
    memario1214
    Colton
    Missoula, MT
    NO. I already had them and they squeaked and provided no more stopping power... Will not buy
  11. Apr 3, 2014 at 8:21 PM
    #1391
    Jerez
    Jerez SoCal LED Dash Swap
    Rod
    Ontario Ranch
    08 TRD 2wd converted to 4wd
    Estock
    So the problem was one of your wheel bearings?
  12. Apr 3, 2014 at 8:26 PM
    #1392
    memario1214
    Colton
    Missoula, MT
    Well I can say this... The truck doesn't run any worse! I still think I have something going on, but I am not entirely sure what it is. I have been having an issue with hard starts when it is cold, so my next thing is to find out why this might be happening. I am beginning to wonder if the truck is providing all of its power or if I might have a fouled plug or something which is causing the truck to have to throw in boost to maintain speed. That will be the next issue I dive into. Might have to tear everything apart and check the driver's side bearing too. Driveline seems good so... I'm kind of pulling at straws, but I still get the feeling that something isn't quite right.
    That being said, does anyone know for sure if a bad battery can cause an issue with the ECU? To the point where it might rewrite some things permanently and cause issues even after an extended battery disconnect? I just wonder if that sketch battery that I replaced this winter might be the cause of some of my issues.
  13. Apr 6, 2014 at 6:24 PM
    #1393
    memario1214
    Colton
    Missoula, MT
    Wow must have been the nice weather or something!? I got so much attention driving around for like 10 minutes. Not very many people mod vehicles around here... and the recent rain took most of the winter gunk off
  14. Apr 6, 2014 at 6:38 PM
    #1394
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    it's the grill. :cool:
  15. Apr 6, 2014 at 6:45 PM
    #1395
    MTgirl
    Weesa
    Bob's secret mod lair
    :laugh: maybe its just casue its SO FREAKIN' LOUD!!!
    or maybe teh dip
  16. Apr 6, 2014 at 7:07 PM
    #1396
    memario1214
    Colton
    Missoula, MT
    ALL OF THE ABOVE :D
    The grill certainly isn't hurting the cause.
  17. May 4, 2014 at 10:19 AM
    #1397
    99TacoDriver
    99TacoDriver Well-Known Member
    South Louisiana
    OME 885x/5100s/LR UCA/3 leaf AAL/275/70/17 Terra Trac X-Venture
    what did you paint blue to get the demon eye effect?
    im confused and what retros are those are those?
  18. May 4, 2014 at 11:47 AM
    #1398
    memario1214
    Colton
    Missoula, MT
    Everything that was forward facing that did not affect the light output. So the reflector bowl in the back I did not touch, but the shield and the little piece below it were painted. I pussed out on pulling out the lens, but there is an area just behind the lens that should be painted as well for maximum effect. If you disassemble everything it should become pretty apparent what affects light output and what doesn't. You have got to make sure to use hi temp paint though as normal paint will flake off.
    The retro is an FX-R 3.0
  19. May 4, 2014 at 12:04 PM
    #1399
    Twinkie0311
    Twinkie0311 Mall crawling like a boss
    Hillsboro, Oregon
    13 DCLB TRD Sport MGM
    OME Lift w/ Dakars, TRD catback exhaust, 275/70/17 with SCS Stealth 6. and much more.
    Haven't checked this thread in a while, but it still looks like your truck is a sexy beast and those headlights OMG.
  20. May 4, 2014 at 2:18 PM
    #1400
    memario1214
    Colton
    Missoula, MT
    I know it's kinda dead as of late isn't it? I am wavering back and forth with continuing to mod it or not. That being said... I have been looking at a couple things I still want to do :cool: Hoping to not catch the bug again haha.
