Memory Saver
Discussion in '3rd Gen. Tacomas (2016-2023)' started by VicNic3, Mar 3, 2023.
  1. Mar 3, 2023 at 7:12 AM
    VicNic3
    VicNic3 [OP] Well-Known Member
    GA
    2018 Toyota Tacoma Sport 4x4 DCSB Silver Sky Metallic
    Has anybody used some sort of memory saver when replacing the battery in your truck. Just replaced the battery in 18 TRD Sport and the backup camera quit working on head unit with the front/rear anytime backup unit.Had to take head unit out and go through a series of unplugging connectors with truck in the ON position and Off position, reconnect to get back working.After doing some research I found several out there to use, but which is better.
    9 volt OBD type
    https://www.amazon.com/Connector-Ba...aver,aps,106&sr=8-3-spons&smid=A27DVM5RJOXCTZ
    Battery type
    https://www.amazon.com/VSTM-Emergen...2&sprefix=battery+memory+saver,aps,106&sr=8-5
  2. Mar 3, 2023 at 7:12 AM
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Do you any aftermarket stuff?
    Chew likes this.
  3. Mar 3, 2023 at 7:26 AM
    VicNic3
    GA
    Yes, winch, front lightbar. I've also had problems on wife's 4Runner with the power windows not working after new battery and no mods on it. Have to cycle the windows up/down to work properly.
