Memory Slot problems
Discussion in 'Technology' started by 07TacoRidah, Nov 23, 2012.
  1. Nov 23, 2012 at 1:30 PM
    07TacoRidah
    07TacoRidah [OP] SHHHH, this is interesting
    Pasadena CA
    2007 Base Model Access Cab
    Engine bay: aFe Pro Dry filter Secondary air filter deleted Sokie Tech hood damper kit Xscorpion dual 0g wire ring terminal (3) Big 3 upgrade (0g wiring) HID kit (headlights, H1 - 8k) HID kit (fog light 3k) Sylvania Zevo LED turn signals w/hyper flash resistors Rear back up light GY6 bulb Bullz Audio 0g wire Exterior: Dynamik Retro Projector style headlight housing Depo Euro Black Altezza LED tails Front grille swap (to chrome, painted w/bedliner paint) XR front bumper valance (dipped red) Aftermarket fog light kit w/OEM switch Rear bumper swap (to chrome, painted w/bedliner paint) 99 Cents Store tailgate lock Suspension: DJM 3/4" drop kit 1" spindle spacer kit 4x4 leaf pack swap (middle leaf removed) Air Lift rear helper springs Rims: 18x10 Work VS-KF front w/5" lip 18x11 Work VS-KF rear w/6" lip 225/40/18 tires all around Neochrome lock nuts Pepboys valve stem caps Interior: Wink Mirror rear view Center console lid fabric Metra Dash kit Kenwood bluetooth headunit Hifonics Zeus ZXi 6410 PB 6 1/2" component speakers up front 10" JBL GTO 1014 (2) 4 ohm svc in dual ported box JDM Fuchsia shift knob (Crown Royal shift boot)
    I have this motherboard
    http://www.newegg.com/Product/Product.aspx?Item=N82E16813186125
    When I got it from my older brother, it already had 2g of RAM (2x1g sticks) and it said on the specs I could go up to 8g of RAM max. I bought myself a 2g stick and I come to find that BOTH of the secondary RAM slots do not read the RAM sticks. Anyone know why this happens/how to fix this/etc.? Would be nice to have 4g of RAM right now. :(
  2. Nov 23, 2012 at 1:41 PM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    Without looking at the specs what RAM is it supposed to take and what did you put in?
    Okay, I found it DDR2 800. Some boards don't like a single stick in a channel when there are two sticks in another channel. Some boards like to run with matching sticks as well. Try pulling out the one gig sticks and just use the 2 gig stick.
    I would have bought two 2 gig sticks and removed the one gig sticks or 4 2 gig sticks.
  3. Nov 23, 2012 at 2:05 PM
    07TacoRidah
    Pasadena CA
    did that. I first tried to put the 1g in the slot next to the 2g, but it didn't even read it. So then I put it next to the 1g one, and same thing happened. I made sure there wasn't anything in the slots too, kind of dusty inside the tower.
  4. Nov 23, 2012 at 2:07 PM
    Bennett707
    Bennett707 TWSS Enforcer
    Oregon
    '04 V6 3.4 TRD
    zip ties and scotch tape
    they insert? dont show? what os and bit are you running?
    i dont remember what the g's are but i know on win 7 it caps you on 32 and to get the rest u have to use 64.
  5. Nov 23, 2012 at 2:08 PM
    dexterdog
    Oly WA
    2012 F150
    Did you try just the 2 gig stick by itself? Just trying to figure out if you got a bad stick.
  6. Nov 23, 2012 at 2:10 PM
    Nunavut
    Nunavut Eh oh, Canada go.
    Shayne
    Canada
    V6
    http://www.tacomaworld.com/forum/1st-gen-tacomas/205044-nunavut-my-build.html
    Windows 7, 32bit is limited too 4 gigs of ram. 64 bit will allow you to have more.
    Did you put the 2gb ram in the slot where the 1gb ram was? Did that work?
  7. Nov 23, 2012 at 2:15 PM
    07TacoRidah
    Pasadena CA
    I'm running Windows XP Pro SP3 32 bit
    The 2g should be reading. I have this program called CCLeaner, it tells me what kind of processor/RAM and video card I'm using. Found this out right now too. As of now, the RAM reads out to 3.0 (on the CCleaner program) and this is ONLY with ONE 2g and ONE 1g in the slot (seperate - hope I am not confusing). When I had TWO 1g RAM sticks in the slots next to each other, it would read out to 3.2g of RAM (this is when I had ALL 3 RAM sticks put into the slots - 1g (x2) and 2g (x1)... ... why is this?
  8. Nov 23, 2012 at 2:20 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    from a quick google 32 bit is capped at either 3gb ram or 4gb.
    at work, limited research supplies. :(
  9. Nov 23, 2012 at 2:20 PM
    07TacoRidah
    Pasadena CA
  10. Nov 23, 2012 at 2:21 PM
    07TacoRidah
    Pasadena CA
    from the searching, it came out to about 3.5g MAX :mad::mad::mad::mad: LAME thanks guys. going to go outside and kick rocks for a bit.
  11. Nov 23, 2012 at 2:21 PM
    Bennett707
    Oregon
    '04 V6 3.4 TRD
    glad i could help, time to go up to 64!
  12. Nov 23, 2012 at 2:22 PM
    kryten
    kryten Well-Known Member
    Canada
    07 TRD Sport DCSB 6MT 4x4
    1" lift from 3rd gen suspension, 265/75/16 ATs
    You will not have access to full 4 gigs on 32 bit OS. 3GB+ is correct.
  13. Nov 23, 2012 at 2:23 PM
    dexterdog
    Oly WA
    2012 F150
    Use BIOS to check whether your RAM is showing up or not.
  14. Nov 24, 2012 at 10:00 AM
    replica9000
    replica9000 mildly retarded...
    Blackstone Valley
    2008 AC Sport 6spd
    How much RAM does WinXP see now? Are you using onboard video? That will probably be sharing some of your RAM. Although, I would think even if video was sharing up to 512MB, WinXp should still see the other 3.5GB.
