Memphis Audio Tweeters
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Cement_Taco92, Feb 20, 2019.
  1. Feb 20, 2019 at 8:44 AM
    Cement_Taco92
    Cement_Taco92 [OP] Beautiful Bearded Bastard
    Jeremy
    Roseburg Oregon
    2018 Cement Tacoma TRD Offroad
    Faux pro grille, plastidip wheels.
    I ordered some memphis audio tweeters for the taco today, and I watched a few videos and I noticed there is a 4 pin plug on the stock tweeter, anyone have any insight how to install the new tweeters? Crutchfield didn't offer a plug and play harness for that particular area. Thanks.g953PRX27-F.jpg
  2. Feb 20, 2019 at 8:50 AM
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    There are 3 ways you can go about this.
    1: cut the 4 pin plug off and wire it in. The signal comes from the radio ->tweeter -> to the woofer. So if you dont wire it right, then the woofer doesnt work
    2: buy ********* harness, plug and play easy
    3: remove the plug from the back of the tweeter, its held on with 3 clips. You will need to do some soldering. First unsolder the factory tweeter, then replace the little black cap (black tube thing) with a peice of wire. Then solder the new tweeter wires to where you removed the factory tweeter wires.
    I went with #3 for my 3 way system. I wired it right to my crossover.
    Cement_Taco92[OP] and peavey02 like this.
  3. Feb 20, 2019 at 8:54 AM
    Cement_Taco92
    Jeremy
    Roseburg Oregon
    Think I may opt for that, no better time than now to practice my soldering skills.
  4. Feb 20, 2019 at 8:56 AM
    5nahalf
    Erik
    Minnesota
    Its a pretty easy job. Just keep track of polarity from the speaker as the plug is not labeled.
  5. Feb 20, 2019 at 8:57 AM
    Cement_Taco92
    Jeremy
    Roseburg Oregon
    I will most definitely do one at a time. I also ordered new door speakers. so its going to be a fun weekend lol.
  6. Feb 20, 2019 at 9:00 AM
    5nahalf
    Erik
    Minnesota
    One thing not many people think of is that the factory front speakers have water shields and very small magnets. The location of the speaker allows water to drip from the window tracks onto aftermarket speakers.
    I killed one speaker because I didnt know this... water dripped into the magnet, and rusted up the voice coil. I have since replaced that woofer and put in foam speaker cups (you need to cut out the bottom half of the cup)
  7. Feb 20, 2019 at 9:01 AM
    Cement_Taco92
    Jeremy
    Roseburg Oregon
    Supposedly crutchfield sent everything that is needed. but i will keep that in mind with the install.
