MESO Customs 3RD Brake Light housings
Discussion in 'Automotive Group Buys' started by MESO, Mar 20, 2019.
  1. Sep 25, 2019 at 7:49 PM
    #261
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    I don't have a 3rd gen unit in front of me, but my 2nd gen one had depressions, but no threaded holes. I essentially used the bolts and screwed them straight through the printed material.
    @MESO any insight?
  2. Sep 25, 2019 at 7:57 PM
    #262
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Use the shorter Allen bolts. Put a Allen bit on a drill and apply pressure when screwing in. They will tap their own threads in the nylon plastic. The longer Allen bolts are too long, I designed the housing with the shorter set.
    Like this
    https://vimeo.com/342787569
    su.b.rat[QUOTED] and memario1214 like this.
  3. Sep 26, 2019 at 8:54 AM
    #263
    su.b.rat
    su.b.rat broken truck
    thank you x 1,000,000. ready to go. :thumbsup:
  4. Oct 20, 2019 at 7:42 PM
    #264
    Jd05
    Jd05 Member
    05 tacoma
    Stock
    I know im a little late to the party, but im looking for the KC5"--$140(holds 5 KC CYCLONES) for the 2nd gen tacoma. Does anyone know when they will be back in production? thank you
  5. Oct 21, 2019 at 6:37 AM
    #265
    JustinL
    JustinL Well-Known Member
    Justin
    Berlin, CT
    2009 TRD OffRoad DCSB Pyrite Mica
    2012 Conversion
    I think 2nd gen units hold 4 Cyclones. The 3rd gen unit holds 5 Cyclones.
  6. Oct 21, 2019 at 8:18 AM
    #266
    trdtacojef
    trdtacojef Well-Known Member
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    OME Dakar Medium duty rear leafs Total Choas UCAs Elka 2.5” Extended Travel CO and Rear Shocks w/ RR and DC FN FX Pro 17” Silver Rims Nitto Ridge Grapplers 285/70R17
    If anyone starts to sell their 2nd Gen tacoma and is willing to snag the Meso customs 3rd brake light off and sell - PM me.
  7. Oct 21, 2019 at 4:06 PM
    #267
    Jd05
    Jd05 Member
    05 tacoma
    Stock
    Sorry, im looking for the 4 holder for the second gen.
  8. Oct 21, 2019 at 5:26 PM
    #268
    trdtacojef
    Jeremy
    Alabama
    2007 DCSB TRD Sport
    Same here... I may have just described it incorrectly.
  9. Oct 29, 2019 at 1:51 PM
    #269
    Glenn247
    Glenn247 Well-Known Member
    Lynchburg VA
    2016 DCSB Manual TRD Sport 4x4
    I'm having a tough time dealing with Toyota regarding my 2016 DCLB third brake light leak...
    I'm being told I can't purchase the third brake light gasket from Toyota because it is only available with the whole third brake light assembly (150 bucks)
    And I can't seem to find an aftermarket third brake light gasket/seal for a 2016 DCLB (found a bunch for different model years and Access Cabs though ????)
    I may be doing this repair myself and would like to know if MESO may have what I need in terms of the gasket/seal and/or a whole new third brake light assembly rather than going with OEM again...
    Thanks for the help!
  10. Oct 29, 2019 at 2:02 PM
    #270
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I would suggest going with a gasket maker in the meantime.
  11. Oct 29, 2019 at 2:30 PM
    #271
    Glenn247
    Lynchburg VA
    Ok; good guidance for the short term, but I'd like to fix once and for all.
    Does MESO have anything for me? Please see my plea above; thanks!
  12. Oct 29, 2019 at 5:14 PM
    #272
    CttAznRanger
    Brandon
    Boston, MA
    The gasket maker will be a permanent fix, just depends on how clean you want to make it look.
    @MESO Got any seals for a third brake light otherwise?
  13. Nov 1, 2019 at 4:32 PM
    #273
    Glenn247
    Lynchburg VA
    Any word on ordering the sea/gasket separately from Toyota, or if there is an aftermarket gasket available?? I am in need of a solution
  14. Nov 1, 2019 at 7:42 PM
    #274
    MESO
    State of Jefferson
    The stock gasket is not available by itself as far as I know. It’s also a PITA to remove from the stock housing because it’s glued on
  15. Nov 1, 2019 at 7:44 PM
    #275
    Glenn247
    Lynchburg VA
    Darn, not what I wanted to hear, but that explains why Toyota only sells the third taillight assembly as one piece (with gasket likely attached) for 150 bucks...
  16. Nov 1, 2019 at 7:45 PM
    #276
    Glenn247
    Lynchburg VA
    @MESO so what do you suggest I do if I don't want that stock option...
    Do you have a third brake light assembly I could use rather than the stock assembly? Any ideas, such as just using silicone to seal it up...
  17. Nov 6, 2019 at 10:33 AM
    #277
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Get some black gasket maker and run a bead around the whole thing.
  18. Nov 6, 2019 at 10:34 AM
    #278
    Glenn247
    Lynchburg VA
    From the inside and/or outside?
    Got a link to that product?
  19. Nov 6, 2019 at 11:02 AM
    #279
    CttAznRanger
    Brandon
    Boston, MA
    Skydvrr likes this.
  20. Nov 6, 2019 at 11:08 AM
    #280
    Skydvrr
    Nick
    YMH
    Black '17 OR
    CttAznRanger[QUOTED] likes this.
