MESO CUSTOMS Total Tail Stage 1
Discussion in '3rd Gen. Tacomas (2016-2023)' started by OCD TACO, Jan 9, 2022.
  1. Jan 16, 2022 at 4:42 PM
    Williamsonj320
    Williamsonj320 Well-Known Member
    Florida
    2017 Tacoma SR 2.7 RWD AC
    Got the second set of resistors in and everything seems to be working fine as of now. I wish there was a 12pin relay to make this all easier and to keep the power consumption down but until then it is what it is.
    Also I checked the other night. When in reverse if you turn on your turn signal the back up light for that side turns off. It does not switch back and forth between the two. The other side still shows the back up light though. If your cautions are on then the back up lights will not come on. Probably an important thing to keep in mind in very specific but potentially dangerous conditions.
  2. Apr 23, 2022 at 3:02 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Has anyone installed the stage 1 total tails without the load resistors and been fine?
    I’m installing mine in a few days (I have a 2021 SR5) and wondering if I should just order the load resistors now. I was hoping I didn’t need them but it seems like most people, on this thread at least, needed them to prevent the hyper-flashing.
  3. Apr 23, 2022 at 3:03 PM
    HUTCHRED
    HUTCHRED I can ride my bike with no handlebars.
    2022 Black Tacoma Limited
    Trying to be chrome free
    Yeah no problem with mine so long as I'm not in reverse with the turn signal on. If I do that it fast blinks. However, it goes back to normal when I'm in a forward gear.
    Road_Warrior[QUOTED] likes this.
  4. Apr 23, 2022 at 3:05 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Ok cool, thanks. I’m not too worried about the reverse thing…not sure I’ve ever used the turn signal in reverse lol
    HUTCHRED[QUOTED] likes this.
  5. Apr 23, 2022 at 3:08 PM
    HUTCHRED
    Lol. I guess I have, twice. Lol. But yeah, it's not a huge issue.
  6. Apr 23, 2022 at 3:10 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Awesome thanks! Hopefully I don’t need to order the load resistors, fingers crossed.
  7. Apr 23, 2022 at 3:11 PM
    Borracho Loco
    Borracho Loco My truck identifies as a Prius.
    DFW, Texas
    2021 Voodoo Blue - Tacoma TRD Offroad DCSB
    Oh look, another mod....
    I did. I've had my stage 1 (without the resistor) on my truck for 10 months now. No issues at all.
  8. Apr 23, 2022 at 3:13 PM
    HisDad
    HisDad Well-Known Member
    Texas at last
    2019 Cement Tacoma SR5 Double Cab
    I found that if I put the four way flashers on and put it into reverse, it also caused hyperflash. I think it's reasonable for everyone who orders this kit to order the resisters at the same time. I know that MESO says that it MIGHT cause hyperflash under some conditions, but I think in reality it's reasonable to assume that that is the norm.
    Road_Warrior likes this.
  9. Apr 23, 2022 at 3:19 PM
    hunter5150
    hunter5150 Well-Known Member
    Tony
    So Cal
    2021 SR5 Trail Edition - AG
    I can confirm the issue with hyper flash while in reverse with turn signal on. Other than that, it works perfectly. Like others said, I rarely use turn signal while in reverse. It is a non-issue for me.
  10. Apr 23, 2022 at 3:19 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Ok cool, hopefully I have the same luck.
    Yeah, after reading through a bunch of threads it seems like more people need them than don’t.
  11. Apr 25, 2022 at 10:35 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Just to close the loop on this, I just installed the total tail kit without the load resistors and fortunately I do not have any hyperflashing.
    MESO and HUTCHRED like this.
  12. Apr 25, 2022 at 1:46 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Thanks for the update!
    I thought about building resistors INTO the bulbs. But since everyone's light configuration is different..you can always ADD a resistor but you can't take any away. If there is to much(technically less resistance), it will cause the truck to do opposite of hyperflash. It will flash once then stop completely stop until the truck restarts. Having them plug and play gives the customer the ability to fine tune them to their system.
  13. Apr 25, 2022 at 3:15 PM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    That makes sense, I’m glad my post helped! Love your stuff :thumbsup:
  14. May 15, 2022 at 5:51 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    This makes sense to me, since the same bulb does both the turn signal and backup light. Wonder if getting signals for both lights are mutually exclusive for that bulb?
    I'm thinking of going the total tail route and just ordering the resistors at the same time since odds are I will need them. For those of you who installed them, did you disconnect the negative battery terminal before you started?
  15. May 15, 2022 at 5:58 AM
    #35
    nucl3ar
    nucl3ar 2021 White Tacoma Limited 4x4
    Raleigh, NC
    OVTune Meso Total Tail Stage 1 tail lights BAKFlip MX4 Tonneau Cover
    I didn't disconnect the battery and fortunately did not run into any issues. I must have also been lucky, I did not need the additional resistors. I've been running these for about a year now and no issues whatsoever (reverse + turn signal happens, but that's user error in my opinion). It's one of my favorite mods.
    FL_TRD Sport[QUOTED] likes this.
  16. May 15, 2022 at 6:15 AM
    #36
    JackJoachim
    JackJoachim Well-Known Member
    Jack
    North MS/Memphis
    ‘22 Barca Red TRD Off Road 6MT
    One of my favorite mods I’ve done.
    For the reverse/signal bulb I took the rubber gasket from the stock light socket and Swapped it on the new bulb. The meso foam gasket was a little loose.
    TDImark and FL_TRD Sport like this.
  17. May 15, 2022 at 8:23 AM
    #37
    hunter5150
    Tony
    So Cal
    After thinking about it, I bought the resistors from Meso. It didn't bother me. But, I didn't want my family to freak out in case they borrow my truck. It has no more hyper flash. Everything works as it should. And no, i didn't disconnect the battery.
    MESO and FL_TRD Sport[QUOTED] like this.
  18. May 16, 2022 at 8:36 AM
    #38
    MESO
    State of Jefferson
    Hyperflash isn't a big issue, the lights still function. It's just more of a mild annoyance. Glad they worked for you!
    RCrumb likes this.
  19. Aug 31, 2022 at 2:25 PM
    #39
    Southendglass
    Southendglass Well-Known Member
    Tony
    Charlotte
    2022 sport access
    Do the resistors plug in or do you have to splice in?
  20. Aug 31, 2022 at 2:58 PM
    #40
    MESO
    State of Jefferson
    resistors are plug and play for stage 1
