MESO Dash Vent ring kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 3, 2020.
  1. Jul 8, 2020 at 7:55 PM
    #301
    skynyrd87
    skynyrd87 Well-Known Member
    2023 TRD Pro Solar Octane AT 2001 TRD OR White MT
    All of my vents have the same numbers...
  2. Jul 8, 2020 at 7:57 PM
    #302
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Correct. All vent rings are identical. If you want the notches to all line up just orient vent number 2 accordingly
  3. Jul 8, 2020 at 8:00 PM
    #303
    skynyrd87
    I’m confused. None of them are sitting flush.
  4. Jul 8, 2020 at 8:02 PM
    #304
    Ch78
    Ch78 GBO!
    Tomball, TX
    25’ Landcruiser 1958
    Tuned By D3 Performance
    Watch the video on his website. Install is simple. Only the 2nd ring (left side of the stereo) is installed different but if you watch the video you’ll see exactly what he means.
    Afilao likes this.
  5. Jul 8, 2020 at 8:04 PM
    #305
    Ch78
    Ch78 GBO!
    Tomball, TX
    if I remember correctly 1, 3, 4 are all together because they have the same orientation. 2 is located on a different part of the ring but all rings have all numbers. 2 just has a different orientation than 1,3,4
  6. Jul 8, 2020 at 8:15 PM
    #306
    skynyrd87
    Mine are all the exact same.
  7. Jul 8, 2020 at 8:23 PM
    #307
    Ch78
    Ch78 GBO!
    Tomball, TX
    Picture?
  8. Jul 8, 2020 at 8:24 PM
    #308
    MESO
    State of Jefferson
    All rings are the same. They have markings #1,3,4 in 1 spot. Then #2 in a different spot. All that is for is to clock them correctly(so the notch designs line up) because Toyota made the 3 peg holes in different locations for the #2 spot.
    Many people have been confused by this so I’m thinking about just removing the numbers completely.
    as for sitting flush... all 4 rings should sit perfectly flush with the inside of the vent. the OUTSIDE however will not (spot # 1 and 2 are the most noticeable) because the way Toyota designed the dash to mold into the vents at different heights. Small annoyance but once installed you don’t really notice. Hope this clears it up
  9. Jul 8, 2020 at 8:53 PM
    #309
    skynyrd87
    I think I figured it out. The vent to the left of the head unit doesn’t seem to sit as flush as the others. I guess that is normal based on what you said.
  10. Jul 9, 2020 at 5:59 AM
    #310
    Mac62989
    Mac62989 Well-Known Member
    2020 Quicksand Sport AC MT
    ^It was annoying at first when the vents were in hand but I kind of forgot it was even an issue until I read it constantly on here..
  11. Jul 23, 2020 at 10:42 AM
    #311
    D-FENS
    D-FENS Well-Known Member
    Los Angeles
    2017 TRD OR 4x4 Quicksand
    @MESO I had a couple questions about availability on the site...
    I can add MGM vent ring kit to my cart but then its says sold out and is removed upon checkout?
    On the opposite side, site says white map lights sold out but I can still add to cart and checkout?
  12. Jul 23, 2020 at 10:46 AM
    #312
    Tacospike
    Two Trucks
    You can piece part the entire kit for the same price. I also see White Maps in stock. Did you drop down the option for red or white? That out of stock description might be an old note
  13. Aug 11, 2020 at 9:34 PM
    #313
    Kohan21n
    Kohan21n A caffeine dependent life form - IG @dizzy.trd
    Nazareth, PA
    2016 DCSB MGM 6MT
    @MESO will you have any chrome delete kits for manual transmissions?
  14. Aug 16, 2020 at 8:13 PM
    #314
    supermario6582
    supermario6582 Active Member
    2017 White Tacoma TRD Sport
    Anybody got any leads on a red set of these?
  15. Oct 19, 2020 at 7:51 PM
    #315
    twolane
    twolane Well-Known Member
    DF
    Providence, RI
    2019 Cement
    Looking for a set of these in MGM.
    Anyone have a set they decided not to install and they'd like to sell?
  16. Feb 6, 2021 at 11:18 AM
    #316
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    They won't sit flush. It's made that way.
    Look at #308.
    Rainoffire and Frsh2df like this.
  17. Feb 6, 2021 at 11:25 AM
    #317
    scottstrong89
    scottstrong89 AhsokaTaco
    Carlsbad | CA
    2021 Tacoma SR5 2.7L DCSB Black (Sold 6-2-21)
    Bilstien 5100s- front 2.5inches Bilstien 5011s - rear extended HeadStrong OffRoad progressive AAL Manga flow muffler Aftermarket Powder-Coated Black Tip BFG KO2s- 265/70/17 Method Wheels Double Standard 17” Prinsu Cab Rack w/ Plano Rife Cases Yakima Awning Tacoma_Twins Paracord Handles TRD Pro Grille w/ Raptor Lights Laminx Fog Light Vinyl Yellow Me-So Customs Flip Fob Me-So Customs Gas Hole AJT Designs Emblem Overlay Black Me-So Customs Method Wheel Caps Screen ProTech 3 Piece Protector Kit Bumper Shells Bumper Caps Black tttacodan Bed Stiffeners TRD Pro Skid Plate TVD Vynil Decals Chrome Delete Hondo Garage Mounts w/ Ram Mounts RCI Adjustable 12” Bed Rack RotoPax Lox Mounts RotoPax WaterPax & Storage Pack Yakima Skyrise RTT WaterPort Shower Baja Born OffRoad Rock Sliders XBull Recovery Boards Al Off-road Trailgate Panel ataco4x4 Grille Emblem Desert Armor Ultra4 Ditch Light Pods Cali Raised LED 40” Light Bar Cali Raised OEM Style Switches
    Will the smooth ribs work with the Hondo Garage unholey mounts?
  18. Feb 6, 2021 at 11:58 AM
    #318
    DSRamsey13
    See #158.
    scottstrong89[QUOTED] likes this.
  19. Feb 6, 2021 at 12:56 PM
    #319
    scottstrong89
    Carlsbad | CA
    Thanks. That’s the old style though. But I’m sure itll work.
  20. Feb 6, 2021 at 2:11 PM
    #320
    indoomitable
    indoomitable Baby-steppin' down the stairs
    Texas
    2018 OR 4x4 DCSB
    Put these on a couple weekends ago, they are a great touch and much much better than the chrome. MGM is the perfect subtle change while the red gives a nice accent to the headunit/dash
