MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Aug 17, 2019 at 8:06 AM
    #3701
    PoorBoyzMoto212
    PoorBoyzMoto212 Member
    Dblank
    19 TRD Offroad
    2” leveling spacers, 1.5” wheel spacers in the front, 1.25” wheel spacers in the back
    Time to tear the door panels off my 19 now!
    SinCityTaco22 and KY_Rob like this.
  2. Aug 17, 2019 at 8:07 AM
    #3702
    ICU1
    ICU1 Well-Known Member
    It’s go time! Thanks Stew! One more mod added to the list.
    KY_Rob likes this.
  3. Aug 17, 2019 at 8:07 AM
    #3703
    photoguy190
    photoguy190 Well-Known Member
    James Goff
    Middle TN
    Made it this time!!!!!!!!!
  4. Aug 17, 2019 at 8:08 AM
    #3704
    aphillips916
    aphillips916 Well-Known Member
    Aaron
    Winchester, Kentucky
    2018 Cement TRD Sport
    Good idea, might as well if you’re gonna have the doors opened up!
    KY_Rob[QUOTED] likes this.
  5. Aug 17, 2019 at 8:09 AM
    #3705
    aphillips916
    Aaron
    Anyone have the limited ultimate turn signals? Does this effect the install in anyway?
    KY_Rob likes this.
  6. Aug 17, 2019 at 8:10 AM
    #3706
    birdieking33
    birdieking33 Well-Known Member
    Jon
    Lexington, SC
    2017 Toyota Tacoma Limited
    Would it be worth waiting on before I install my puddles and do it all at one time?
  7. Aug 17, 2019 at 8:10 AM
    #3707
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I’ve got them, and I’m thinking (hoping?) it’s not an issue.
  8. Aug 17, 2019 at 8:12 AM
    #3708
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    will not effect limited turns previously installed.
    Switch will be easy to install at any time.
    1)Pop A pillar panel off
    2)plug in new Extension harness
    3)drop wire down to cubby hole
    4)plug switch in
    the most work will be running the puddle harnesses through the door.
  9. Aug 17, 2019 at 8:12 AM
    #3709
    tacotongue
    tacotongue Well-Known Member
    San Francisco, CA
    19 DCSB TRD 4x4 OR
    #13838
    puddles and a taco bucket!
    woo hoo!
    birdieking33 and KY_Rob like this.
  10. Aug 17, 2019 at 8:13 AM
    #3710
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    Finally scored a set of these and got to use my coupon code from the turn signal mix up! Looking forward to the install! And just need a KC5 now.
    Rexus Ranger likes this.
  11. Aug 17, 2019 at 8:13 AM
    #3711
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Nope. They interface well
  12. Aug 17, 2019 at 8:14 AM
    #3712
    Skydvrr
    Nick
    YMH
    Black '17 OR
    But no kill switch, as mentioned.
  13. Aug 17, 2019 at 8:14 AM
    #3713
    xMaverickx
    Jeremy
    Will you be doing a run of switch panels for the cubby hole around the same time? Gonna need one of those for that switch.
  14. Aug 17, 2019 at 8:15 AM
    #3714
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    Correctamundo pal.
  15. Aug 17, 2019 at 8:15 AM
    #3715
    Rexus Ranger
    Rexus Ranger Well-Known A-Hole
    Albert
    Reno, NV
    2018 TRD Off-Road
    I thought I was the only one. Felt like I held on to that code for eternity. :D
    xMaverickx[QUOTED] likes this.
  16. Aug 17, 2019 at 8:16 AM
    #3716
    Thehighesttree
    Thehighesttree Active Member
    Benjamin
    2018 Cement TRD OR Manual
    Stoked I got some on the way! Along with some maps!
    KY_Rob likes this.
  17. Aug 17, 2019 at 8:22 AM
    #3717
    xMaverickx
    Jeremy
    I know right, I thought for sure it would be expired lol and the first time I punched it wrong and didn’t go through but found the email and got the right code with no issues.
    Rexus Ranger[QUOTED] likes this.
  18. Aug 17, 2019 at 8:24 AM
    #3718
    ICU1
    Stew, will you make available your custom
    Stew, will you make available your left side switch mod? Will it fit the new puddle switch?
  19. Aug 17, 2019 at 8:25 AM
    #3719
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Pretty sure he's modeling it after the short fat switches. Like the inverter power ones.
    MESO[OP] likes this.
  20. Aug 17, 2019 at 8:27 AM
    #3720
    Pat3002t
    Pat3002t Well-Known Member
    3rd gen SR 2.7 5MT
    Got em!
    TimC likes this.
