MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Aug 20, 2019 at 9:59 AM
    #3901
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Perfect!
  2. Aug 20, 2019 at 10:08 AM
    #3902
    obpmem
    obpmem Well-Known Member
    I think someone said its a large switch designed for the space below the cubby (left of the steering wheel). I have a M/T and the no clutch start button is there. I do have available space in the center panel (where the Qi charger is), will the puddle switch fit this size also? @MESO
  3. Aug 20, 2019 at 11:36 AM
    #3903
    TWTaco
    TWTaco Well-Known Member
    Dave
    When do you plan on installing?
    LivinOnEdge and cshrum like this.
  4. Aug 20, 2019 at 11:45 AM
    #3904
    Tacospike
    Two Trucks
    It’s a small switch per Meso. I was going to run an extension to my ECT slot since it’s hooked up to my shift knob now
    Frsh2df, FishnTx and obpmem[QUOTED] like this.
  5. Aug 20, 2019 at 12:13 PM
    #3905
    wirickc7
    wirickc7 Well-Known Member
    2016 white Tacoma try off-road
    Got my shipping notification, realizing I shipped to my old address. dam Apple Pay
  6. Aug 20, 2019 at 1:21 PM
    #3906
    J_Anthony_
    J_Anthony_ Well-Known Member
    RangerIsTheBestTruck.Duh.
    Naomi, Lana
    I’m thinking this weekend. I have zero experience with this stuff. So I know it’s going to take some time.
  7. Aug 20, 2019 at 4:59 PM
    #3907
    TRDtacomamr2
    TRDtacomamr2 Well-Known Member
    JOSH
    Vermont
    2016 trd tacoma sport 6 SPEED
    @MESO please tell me you give another release coming for the puddles. Please please.
  8. Aug 20, 2019 at 5:53 PM
    #3908
    oneup714
    oneup714 Well-Known Member
    All show no go Super White Tacoma TRD Mall Crawler
    Looks like you're in HB, I'm in Westminster and depending on the day and time I can help you out.
  9. Aug 20, 2019 at 6:33 PM
    #3909
    J_Anthony_
    Naomi, Lana
    I’ll shoot you a PM :cheers:
  10. Aug 20, 2019 at 6:37 PM
    #3910
    Tacospike
    Two Trucks
    With two of you doing each door. Should be a record time!
    Skydvrr, Georgeee28 and Inferno__Taco like this.
  11. Aug 20, 2019 at 6:43 PM
    #3911
    Thud
    Thud Active Member
    Atsugi-kichi, Kanagawa, Japan
    17' Barcelona Red Tacoma TRD Sport 4x4
    Prinsu Rack, FAB Fours Full guard Grille, LED Tail lights, LED Headlights, Hood light, Warn winch (N/I)
    No, Stew said it will be the smaller switch size. I have M/T as well and went with a simple replacement that can be redone to fit the switch sizes. (sorry no pics) I pulled the console off and the cubby. Cut a square blank from an old computer chassis, rounded it out with a belt sander to fit the entire top part of where cubby is/was, and dremmeled the hole for the switches. Drilled 4 holes to mount a bolt and nut to secure it, then threw in my existing switches. I'll ask my fam to take a pic if it's asked.
    obpmem[QUOTED] likes this.
  12. Aug 20, 2019 at 10:32 PM
    #3912
    Sleevez
    Sleevez Well-Known Member
    LA / Toronto
    2017 SW TRDPro, 2000 PinkTaco
    Do you know which wire(s) on the puddle lights side you will need to use to tap into the OEM harness?
  13. Aug 21, 2019 at 4:30 AM
    #3913
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    Post #6 on the thread below shows how he did it to make his bed lights work in conjunction with his cargo light/switch. I have not tried it yet, so I can’t say first hand.if you aren’t 100% sure, I would recommend just using Meso’s plug and play harness.
    https://www.tacomaworld.com/threads...light-bed-light-circuit.530874/#post-17086665
    Sleevez[QUOTED] likes this.
  14. Aug 21, 2019 at 4:35 AM
    #3914
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    Also seems to depend on what build of aftermarket power mirrors you get.
    Mine fit perfectly with my OEM covers.
  15. Aug 21, 2019 at 7:00 AM
    #3915
    derelique
    derelique Well-Known Member
    Derek
    2004 Tacoma
    Installed last night. Pretty cool!
    Brostjoe, lpfe42, Rainoffire and 6 others like this.
  16. Aug 21, 2019 at 8:12 AM
    #3916
    Sleevez
    LA / Toronto
    I have already installed the bed lights already, I just need to know which wire needed on the meso side.
    The post only mentions the bed lights setup.
  17. Aug 21, 2019 at 4:17 PM
    #3917
    El Taco Blanco
    Stock (for now)
    That post is all I have to go on. My puddles haven’t came in yet, so I haven’t gotten all into the install yet.
  18. Aug 21, 2019 at 5:16 PM
    #3918
    Brostjoe
    Brostjoe Well-Known Member
    British Columbia
    2017 Limited DCLB
    Attempting to keep up and read the thread. Obviously missed the last batch. Has he made any indication when the next wave will be produced?
  19. Aug 21, 2019 at 5:49 PM
    #3919
    rdpoe
    rdpoe #2WDFTW
    Central Kentucky
    2019 TRD OR DCLB (Sold), Honda Civic TRD PRO
    Installed mine just now. Pretty dope. The proximity sensing function makes me smile each time
    The installation was easy. The only challenges were from the truck, not the Meso kit.
    To get the harness through the door wire gland thing I pushed a long thin drill bit extension through, taped the harness to the extension and pulled it back through. Worked like a champ and was super easy.
    WHIT4K3R, birdieking33 and MESO[OP] like this.
  20. Aug 21, 2019 at 6:47 PM
    #3920
    birdieking33
    birdieking33 Well-Known Member
    Jon
    Lexington, SC
    2017 Toyota Tacoma Limited
    Got home from work this evening and guess what was waiting for me.
    May start on the install tomorrow but more likely gonna be Friday.
