MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Feb 20, 2020 at 4:10 PM
    #5181
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    There's a zip tie and a Christmas tree retention clip.
  2. Feb 20, 2020 at 6:40 PM
    #5182
    Bosco944
    Bosco944 Well-Known Member
    Todd
    2017 TRD Sport
    I will post the board when I seperate it, but changing the diode on a board is probably beyond my comfort!
  3. Feb 20, 2020 at 6:59 PM
    #5183
    SAPR53
    SAPR53 Well-Known Member
    2019 TRD Offroad
    King 2.5" Ext resi with compress adjust Front and Rear ICON RXT Leafs ICON Tubular Delta Joint UCAs Xenon HD LED Low Beam Swap Baja Sports Wide Cornering Fogs Interior LED AVS In-Channel Extang Solid Fold 2.0 Tonneau
    I’m still not clear on how the plug connects to the t harness. Can anyone break it down barney.
  4. Feb 20, 2020 at 7:08 PM
    #5184
    SuperBad
    SuperBad Well-Known Member
    Dallas, TX
    2017 MGM Tacoma OR DCSB
    Truck stuff
    Should be pretty simply unplug 1 connection in the Apillar plug in switch wiring harness in between the plug you just unplugged and done.
  5. Feb 20, 2020 at 7:23 PM
    #5185
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Pm sent
  6. Feb 20, 2020 at 9:21 PM
    #5186
    SAPR53
    2019 TRD Offroad
    Are you guys removing this plastic bracket to separate the plugs and stuff it down? If so how the f do u disconnect the plastic bracket from the two plugs.
    NickB likes this.
  7. Feb 20, 2020 at 9:24 PM
    #5187
    Skydvrr
    Nick
    YMH
    Black '17 OR
    Strange, that's on meso's harness? Does it slide down/off?
  8. Feb 20, 2020 at 9:28 PM
    #5188
    SAPR53
    2019 TRD Offroad
    That’s the plug I connected MESOs harness to it’s the oem plug with mesos harness. Sure doesn’t...
  9. Feb 20, 2020 at 11:18 PM
    #5189
    airmac_11
    airmac_11 Well-Known Member
    2019 Cement DCSB Premium/ Tech TRD 4x4 Sport
    After fighting with the OEM bracket and losing the fight- I decided to nuke it. In hindsight I probably should have asked like your doing now but the bracket was preventing me from stuffing the wiring down the “A” pillar hole. Space is at a premium with the puddles and the puddle switch in that pillar channel.
  10. Feb 21, 2020 at 3:33 AM
    #5190
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Typically they slide in parallel with a “latch” to keep it in place.
    To understand, look at the one you are installing (MESOs) for reference, it is meant to snap in the same place. At times I have had to use a jewelers screwdriver (flat/blade) to achieve success with this, but use what you have available, if a swift tug doesn’t dislodge it. REMEMBER: DO NOT PULL BY THE HARNESS/WIRES.
    Bradg93 likes this.
  11. Feb 21, 2020 at 6:19 AM
    #5191
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    Hey @MESO , when you say that the first version needs modification to get the switch to illuminate, are you talking about the original ones you sent out before production or the first big batch you had done? I bought mine during your first big release. And if I do have the version that needs modification for switch illumination, is there a harness I can buy to make this more plug and play? Thanks!
  12. Feb 21, 2020 at 6:24 AM
    #5192
    SuperBad
    Dallas, TX
    Truck stuff
    To tell which version you have you can check the harness that you installed(check quote below for details). Any modification that needs to be done it to the harness and not the truck wiring.
    Tommyb08[QUOTED] and Skydvrr like this.
  13. Feb 21, 2020 at 6:32 AM
    #5193
    Frsh2df
    @Tommyb08
    Tommyb08, Tacospike and SuperBad like this.
  14. Feb 21, 2020 at 7:17 AM
    #5194
    SAPR53
    2019 TRD Offroad
    yea I’m gonna try to get that latch dislodged again for both those plugs, little sh!t doesn’t want to pop.
    Tacospike likes this.
  15. Feb 21, 2020 at 7:42 AM
    #5195
    tacobelletx
    tacobelletx Well-Known Member
    TX
    '18 Sport ACLB
    Yeah, I couldn't get mine to budge at all (even used a small pick tool to try and help). Out of frustration, I ended up snipping it in half to split the two harnesses and then just snipped the christmas tree portion off the big one so it would sit flush. Then I just used felt tape for now to hold it in place so it wouldn't rattle.
    Maybe one day I'll find and order a single one from the 2016/2017s and use that to hold the Meso harness... but for now it works.
    SAPR53[QUOTED] and Tacospike like this.
  16. Feb 21, 2020 at 8:59 AM
    #5196
    CementTacoPA
    CementTacoPA Well-Known Member
    Nate
    Lancaster PA
    ‘19 Cement DCSB - Sold
    I had that issue and it ticked me off for a bit too. If you have a trim pick, use that to push up in the very middle of the bracket and plug. See pictures below. It seems like you can slide the plug up about an 1/8” and then it catches so you have to release the clip. Hope this helps!77427B50-369F-49B7-816D-2F5C7B227BE8.jpgimage.jpg
    TacoWdrd and SAPR53[QUOTED] like this.
  17. Feb 21, 2020 at 1:53 PM
    #5197
    HyTrojan
    HyTrojan Well-Known Member
    Jared
    South Louisiana
    2020 MGM Sport AT DCSB
    Nfab running boards, PapaRee Tune, T4R Pro SEMA rims
    Just got mine in the mail. Can't wait!
  18. Feb 21, 2020 at 1:59 PM
    #5198
    Jake.ski51
    Jake.ski51 Active Member
    Jake
    2020 Tacoma TRD offroad
    @MQQSE is this what you are thinking?
  19. Feb 22, 2020 at 10:48 AM
    #5199
    kecknj
    kecknj Well-Known Member
    Nick
    '19 TRD Off-Road
    @MESO I have a set of the ECT plugs I bought from you. They look like molex microblade, but I'm not certain. Can you recommend a crimping tool for these pins?
  20. Feb 22, 2020 at 4:16 PM
    #5200
    Bradg93
    Bradg93 Well-Known Member
    Port Hope, Ontario, Canada
    2020 TRD Sport DCLB Cement Grey
    FFA7AF59-FCC2-472C-9209-2590D0DB21F1.jpg E2B44054-43D1-4A1E-B494-593E6E33E6D8.jpg
    While I agree that it’s always best to be safe rather than sorry, I don’t think that cable was that much of a safety concern. Here are pictures of my truck with the OEM clip in its original state and with the meso harness. The Toyota clip is just as much in the way as his wire was. It looks like the airbag is higher up than where the wiring harnesses sit
