MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Feb 25, 2020 at 4:10 AM
    #5241
    db6598
    db6598 Well-Known Member
    NC
    I installed my puddle pod kit this past weekend. Not too difficult but give yourself plenty of time so you don't have to rush through it. Thanks to everyone who posted tips and pictures in this thread.
    bcgill and TimC like this.
  2. Feb 25, 2020 at 4:12 AM
    #5242
    db6598
    NC
    I had to do the same thing on my 2019. That smaller connector didn't have much slack in it either so it was a little tricky to get things situated in there but my A-pillar cover went back on without a bulge.
  3. Feb 25, 2020 at 4:37 PM
    #5243
    TacoWdrd
    TacoWdrd Well-Known Member
    Shane
    Ohio
    2019 MGM TRD OR
    Brought the truck in for maintenance and a tech asked if “the lights” were a dealer option? I said, “No they are a MESO option.”... and walked away. He looked very confused :notsure::rofl:
  4. Feb 25, 2020 at 4:53 PM
    #5244
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    That's what I strive for:headbang:
  5. Feb 25, 2020 at 6:45 PM
    #5245
    Bradg93
    Bradg93 Well-Known Member
    Port Hope, Ontario, Canada
    2020 TRD Sport DCLB Cement Grey
    @MESO those switches are beauty. Installation was super easy, can’t say enough good things about the work you do.
    PS you should look into doing an Anytime backup camera as I see a lot of people complaining about quality issues and inconsistencies between kits. Your quality is always top notch. But I know you’re very busy!
    MESO[OP] likes this.
  6. Feb 25, 2020 at 6:47 PM
    #5246
    kecknj
    kecknj Well-Known Member
    Nick
    '19 TRD Off-Road
    I would give meso my first born son for a meso-designed anytime backup/front/left/right/aux camera kit
  7. Feb 26, 2020 at 8:18 AM
    #5247
    Justin_Exploring
    Justin_Exploring Well-Known Member
    2019 BRM Tacoma TRD OR DCSB 4x4
    I second this. But I don't have any children... I offer MESO a sacrificial lamb in addition to kecknj's first born.
    kecknj[QUOTED] likes this.
  8. Feb 26, 2020 at 11:13 AM
    #5248
    TacoWdrd
    Shane
    Ohio
    2019 MGM TRD OR
    In the news tonight.... Crazy man kidnaps 64 children screaming, "MESO bestows sight upon the Taco!"
    kecknj and Justin_Exploring like this.
  9. Feb 27, 2020 at 9:06 AM
    #5249
    xMaverickx
    xMaverickx Well-Known Member
    Jeremy
    New Brunswick, Canada
    2016 MGM Limited V6 4X4 DCLB
    Have any of those people simply tried a different camera? I got one off Amazon for less than 40$ and it’s as good as my oem rear cam. I don’t have a controller for it yet and I just plugged it into my crux box to check the quality. I’ll probably just end up with the anytimebackupcamera switch and harness only option. Unless MESO designs something and then I’d most likely buy that lol.
  10. Feb 27, 2020 at 9:56 AM
    #5250
    Bradg93
    Yeah I just ordered the 2020 kit from R4T and I got the Natika cam off Amazon like most others have suggested
    @MESO the people have spoken! Let us know when your camera kit will hit the first production run haha
  11. Feb 27, 2020 at 11:53 AM
    #5251
    ICU1
    ICU1 Well-Known Member
    And Stew is thinking “It’s good to be the king.”
  12. Feb 27, 2020 at 12:16 PM
    #5252
    Blkdmax
    Blkdmax Well-Known Member
    Tennessee
    2017 DCSB 4X4 V6
    @MESO any clue when these will be back in stock?
  13. Mar 1, 2020 at 9:34 AM
    #5253
    Blakeng0118
    Blakeng0118 Well-Known Member
    Blake
    Tacoma, WA
    2019 Limited
    I have a rock lights/ courtesy lights set up with DSIM module and a ch4x4 switch. Any one know how i can hook up the puddle lights to same switch?
    @DSIM @MESO
  14. Mar 1, 2020 at 10:25 AM
    #5254
    OMGitsme
    OMGitsme Well-Known Member
    Sold
  15. Mar 1, 2020 at 10:26 AM
    #5255
    Blakeng0118
    Blake
    Tacoma, WA
    2019 Limited
    Yeah. But idk what wire from the Meso puddles to tap my switch to :(
  16. Mar 1, 2020 at 10:29 AM
    #5256
    OMGitsme
    Sold
    Click the link above
    Blakeng0118[QUOTED] likes this.
  17. Mar 1, 2020 at 2:20 PM
    #5257
    Poptarts010
    Poptarts010 Member
    Andrew
    Woodbury, NJ
    2018 Calvary Blue TRD Pro
    MESO Customs Interior Chrome Delete Kit including Start/4x4 Buttons (Black), Side Mirror Puddle Pods w/center console switch kit, Total Tail Stage 1 Kit, and Minimalist Key Fob (Cav Blue), Redline Tuning Hood QuickLIFT PLUS, Rubber volume knob rings (*Soon to be replaced *), Expedition Essentials Powered Dashboard Accessory Mount
    I may be going crazy after a 'lazy Sunday' installing all my lastest Meso Mods...but I think I'm having an issue with the switch or a connection somewhere:
    It works as intended with the Auto function when I open the doors and shuts off shortly after closing them. However, the Manual function doesn't seem to be working at all and I am not getting any backlight on the switch itself even though I purchased the newest harness that should have the pin included. I did double-check all the connections before closing up all the paneling.
    Note: I did have an issue midway through the build where some wires came out of their connector but I immediately noted where they came from and took my time making sure they went back in and stayed in place the remainder of the job.
    Does anyone have any ideas?
  18. Mar 1, 2020 at 3:43 PM
    #5258
    MESO
    State of Jefferson
    Sounds like you don’t have a proper ground to the switch. Double check where you bolted the black ground ring(coming off the switch) making sure it has a proper metal ground.
    Manual mode relies on that to be grounded(so it grounds the puddle lights) this turning them on. The backlight also requires the same ground because it’s only has +12V illumination coming in the main harness.
  19. Mar 1, 2020 at 5:10 PM
    #5259
    Bradg93
    Did you ever find one? I probably could but I live in Canada and shipping would probably be brutal
  20. Mar 1, 2020 at 7:07 PM
    #5260
    BoomBapClap
    BoomBapClap Well-Known Member
    Exact same thing happened to me while installing today. The on switch doesn’t work for me either but I also haven’t grounded it yet. I’ll finish setting it up tomorrow and report back.
