MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Mar 12, 2020 at 4:17 PM
    #5361
    TacoWdrd
    TacoWdrd Well-Known Member
    Shane
    Ohio
    2019 MGM TRD OR
    Have you bypassed the Y splitter and plugged each side directly into the T harness to see how it behaves? You may have said it but I've gotten lost in the post. If each side stays on which I'm assuming it would then it has to be in the T harness... maybe? Unless there is just something off with the factory wiring but you figure you would have a lighting issue somewhere else also. I guess compare every color to every pin location. This is a bitch of a job... sorry man.
  2. Mar 12, 2020 at 4:22 PM
    #5362
    Guccitaco
    Guccitaco TRDPro 2020 Army Green
    2020 AG trd pro
    little bit of here and a little bit of that...
    A9590C4D-5A1A-497A-B029-65FBAE683E69.jpg Meso came thru! But reading the post about 2020s. Hope my install is a breeze. Puddle lights.
    birdieking33 and Qauthority like this.
  3. Mar 12, 2020 at 5:07 PM
    #5363
    caribe makaira
    Caribbean, Puerto Rico
    Does the provided T-Harness you have include a wire in ALL cavities? I see in your pictures that there is an additional wire in cavity #10, next to the Yellow (ILE_DIMMING #11) that later models (at least the references I have) do not have.
  4. Mar 13, 2020 at 3:17 AM
    #5364
    robb1887
    robb1887 Well-Known Member
    Norfolk, VA
    2020 Limited
    Not yet. Its on the to-do list for this weekends troubleshooting
    95% sure all pins have passthrough wiring. I didnt have any luck trying to locate a 2020 wiring schematic. I wonder if @Jeff Lange could help with the wiring for this plug on a 2020 Limited?
  5. Mar 13, 2020 at 10:47 AM
    #5365
    drewmo
    drewmo Well-Known Member
    1995.5 4x4 Taco
    @robb1887 We're keeping on eye on this too and will replace anything that is wrong on the kit. Let us know as soon as you confirm what the issue is.
    corgimas and birdieking33 like this.
  6. Mar 13, 2020 at 10:52 AM
    #5366
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    In case y'all didn't notice... click on his logo to get 5% off MESO. Bookmark it like I did... so every time you order, you're saving 5%. It's not a lot, but every little bit helps. (might offset some shipping costs)
    corgimas and drewmo[QUOTED] like this.
  7. Mar 13, 2020 at 11:04 AM
    #5367
    caribe makaira
    Would you confirm that the T-harness has wires on all slots?
    Vehicle without Sliding Roof:
    2020 Limited from @robb1887 :
  8. Mar 13, 2020 at 11:21 AM
    #5368
    drewmo
    1995.5 4x4 Taco
    They do:
  9. Mar 13, 2020 at 11:48 AM
    #5369
    caribe makaira
    So the Y (JST) is a dual wire crimp coming from both sides of the IN1?
  10. Mar 13, 2020 at 11:56 AM
    #5370
    drewmo
    1995.5 4x4 Taco
    The split is coming from the female side of the plug only, which looks like the IN1 side like you have labeled. They are crimped into the pins together with the matching pass through wires.
  11. Mar 13, 2020 at 12:05 PM
    #5371
    caribe makaira
    :thumbsup:
    I've only read about the JST's wires coming loose or the wires miss located...
  12. Mar 13, 2020 at 1:56 PM
    #5372
    rberumen2
    rberumen2 Well-Known Member
    Ralph
    California
    2017 White Tacoma TRD Sport 4x4 DCSB
    Absolutely LOVEEEE the puddle lights. Just installed Them This morning. Pretty straight forward. Hardest part was pulling the wire through the grommet. Since I was doing that I did the chrome delete and installed the ect pro shift knob so I can use that button for the puddle lights.
    MESO[OP] and Blakeng0118 like this.
  13. Mar 13, 2020 at 2:19 PM
    #5373
    Blakeng0118
    Blakeng0118 Well-Known Member
    Blake
    Tacoma, WA
    2019 Limited
    Does anyone know how to make the puddles work with DSIM harness? I have the DSIM splitter. I wired the DSIM harness to a relay, a switch to turn on set of rock lights. I would like the switch to work with the puddles as well.
  14. Mar 13, 2020 at 2:24 PM
    #5374
    soapbox
    soapbox Active Member
    Jay
    MPLS
    2019 QS Tacoma TRD SP
    Weather tech floor mats, Factory door sill. 2 days in.lol
    I received mine yesterday. After fast S&H. I had them installed. With the assistance of a friend that has the patience. The rubber boots do nothing for my self a steam.
    look really good and practical at night. Not so much in the day though...;)
  15. Mar 13, 2020 at 3:00 PM
    #5375
    Tacospike
    Two Trucks
    you mean you have this?
    https://dsimsolutions.com/collections/all
    Blakeng0118[QUOTED] likes this.
  16. Mar 13, 2020 at 3:59 PM
    #5376
    Blakeng0118
    Blake
    Tacoma, WA
    2019 Limited
    Yes i have that. Connect to a set of rock lights, a relay and a CH4x4 switch. I installed the puddles. It works as intended but not coming on with the switch.
  17. Mar 13, 2020 at 4:38 PM
    #5377
    caribe makaira
    How do you have the Meso Puddles wired to the DSIM?
  18. Mar 13, 2020 at 5:03 PM
    #5378
    Blakeng0118
    Blake
    Tacoma, WA
    2019 Limited
    I just running each puddle wire to the splitter. Not sure if thats what youre asking
  19. Mar 13, 2020 at 5:07 PM
    #5379
    caribe makaira
    Well, I have to ask, how do you think they come ON after all doors are closed? The other lights/lamps have the switch to activate the relay. The MESO puddles do not...
    What color wire are the MESO puddles connected to?
    Edit:
    The splitter is before the DSIM module, correct? so after doors are closed no juice to the puddles, unless you open a door...
    RyanDCLB and Blakeng0118[QUOTED] like this.
  20. Mar 13, 2020 at 5:25 PM
    #5380
    Blakeng0118
    Blake
    Tacoma, WA
    2019 Limited
    This makes sense now. Thank you for explaining.
