MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Jun 1, 2020 at 8:52 AM
    #5701
    facefirst
    facefirst Well-Known Member
    Geoff
    Cleveland, OH
    2017 MGM TRD Off Road DCSB
    Order placed
  2. Jun 1, 2020 at 9:07 AM
    #5702
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    The small Meso switch is a rocker style, and allows for the lights to be overridden on, turned totally off, or function with the dome light. And you can use the Meso switch to control the puddle lights and the rock lights with the DSIM module. You could also wire in 2 Meso switches if you really wanted. One could control the rock lights (call it switch 2), and when switch 2 is placed in auto, the rock lights would then mirror the switch that controls the puddle lights (call it switch 1). This would allow for the rock lights to be turned on without the puddle lights pretty easily. It would open up a lot of options.
    Switch 1 AUTO, Switch 2 AUTO: Puddle lights and rock lights both work with the dome light.
    Switch 1 AUTO, Switch 2 ON: Puddle lights work with the dome light, rock lights are on.
    Switch 1 AUTO, Switch 2 OFF: Puddle lights work with the dome light, rock lights are off.
    Switch 1 ON, Switch 2 AUTO: Puddle lights are on, rock lights are on.
    Switch 1 ON, Switch 2 ON: Puddle lights are on, rock lights are on.
    Switch 1 ON, Switch 2 OFF: Puddle lights are on, rock lights are off.
    Switch 1 OFF, Switch 2 AUTO: Puddle lights are off, rock lights are off.
    Switch 1 OFF, Switch 2 ON: Puddle lights are off, rock lights are on.
    Switch 1 OFF, Switch 2 OFF: Puddle lights are off, rock lights are off.
    You could also swap the above behaviors by putting switch 2 before switch 1. Not sure how you would designate between the two switches in the cab though? Label wise. Sorry, kind of thinking out loud here as I type...
    If you didn't mind getting away from the plug and play, anytimebackupcamera.com sells a couple of rocker style switches that might work? I'd have to see exactly how they wire. They just need to be able to switch grounds as opposed to 12v+. https://www.anytimebackupcamera.com/products/a-b-light-switch-toyota
    As to what I am personally planning: I am going with a push on/off switch that will turn both puddle and rock lights on (my "rock" lights aren't really rock lights, underglow would probably be more specific for what I'm doing) whenever I want them on, regardless of the key position, and when that switch is off, they will work with the dome. I don't anticipate ever needing to turn them off totally, and I am very particular about things matching. Don't get me wrong, the Meso switch is absolutely top quality and looks great, but it doesn't match what I am trying to do. So I had ch4X4 custom make a switch which I then took the face off of to put it on an AirOnBoard switch so the lighting matches (like I said, I'm very particular, probably to a fault).
    As to how I am going to dim the lights on and off: https://www.amazon.com/dp/B07X3HNR93/ref=twister_B07X3GD8PN?_encoding=UTF8&psc=1 I will take the 12v+ output of the DSIM (yellow wire) and attach it to the Hi Trigger + (blue) wire. Then the lights themselves tie to the Oznium dimmer (both + and -). You can then adjust the timing (with the 8amp controller, I don't think you van with the 2amp one). Keep in mind, I am kind of an oddity when it comes to this stuff. I tend to spend a lot of my free time making things do things they weren't designed to do, so take all of this with that disclaimer in mind.... but here is a rough idea of what I'm planning:
    Its really rough, and the color scheme wont make sense out of context, so I would ignore that part. Also, I still need to verify the puddle pods +/- (VIF=verify in field). Basically, its a mess that would greatly benefit from the skills of someone like Caribe Makaira (sorry, not sure how to @ someone) who is way better at streamlining and diagraming than I am.
  3. Jun 1, 2020 at 10:30 AM
    #5703
    MaulMalls
    MaulMalls Well-Known Member
    Bay Area
    2020 TRD OR- Cement Grey
    On the puddle light install, there is a cable listed as “A” (for future products). Should I route this into the mirror where the puddle light is? Should it be through the mirror hole and into door area?
  4. Jun 1, 2020 at 10:30 AM
    #5704
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    leave it in the cavity of the puddle light. SO when sequential turn signals come out, you just have to run the wire up into the main mirror body.
  5. Jun 1, 2020 at 10:33 AM
    #5705
    MaulMalls
    Bay Area
    Thank you for the quick reply! I thought that was what it was for but just making sure!
  6. Jun 1, 2020 at 1:56 PM
    #5706
    mainjet
    mainjet Well-Known Member
    Alberta
    2019 Tacoma off road
    Ray 10s Diode dynamics Hidden Light bar Toyo AT2s
    How often do you release these ?
    I always seem to have bad timing (first world problems)
  7. Jun 1, 2020 at 4:49 PM
    #5707
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    Any advantage/disadvantage to go ahead and leave it in the main mirror body if we plan on getting the sequential turn signals? Not sure if it will save a step (or three) when we go to install the sequential turn signals.
  8. Jun 1, 2020 at 4:50 PM
    #5708
    MESO
    State of Jefferson
    Leaving it in the mirror you will not have to I’ll the door panel or unbolt mirror again
    BOMBS likes this.
  9. Jun 1, 2020 at 4:53 PM
    #5709
    DSRamsey13
    Awesome... then I'll be putting it in the main mirror body then! :thumbsup:
  10. Jun 1, 2020 at 6:13 PM
    #5710
    mOjO_Taco
    mOjO_Taco Well-Known Member
    Mesa, AZ
    2020 TRD 4X4 OR Cement
    None yet
    Just got my puddle kit today! Install coming up soon.
  11. Jun 2, 2020 at 9:01 AM
    #5711
    1TACOTONY
    1TACOTONY Well-Known Member
    Tony
    MICHIGAN
    2017 Inferno TRD Sport 4x4 M/T
    MISC. MODS WEBOOST overland cell booster Blacked out badges Black bedside decal Uptop overland alpha roof rack with inferno armortek and baja designs scenelighting EYECATCHER PRO Tacoma tailgate letter inserts Trd Pro grill with raptor lights(REMOVED) DB CUSTOMS Toyota halo grill with backlighting TRD color match grill badge Color matched Trd Pro shifter Tinted windows Front and Rear MBRP 3" side exit exhaust w tip OCD center console organizer Meso Customs Flip Fob Key Meso Customs blacked out climate control rings Meso Customs blacked out vent rings Meso Customs blacked out 4x4 ring Meso Customs coin organizer M/T Meso Customs blacked out steering wheel emblem overlay Meso Customs blacked out handle covers Meso Customs Overhead hex rack (sunroof model) KTJO4X4 HUD FOR TACOMA Trd pro skid plate Tufskinz glovebox insert ch4x4 custom switches w/ cubby panel Lil B's bed stiffeners with bottle opener Inferno Door sill guard inserts Rear passenger dual USB charge port Rear window switch relocation mod Taco Time plate frame AVS low profile in channel vent shades URD short throw shifter kit Cravenspeed Gauge mount JLT oil catch can N2 Designs remote start with smartphone module Trailer hitch step guard with locking pin Hondo garage unholy mount with ohnap magnetic mounts(driver and passenger side) Diamondback HD smooth bed cover Uptop Overland Diamondback truss rack system Ikamper Skycamp 3.0 mini with insulation liner Wolfbox G900 mirror and dashcam front and rear camera Seat jackers front and rear driver and passenger side Front seat jacker multi panel mounts driver and passenger side ////// (AWAITING ARRIVAL) None at this time (AWAITING INSTALL) Uptop overland rack lights dual function white and amber x8 /////// SUSPENSION COMPONENTS FRONT Fox 2.5 extended travel coilover remote resi with adjuster and added protection for the reservoir Sway bar relocation kit Spc adjustable uca (removed) Icon billet UCA Durobump bumpstops Runnin 4 Tacos lower control arm skids REAR Fox 2.0 extended travel remote resi with adjuster and Fox roost guards Toytec (Deaver)3 leaf progressive aal Durobump 4.25 bumpstops with Ubolt flip kit ///// WHEELS AND TIRES FN FX Pro matte black w import equipment center decal BFG KO2 285/70/17 ///// AUDIO Stinger Heigh10 10in multimedia display w/ tacoma flush mount integration kit and wireless AA adapter OEM Audio Reference 450Q w/ subwoofer Soundskin Pro sound deadening doors,panels,counsol and rear wall ///// LIGHTING Rigid Radiance+ Amber backlighting 30" Hidden Bumper Light Bar Rigid Radiance Scene pods with amber backlighting Morimoto XB Led projector Gen 2 Black headlights with sequential turn signal MESO Customs/ Morimoto led sequential tail lights Morimoto XB Led projector fog lights Meso Customs blacked out ultimate turn signals (REMOVED) Meso Customs blacked out ultimate v5 turn signals with white drl and sequential turn signal (INSTALLED) Meso customs puddle lights w switch TRD pro tail lights Mic tuning 2 bar triple row tailgate bar with brake,reverse and sequential turn VLed upgrade vanity lights Meso Customs ultimate map light Meso Customs dual brightness cab light Led upgrade turn,brake,side markers and plate lights (changed to meso customs headlight and taillights) Import equipment 3rd brake light cover Raptor grill lights (REMOVED WITH PRO GRILL) KTJO4X4 door handle lighting Yota mafia KC hilites v2 rock light 6 light kit with auto on feature UPTOP Overland Underhood lighting with Baja designs pods Baja designs rock lights with scenepods 2.0 for roof rack
    From reading your post I'm thinking you want the rock lights to be controlled and operate the same as the puddle pods. The kit I installed was all plug and play and I still have the option to control puddle pods and rock lights fully. So I can turn them all on at anytime,have them all on auto,all off,or one or the other. It was a very straightforward install and I'm very happy with the outcome. Is this similar to what your trying to achieve?
  12. Jun 2, 2020 at 9:07 AM
    #5712
    blitzkrieg3002
    blitzkrieg3002 Well-Known Member
    Rick
    California
    2019 Tacoma SR5 4x4
    pretty much. but I want the rock lights to fade on/off as well. i'm going to try @Puppypunter 's diagram with a aironboard switch.
  13. Jun 2, 2020 at 9:10 AM
    #5713
    1TACOTONY
    Tony
    MICHIGAN
    That sounds like it will look really clean and high class. Looking forward to seeing the full setup so please share the finished product pics :thumbsup:
  14. Jun 2, 2020 at 12:44 PM
    #5714
    caribe makaira
    Caribbean, Puerto Rico
    or better this:
    blitzkrieg3002 likes this.
  15. Jun 2, 2020 at 1:09 PM
    #5715
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    so if going this route no need for a dsim? You just use the negative trigger and connect that to the low Trigger on the dimmer?
  16. Jun 2, 2020 at 6:17 PM
    #5716
    SubaruTheTacoma
    SubaruTheTacoma SubaruTheTacoma
    Rhys
    USA
    2017 STI Off Road
    HELLA Horns BP-51 ARB Summit SCS Ray 10 And many many others
    Finally got my puddle lights done!
    Everything works greAt!
    @MESO is the gap on the driver side supposed to be that big or did I do something wrong? I only saw cutting instructions for the passenger side.
    thabks!
  17. Jun 2, 2020 at 6:23 PM
    #5717
    blitzkrieg3002
    Rick
    California
    2019 Tacoma SR5 4x4
    awesome! i appreciate it. I think i'm just gonna do the method and diagram that utilizes the spdt relay and a single push button to turn all lights on or auto.
  18. Jun 2, 2020 at 6:42 PM
    #5718
    Puppypunter
    Johnny
    2019 Black SR
    I knew Caribe Makaira could find a more efficient way. But the Oznium has three trigger, so don't use the low, use the GND trigger (the black wire). I am not positive how well that will work given the ground is PWM, but I'll do some bench testing. Some relays chatter when they are activated by a variable voltage, so not sure if the Oznium would do that or not. I'm pretty sure that is how the DSIM module gets around the issue is by using a capacitor. Kind of thinking out loud again.... Will have to do some testing. LEDs are pretty sensitive to voltage, so the chatter might cause them to strobe. That is, if it does chatter.
  19. Jun 2, 2020 at 7:06 PM
    #5719
    MESO
    State of Jefferson
    There shouldn’t be.. it’s been addressed. If you don’t mind taking a look on the back of the plastic pod itself. The revised ones should have a long support spine on the middle tab(see pic)
  20. Jun 2, 2020 at 7:16 PM
    #5720
    1TACOTONY
    Tony
    MICHIGAN
    Mine had a slight gap until bolted back to the truck. It caught me off guard because we know how great mesos work is so I just went ahead and continued and the fit and finish is perfect. Try test fitting it to your door and see if the gap closes up :thumbsup:
