MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Sep 9, 2020 at 3:20 PM
    #5941
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    Thank you brother. :thumbsup:
    Tacospike[QUOTED] likes this.
  2. Sep 9, 2020 at 9:09 PM
    #5942
    fezzy
    fezzy Well-Known Member
    Hawai'i
    2017 BLACK TRD OFFROAD DCSB M/T
    need help. domes are super dim. lights arent turning on. do i need a resistor?
  3. Sep 9, 2020 at 9:10 PM
    #5943
    fezzy
    Hawai'i
    if anyone can reply asap
  4. Sep 9, 2020 at 9:10 PM
    #5944
    fezzy
    Hawai'i
    or a relay
  5. Sep 9, 2020 at 9:12 PM
    #5945
    Puppypunter
    Puppypunter Well-Known Member
    Johnny
    2019 Black SR
    For the puddle lights? No
  6. Sep 9, 2020 at 9:13 PM
    #5946
    fezzy
    Hawai'i
    yeah. i also have the dsim module plugged in. switch has illumination but puddle lights arent working now
  7. Sep 9, 2020 at 9:13 PM
    #5947
    Puppypunter
    Johnny
    2019 Black SR
    There may be a wiring issue. Are the puddle lights dim as well? Actually, I'll PM you...
  8. Sep 9, 2020 at 9:14 PM
    #5948
    fezzy
    Hawai'i
    all lights was working. they were all dim. now maps and dome and pods arent working
  9. Sep 9, 2020 at 9:18 PM
    #5949
    fezzy
    Hawai'i
    fuse is blown. too much draw??
  10. Sep 10, 2020 at 2:32 AM
    #5950
    hanapaa98
    hanapaa98 New Member
    2002 Reg cab /2020 Tacoma double cab shortbed
    I think you gotta throw your truck away. Hope this helps
    fezzy likes this.
  11. Sep 10, 2020 at 2:38 AM
    #5951
    fezzy
    Hawai'i
    i threw em away, still not working. what now?
    hanapaa98 likes this.
  12. Sep 10, 2020 at 3:43 AM
    #5952
    DSRamsey13
    DSRamsey13 Well-Known Member
    '23 TRD Pro Solar Octane
    Center console organizer.
    Sorry to hear about your issues. Once you get it resolved, please post the solution on here so we can learn as well.
  13. Sep 10, 2020 at 7:36 AM
    #5953
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Double check there isn’t a pinched wire or short anywhere. At the A pillar you can leave 1 side plugged in at a time(pass or driver) and retest the functions.
    BOMBS likes this.
  14. Sep 10, 2020 at 3:09 PM
    #5954
    fezzy
    Hawai'i
    how does the lights come on without the switch? are they just gonna be always on?
  15. Sep 10, 2020 at 3:25 PM
    #5955
    TC_Mic
    TC_Mic Well-Known Member
    State of confusion, aka Flori-duh
    2017 Silver Sky 2x4 Limited
    AMP Powerstep, UC Flex, bed lights, Opt7 Tailgate bar, black tailgate lettering Pending: re-configure tail light,s custom storage pocket bags, pinch weld painting, blackout badges, ......
    Only if the key fob is in range of the truck. just like the interior lights
  16. Sep 10, 2020 at 3:25 PM
    #5956
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    They turn on and off when the door opens/closes.
    They also turn on with the Domes/Maps proximity illumination.
    TC_Mic likes this.
  17. Sep 10, 2020 at 3:30 PM
    #5957
    fezzy
    Hawai'i
    map and dome wont turn on in center position
  18. Sep 10, 2020 at 3:30 PM
    #5958
    fezzy
    Hawai'i
    if i lock. or unlock my doors
  19. Sep 10, 2020 at 3:31 PM
    #5959
    fezzy
    Hawai'i
    could this be my problem?
  20. Sep 10, 2020 at 3:45 PM
    #5960
    TC_Mic
    It sounds like it is definitely "A" problem. You seem to have struggled with the install.
    My best suggestion is to begin trouble shooting by first revert back to stock. Just disconnect battery, pull the A pillar remove the T-harness, plug the original connectors back together, reconnect the battery and see if everything works properly. IF not diagnose and fix the problem there.
    Then.... disconnect batt, reconnect T harness with only 1 puddle pod, reconnect batt, test if all is good try the other, if all works you are fixed. IF not try the one that worked again, then only the one that did not. If one is failed follow the wiring to try to find a fault. If any part is failed after it all works in stock config contact Meso let him know your order #, and what you have done to diagnose, and what you have found. He can help replace or diagnose from there.
    Sometimes we find odd conditions due to a single crossed, grounded or pinched wire. Gotta start by eliminating all the changes that caused the issue and work from there again.
    DSRamsey13 likes this.
