MESO Puddle Light build
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Jan 12, 2019.
  1. Jun 17, 2022 at 8:18 AM
    #6661
    CttAznRanger
    CttAznRanger Crazy NE Asian with the Cali Lean (temporary)
    Brandon
    Boston, MA
    2018 Tacoma TRD Sport
    I'm honestly not sure then. I personally haven't run in to this issue. The only thing I can suggest is to double check all the connections to make sure everything is tight, and compare your T-harness and connections to someone elses.
    Dkota-yota[QUOTED] likes this.
  2. Jun 17, 2022 at 8:21 AM
    #6662
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    Have you contacted meso? They are usually great with their customer service
  3. Jun 17, 2022 at 8:33 AM
    #6663
    Dkota-yota
    Dkota-yota Active Member
    Dakota
    St. Augustine, Florida
    2019 SR5 V6 DCSB
    No I haven’t, just trying to see if anyone else has seen this before or any ideas. Every connection seems to be seated well and it works perfectly, just as it’s supposed to so I don’t really see anything being wrong with them. Seems to be some kind of power issue.
  4. Jun 17, 2022 at 9:08 AM
    #6664
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    The fact they functioned like normal after you opened (and closed?) your door sounds like you may have nicked something while running through the boot. I would suggest holding the door switch in and see if wiggling the door boot around makes the lights illuminate. Could even try opening and closing the door while keeping the door switch depressed (tape perhaps) and watching the lights. You may need a second person to test.
    Toolndie7 likes this.
  5. Jun 17, 2022 at 9:20 AM
    #6665
    caribe makaira
    Caribbean, Puerto Rico
    Or Mirror cable channel also...:burp:
    ktbell444[QUOTED] likes this.
  6. Jun 23, 2022 at 8:49 PM
    #6666
    Punkface
    Punkface Well-Known Member
    Colorado
    2020 Tacoma TRD Off-Road DCSB 4x4
    Anyone still have their factory bottom mirror piece for the driver's side? Rock took mine off. Will pay.
    Edit: found
  7. Jun 27, 2022 at 8:34 AM
    #6667
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Hello everyone @MESO. I have the puddles with the switch. Does anybody know if will it eventually automatically shutoff? I might have left it on at the parking lot.
    And I don’t mean when the battery drained…thx.
  8. Jun 27, 2022 at 10:16 AM
    #6668
    Tacospike
    Two Trucks
    You mean you left it in the ON position?
  9. Jun 27, 2022 at 10:21 AM
    #6669
    MiTacoTRD
    N. Idaho
    Yup!
  10. Jun 27, 2022 at 10:23 AM
    #6670
    Tacospike
    Two Trucks
    I think it's going to stay on. Like leaving the DOME / MAPS on. :(
  11. Jun 27, 2022 at 10:27 AM
    #6671
    MiTacoTRD
    N. Idaho
    That’s what I thought. Good thing it’s LED. But I’m afraid it will over heat. I might have a friend that can check it out 15 hours later. I can unlock it remotely for her to turn it off. I can also monitor the batt via N2designs CL6 app.
    Tacospike[QUOTED] likes this.
  12. Jun 27, 2022 at 10:30 AM
    #6672
    MiTacoTRD
    N. Idaho
    Wait! The Domes/Maps turns off when left on.
  13. Jun 27, 2022 at 10:32 AM
    #6673
    Tacospike
    Two Trucks
    They will get hot, no sure if they will overheat? Good thing you can monitor it though
  14. Jun 27, 2022 at 10:33 AM
    #6674
    Tacospike
    Two Trucks
    But the puddle light switch is separate. They can work independently
    Edit: Maybe you had the puddle switch on 'door' / 'auto' and they turned off?
  15. Jun 27, 2022 at 10:33 AM
    #6675
    AndrewW
    AndrewW Well-Known Member
    2020 Or 4x4
    I’m having issues with my switch also. I contacted meso over a week ago with no reply. I’m starting to have second thoughts on his products.
  16. Jun 27, 2022 at 10:34 AM
    #6676
    MiTacoTRD
    N. Idaho
    Darn it!! Thx.
  17. Jun 27, 2022 at 10:37 AM
    #6677
    MiTacoTRD
    N. Idaho
    I’m certain I toggled/pushed that switch all the way up.
  18. Jun 27, 2022 at 10:38 AM
    #6678
    Tacospike
    Two Trucks
    Gotcha, yeah, they would be ON then
    MiTacoTRD[QUOTED] likes this.
  19. Jun 27, 2022 at 6:02 PM
    #6679
    MiTacoTRD
    N. Idaho
    I got my GF to turn off the puddle switch…Low and behold the puddle lights were OFF. And yes, they were in ON position. I guess it’s tied with an auto shut off system?? Or…they’ve just overheated and burned out. It’s over 90° in my area and I forgot to asked her to check if the puddle lights still works. I’ll just have to see for myself when I get home in a couple of days.
  20. Jun 27, 2022 at 7:02 PM
    #6680
    _FREEDOMTACO
    _FREEDOMTACO Brewmaster
    Greg
    2017 TRDOR DCSB 4x4 M/T
    Is anybody running these with the MESO switchback DRL turn signals and the vled footwell lights? So all 3 together? Is it pretty simple?
