MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Feb 22, 2019 at 9:36 AM
    #181
    Tacosrus
    Tacosrus Carpe Diem
    Northern California
    2018 Blazing Blue Pearl SR5 DCSB
    Switchup Tailight Mod.
  2. Feb 22, 2019 at 9:46 AM
    #182
    El Taco Blanco
    El Taco Blanco Well-Known Member
    2017 White Tacoma SR5 4x4 DCLB
    Stock (for now)
    Harness only release date?
  3. Feb 22, 2019 at 9:47 AM
    #183
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Good starter... if I was thinking that way, I would go with:
    Switchback Taillight Full Upgrade ... STFU
    or
    Switchback Taillight Full Upgrade - Factory Terminal Wiring ... STFU-FTW
  4. Feb 22, 2019 at 10:08 AM
    #184
    oly51
    oly51 Well-Known Member
    Gary
    S.E. MA
    2017 Tacoma, TRD Sport, MGM
    What about Turn And Tail And Stoplight System, TATASs?
  5. Feb 22, 2019 at 10:27 AM
    #185
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    What’s the update on the bulbs for the stage 2?
  6. Feb 22, 2019 at 10:35 AM
    #186
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    My stage two is showing shipped so maybe he had some on hand :fingerscrossed:
  7. Feb 22, 2019 at 11:10 AM
    #187
    Soul Surfer
    Soul Surfer Jimi Was Last Seen: Roam in’ Around…
    Jimi
    West Central Florida Coast
    ‘25 TRD OR/W-UpGrade Package.
    :popcorn: Subbed For Stage 1 Restock :spending:
  8. Feb 22, 2019 at 11:46 AM
    #188
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I tested another method for modifying stage 2 hole. HOT KNIFE
    PROS: less mess, tools readily available
    CONS: not as accurate cut like ultrasonic knife or step drill bit.
    The con isn't that bad really becasue all you are trying to do is enlarge the hole. It's a rough cut.. but doesn't matter because it will be hidden by the adapter and epoxy. I would almost suggest this method as you won't get any plastic shavings inside the light. But it's all up to you!
    Heat up the blade until it's red hot
    Start trimming the inside
    You will NOT be able to do the full trim in 1 pass. The blade cools down too fast. I was able to do it in 1/4 at a time.(reheat blade, continue)
    Trimmed. Again..it looks a little brutal but it will all be hidden.
    Like this!
    My VLED shipment arrives today, so I'm hoping to get ALL the stage 2's shipped today/tomorrow. Everything will be in the box except for the 4X 7443 red. If you really want, you can install the kit (just use the stock brake bulbs until the new ones arrive):D
    pinochle likes this.
  9. Feb 22, 2019 at 12:16 PM
    #189
    boywonder77
    boywonder77 Well-Known Member
    Bay Area
    2018 Tacoma Cement DBSB TRD Sport
    Thanks for sharing @mesojdm
    Do you think a regular grill lighter (like what you light candles with) would suffice or do we need a stronger type of lighter?
    Also, I recall in another post there being a small ridge near the breather cap that needs to be either cut or shaved down. I'm assuming this is still the case correct?
  10. Feb 22, 2019 at 12:18 PM
    #190
    Skydvrr
    Nick
    YMH
    Black '17 OR
    So u shipped all the harnesses? And shipping bulbs later? The adapter goes over the stock socket, over the OD, not the ID. Good to know. The cutting is just clearance for the bulb? No for the adapter eh?
  11. Feb 22, 2019 at 12:24 PM
    #191
    MESO
    State of Jefferson
    Yes, it’s a very small ridge that you can knock down with a blade. Once you have the light out and in hand you will see
    yes.. harnesses and switchback bulbs will be going out today.(worst case tomorrow)Everyone should have got tracking emailed. The adapter has a shoulder and fits INSIDE the hole you just enlarged. It’s pretty straight forward once you have it in hand. :)
    MrBrooks and Skydvrr[QUOTED] like this.
  12. Feb 22, 2019 at 2:07 PM
    #192
    Mastermindless
    Mastermindless Member
    Huck
    STL
    2017 TRD sport AC MT
    Stage 1 received, that was some fast shipping!
    MrBrooks likes this.
  13. Feb 22, 2019 at 3:42 PM
    #193
    DvS21
    DvS21 Well-Known Member
    It's getting there.
    I guess I’m going to have to sub for the v2.
  14. Feb 22, 2019 at 4:06 PM
    #194
    savethewheels
    savethewheels Well-Known Member
    Nashville, TN
    truck
    Stage 1 install tip —
    Only thing that gave me trouble was getting the switchback to seat and twist into place, I believe due to the new supple o-ring. I ended up swapping over the stock o-ring, and was able to get the switchback seated and twisted into place.
  15. Feb 22, 2019 at 4:09 PM
    #195
    morcheez26
    morcheez26 Well-Known Member
    Brian
    New Orleans
    18 trd sport
    Man where do you guys live that have gotten their kits already? Mine still says its in cali and i know thats not true :annoyed:
  16. Feb 22, 2019 at 4:11 PM
    #196
    NuTacoma18
    NuTacoma18 Well-Known Member
    Florida
    Tacoma DCSB TRD OR 4X4 MGM w/Tech Pkg.
    Good to know, thanks for heads up. Did you need to use the resistors?
  17. Feb 22, 2019 at 4:11 PM
    #197
    NuTacoma18
    Florida
    I’m in Florida and still waiting too, sucks....
  18. Feb 22, 2019 at 4:19 PM
    #198
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    Email subb'd :spending:
  19. Feb 22, 2019 at 4:28 PM
    #199
    Victory
    Victory Well-Known Member
    St. Pete, FL
    2016 White Tacoma TRD Off Road
    Yeah mine shows a label was made but USPS hasn’t received for shipping. I think this has happened before with Meso stuff I ordered. His USPS location seems to not scan every package.
  20. Feb 22, 2019 at 5:49 PM
    #200
    Mastermindless
    Huck
    STL
    St Louis
