MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Apr 16, 2019 at 12:33 AM
    #2021
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    Thanks for clearing that up
  2. Apr 16, 2019 at 6:55 AM
    #2022
    Frito
    Frito Well-Known Member
    I'm Illuminated ! :rolleyes:
  3. Apr 16, 2019 at 4:42 PM
    #2023
    bill8331
    bill8331 W9LSC
    bill
    central IN
    17 SR5 V6 4x4
    SCS F5, 5100, Kenwood-Kicker/Polk
    I love this upgrade. Its like HEY I`M TURNING/STOPPING! Should have been this way from the factory. Excellent job Meso!
  4. Apr 16, 2019 at 7:01 PM
    #2024
    TiHo
    TiHo Well-Known Member
    2018 TRD Sport
    Ok how is everyone mounting the resistors? The VHB tape doesn’t stay and I cleaned with alcohol too. Could I use just regular old 3M double side mounting tape or will that not work because they get warm?
  5. Apr 16, 2019 at 7:04 PM
    #2025
    bill8331
    bill8331 W9LSC
    bill
    central IN
    17 SR5 V6 4x4
    You shouldn't need the resistors, mine didn't.
  6. Apr 16, 2019 at 7:18 PM
    #2026
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    You can still install the resistors whether you need them or not correct ?
  7. Apr 16, 2019 at 7:22 PM
    #2027
    TiHo
    2018 TRD Sport
    Ok so installed the resistors and everything worked good so I thought I would leave them but I just took them out and everything still works perfectly. So I am going to leave them out and see how it goes. I also have the ultimate turns and led’s in the front turns as well.
    Inferno__Taco likes this.
  8. Apr 16, 2019 at 7:47 PM
    #2028
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    Not my pic but mounted in the same spot. Just used the double sided tape, it's not going anywhere.
  9. Apr 16, 2019 at 8:17 PM
    #2029
    Inferno__Taco
    Inferno__Taco Well-Known Member
    Georgia
    2016 DCSB 4x4 TRD Sport
    I tried with one installed as i did one tail light at a time for comparison pics. And my blinker wouldn't work nor did the indicator on the instrument cluster show i had the signal on. So i removed the resistor and everything worked normally. Installed the second tail light stage 2 kit without the resistor. and both operate normally. Unsure if my issue was because i only did one tail light at a time or not. Thought i blew a fuse at first since the indicator didn't even work.
  10. Apr 16, 2019 at 8:21 PM
    #2030
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    I always suggest installing the complete kit MINUS resistors. Drive around and test. If you DO end up needing them(small % do) it’s a few min job to pop the tails out and connect them.
    Inferno__Taco[QUOTED] likes this.
  11. Apr 16, 2019 at 8:23 PM
    #2031
    Inferno__Taco
    Georgia
    Thank you sir. After installing both without the resistors, everything tested normal and has been since the install.
    MESO[QUOTED][OP] likes this.
  12. Apr 16, 2019 at 10:19 PM
    #2032
    SLACKBOY
    Erich
    Washington State
    Noted and thanks for clarifying. I still am waiting on an available Stage 1 Kit as both batches sold out in no time.
  13. Apr 16, 2019 at 11:24 PM
    #2033
    baldbeardedtaco
    FL
    Just installed some triton v6 amber for the front to matchy matchy. It was weird when I went to test for hyper flash, nothing turned on. So I hopped out and rotated the adapter then tried again and hyper flash like crazy (maybe because I didn’t turn the truck off) but then I put it in drive and it didn’t. Ran it through different scenarios and nothing, returned it to park and tried again and it didn’t hyper flash this time.
    I don’t get it but so far stage2 total tails, v4 ultimate turns and v6 triton fronts don’t need any added resistors
    MGMSangTaco likes this.
  14. Apr 17, 2019 at 12:01 AM
    #2034
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    I got the stage 1 installed and automatically installed the resistors. Should i try it without them?
  15. Apr 17, 2019 at 5:03 AM
    #2035
    uploadadventure
    uploadadventure It’s all @ColoradoTJ’s fault
    Dixon, Mo
    2019 Cavalry Blue Tacoma TRD OR (sold) 05 Duramax
    I didn’t need them.
    But I did connect them because I didn’t want the connector end exposed to getting corrosion in the harness. I’ve see that happen all to much. Little bit of water and it’s a done deal.
  16. Apr 17, 2019 at 7:49 AM
    #2036
    TiHo
    2018 TRD Sport
    We need a cap to plug into the open socket to prevent that. @mesojdm ;):D:fingerscrossed:
  17. Apr 17, 2019 at 8:16 AM
    #2037
    boywonder77
    boywonder77 Well-Known Member
    Bay Area
    2018 Tacoma Cement DBSB TRD Sport
    Where did you guys get your cap at?
  18. Apr 17, 2019 at 8:28 AM
    #2038
    TiHo
    2018 TRD Sport
    We don’t have a cap either.
  19. Apr 17, 2019 at 9:20 AM
    #2039
    ShadyCoh
    ShadyCoh Well-Known Member
    Burnet, Tx
    that is what shrink wrap and electrical tape are for
    Abumarf, Frsh2df, TiHo and 1 other person like this.
  20. Apr 17, 2019 at 10:09 AM
    #2040
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Adhesive lined heat shrink. Cut like a 3/4" piece and over hang the heat shrink, over the connector. Recover the heat shrink, while it's still warm, pinch the part that's over hanging to seal it up.
    TiHo[QUOTED] likes this.
