MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Aug 13, 2019 at 9:13 AM
    #3261
    swils
    swils Well-Known Member
    Maryland
    2018 OR Blazing Blue, MT
    Maybe a stupid question, but how will we know if we need the resistor, will we risk frying something if we plug in without it?
  2. Aug 13, 2019 at 9:26 AM
    #3262
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    If your turn signal does not hyper-flash without the load resistor then you don't need it. If you get hyper-flash, then install the resistor. No damage done either way.
    Inferno__Taco and swils[QUOTED] like this.
  3. Aug 13, 2019 at 9:37 AM
    #3263
    The_albatross
    The_albatross Well-Known Member
    Dave
    Levittown, PA
    2019 quicksand TRD off-road
    LEDs are just diodes and don’t have much resistance at all, not like bulbs. It’ll hyperflash (flash fast) like if a turn signal bulb burned out because your truck thinks that one is out.
    swils likes this.
  4. Aug 13, 2019 at 9:37 AM
    #3264
    Mfairchild08
    Mfairchild08 Active Member
    Mark
    Tampa
    2016 Limited 4x4 Tac0ma
    I'm interested in the stage 2 but have a question. Do you have to have the stage 1 and then upgrade with stage 2 or is it just an upgrade of brightness on the OEM setup? I don't have the stage 1.
  5. Aug 13, 2019 at 9:47 AM
    #3265
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    AFAIK. Stage 2 is a stand-alone product, it's just BRIGHTER (than Stage 1) and requires slight modification to the tail lamp housing. Stage 1 is not required for a Stage 2 install.
  6. Aug 13, 2019 at 9:47 AM
    #3266
    DocT
    DocT Member
    2018 Tacoma, DCSB, TRD Off Road, Manual, Premium
    Pop n lock. XD Depot HIDs. Joying head unit. JL XD700/5 amp.
    With the stage two, after performing the cut, does that inherently damage the OEM bulb mount, and prevent it from being returned fully to stock? It is hard to tell from the video.
  7. Aug 13, 2019 at 9:47 AM
    #3267
    godzilla888
    godzilla888 Just a plain white T
    Paradise
    2017 Super White SR5 DCSB AT
    Stage 2 is a different kit, it has upgraded vled switchback bulbs for reverse/turn
    It will require modification of the tail light assembly (cutting a bigger hole), but it was so worth it imo
    Inferno__Taco likes this.
  8. Aug 13, 2019 at 9:49 AM
    #3268
    godzilla888
    Paradise
    Yea unfortunately you can't go back, you would need to buy a new tail light housing if you wanted to go back to stock
    DocT[QUOTED] likes this.
  9. Aug 13, 2019 at 9:50 AM
    #3269
    The_albatross
    Dave
    Levittown, PA
    Yes you’re physically cutting out the stock twist lock location for the oem bulb.
    godzilla888 likes this.
  10. Aug 13, 2019 at 10:01 AM
    #3270
    godzilla888
    Paradise
    Btw I have stage 2 , absolutely no regrets :thumbsup:
    Well maybe only regret is not buying a sport or 2018/19 housing with the black that I could mod instead of my sr5 chrome dazzle:rofl:
    KY_Rob and The_albatross like this.
  11. Aug 13, 2019 at 10:08 AM
    #3271
    THE_KiRRAx
    Tampa, Florida
    Keep looking mate, they pop up every now and then for cheap-ish.
  12. Aug 13, 2019 at 10:13 AM
    #3272
    Mfairchild08
    Mark
    Tampa
    Thanks for the info, Stage 2 purchased.
    godzilla888 and 509 buckeye like this.
  13. Aug 13, 2019 at 11:30 AM
    #3273
    KY_Rob
    KY_Rob Well-Known Member
    Rob
    North East Ohio
    2022 DCSB TRD-OR 6MT
    OEM: TRD Pro Grille & Garnish, TRD Pro Skid Plate, TRD Pro Rear Tail Lights, TRD Pro Shift Knob (MT), Tailgate Remote Lock, Black Chrome Exhaust Tip, Black Emblem Overlays, Bed Mat Vorra65 AC Drain Mod Kit FBC Harness Solutions (aka daveeasa) D-I-R Harness with Aux out Total Chaos Bed Stiffners Taco Garage Dashtop Multi-Mount MESO: Gashole, Total Tails Stg1, V5 Switchback Mirror Turn Signals, HitchPod + S1, Vent Rings AJT Designs: Radio Knobs, Door Handle Covers (Removed) Black Forest Industries Shift Knob for R8…using an adapter MountainHatch Tailgate Insert KTJO4x4 Drivers Side Grab Handle Cali Raised Catalytic Converter Shields BajaDesigns NextGen Squadron SAE Amber fogs Bilstein 6112 Front & 5160 Rear ICON Add-A-Leaf pack ICON Sway Bar Relocation Blocks ECGS Bushing 17” SEMA Gunmetal Gray Wheels with LT255/75R17 KO2’s Active Off-Road U-Bolt Flip Kit w/Timbren Bump Stops Redline Elite Hood Struts
    I’ll have a set of OEM TRD Pro tail lights for sale in the next week or so, if you’re interested. They have the clear over outer lenses with black instead of chrome on the interior.
  14. Aug 13, 2019 at 11:57 AM
    #3274
    #NEVERGIVEUP
    #NEVERGIVEUP Well-Known Member
    California
    2017 Quicksand DCSB TRD OR
    TBD
  15. Aug 13, 2019 at 2:33 PM
    #3275
    KY_Rob
    Rob
    North East Ohio
    Ah, got it! I have the Ultimate Turns, so I should be good to go! Thanks!
  16. Aug 13, 2019 at 2:48 PM
    #3276
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    So vleds has a sale going on right now- it’s a tier based discount based on amount… 25% max
    So I went ahead and splurged… v6 red extremes for the s2 brakes and v6 extreme ambers up front. The only thing missing will be the newer v6 extreme switchbacks that @MESO said was in the works. Then I’m done :rolleyes:
    Once I get them in I’ll have stage 2 brake leds for sale- would be an upgrade for the s1 users! And v6 ambers for the front
  17. Aug 13, 2019 at 3:52 PM
    #3277
    godzilla888
    Paradise
    The Triton adapters though...
    KY_Rob[QUOTED] likes this.
  18. Aug 13, 2019 at 4:09 PM
    #3278
    KY_Rob
    Rob
    North East Ohio
    The ones I’ll be selling will be completely factory. It’s a bit of a story how I’m ending up with 2 sets of OEM TRD Pro tails (My wife actually listens, but doesn’t pay much attention, so I’ll just leave it at that). It doesn’t look like that big of a deal to whittle out the inside lip of the reverse light hole...could be wrong. I’ll find out soon enough :D
  19. Aug 13, 2019 at 5:35 PM
    #3279
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    How much did those run ya? I might be interested in doing the same for my S2’s. My retrofits are fully blacked out with a smoked cover over my turn signal too so those ambers would be beneficial for sure.
  20. Aug 13, 2019 at 6:03 PM
    #3280
    CT18Tacoma
    CT18Tacoma Well-Known Member
    Ray
    2018 TRD Sport
    Ordered the S2’s today!
    Just installed the domes tonight. Bad ass improvement!
    Next, puddles...:spending:
    509 buckeye and Inferno__Taco like this.
