MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Sep 19, 2019 at 1:08 PM
    #3761
    KrnTaco08
    KrnTaco08 Well-Known Member
    LA
    2017 Taco
    Thanks man. Looks like the new stage 1s don’t come with resistors though.
    CygnusX191 likes this.
  2. Sep 19, 2019 at 2:12 PM
    #3762
    THE_KiRRAx
    THE_KiRRAx Well-Known Member
    Tampa, Florida
    2016 BBP Tacoma SR5 DCSB
    MESO does not include resistors from the get go as his testing showed most vehicles don't need them. If they are required for your specific case, just contact him, he'll get you sorted.
    Please note the resistor shown above is not the resistor you'll use with the new stage 1s, you'll use the large black resistor shown in the stage 2 picture. I still need to mount mine permanently, just iffy because I may get bed stiffeners so I don't want them to be in the way of the bolts
  3. Sep 19, 2019 at 5:02 PM
    #3763
    APynckel
    APynckel Well-Known Member
    2018 MGM Tacoma TRD OffRoad 4x4 DCSB
    Bakflip MX4 Tonneau Cover XenonDepot ExtremeHID w/ Phillips bulbs
    Got my 1.5's in today. Install was a BREEZE. Didn't even need instructions. Everything worked the first time too (didn't know if polarity might be an issue or not). Great product!
    @MESO Thank you for the wonderful product, yet again!
    CygnusX191 and MESO[OP] like this.
  4. Sep 20, 2019 at 5:27 AM
    #3764
    Taco_Coma
    Taco_Coma That's a lovely accent you have. New Jersey?
    South NJ
    2018 DCSB SR5
    3 bolts
  5. Sep 20, 2019 at 5:36 AM
    #3765
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    It is actually two. The third bolt does not secure the tail light assembly and does not have to be removed.
  6. Sep 20, 2019 at 12:54 PM
    #3766
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    4, if you want to do both sides :thumbsup:
  7. Sep 20, 2019 at 1:55 PM
    #3767
    Mountain2018
    Mountain2018 Well-Known Member
    Harpers Ferry/Leesburg VA
    2018 4x4 SB gray
    i think my truck may be the Unicorn on this install....As everyone noted install is a breeze and they look nice. Mine work as designed but have the hyper flash...when useing turns sitting, moving etc. No other issues and no worries as resistors will cure. Funny as I left them in since had a 25 mile drive with little traffic on side roads. Figured put regular bulbs back tonight. A state trooper was apparently a ways back and noticed when i made about only turn on this trip....he was a nice guy and just pulled next to me on shoulder at a light asking whats up with the yellow strobe for signals!! lol
  8. Sep 20, 2019 at 4:19 PM
    #3768
    Taco_Coma
    South NJ
    2018 DCSB SR5
    any way you could post a video? interested in seeing what the hyper flash looks like
  9. Sep 20, 2019 at 4:36 PM
    #3769
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    Instead of a steady (one-one thousand-two one thousand) common flashing speed, hyper flashing is much quicker (one-two-three-four) if you want to see it happen on a stock truck/set up just remove one of the flasher bulbs. The system will think one of the bulbs has blown and will alert you by hyper flashing....
    Mountain2018 and CygnusX191 like this.
  10. Sep 20, 2019 at 5:15 PM
    #3770
    THE_KiRRAx
    Tampa, Florida
    This should show the hyperflashing you requested. Just wait until the left turn signal activates.
  11. Sep 20, 2019 at 6:52 PM
    #3771
    Mountain2018
    2018 4x4 SB gray
    You are correct in the video is spot on for the hyperflash.
  12. Sep 20, 2019 at 10:22 PM
    #3772
    payrow
    Los Santos
    '18 DCSB Sport
    Just got my TTL-S1 today :thumbsup: Super quick and easy install! FYI - You only need to remove 2 (the upper and lower) bolts on the tail lamps. These things are @MESO all the way - SUPER BRIGHT :eek: I'm 110% satisfied and you will be too!!! This is how the taillights SHOULD have worked out of the factory...
    Tried uploading a video - gave up.
    CygnusX191, THE_KiRRAx and Quktic like this.
  13. Sep 21, 2019 at 12:00 PM
    #3773
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Update,
    It seems that some users are experiencing hyperflash when activating the turn signal(usually 1 side, could be both) STAGE 1. if that is the case, do not worry, just PM me and I'll send out a Resistor for you(they are VLED's and I will cover the cost) Also, I am finding out most every case will have the hyper flash WHILE in reverse. At first I thought it couldn't be tamed, but I have been activity working on a solution. Sent some resistors out to testers and it seems to fix the problem. So now I am working with my factory to include a plug and play resistor with all kits going forward. I want this to be as simple as possible installation wise, and also work like factory. So stay tuned!
    P.S MORE STAGE 2's IN STOCK
    Knapz, payrow, CygnusX191 and 5 others like this.
  14. Sep 21, 2019 at 12:02 PM
    #3774
    Tacospike
    Two Trucks
    I still don’t think I’ve ever used my blinker while in reverse in my life
    Kheiron and PapaRee like this.
  15. Sep 21, 2019 at 12:03 PM
    #3775
    MESO
    State of Jefferson
    I know, me either. But if I want to advertise this as OEM quality/functions I want it to be 100%
    yub, CygnusX191, payrow and 4 others like this.
  16. Sep 21, 2019 at 12:04 PM
    #3776
    PapaRee
    PapaRee Pro Tuner
    Kreg
    Prairieville, Louisiana
    2016 Black TRD Sport, Tuned, BHLM OEM LEDs
    GTS Dobinson's lift, 33"-Wildpeak Atw3-18x9 -6 Offset ,265/70/18 tires, Raceline Assault wheels, Backflip G2 bed cover, Magnaflow exhaust, Pro tail lights, Pro fog lights, Pro grille, Raptor grille lights, Predator side steps, RedLine Hood Struts, Toyota bedmat, tinted windows, Retrofitted-BHLM-Amber Halo-Amber DRL-HID headlights, LED Highbeams, LED Hood Scoop lightbar, LED hidden bumper lightbar, LED under hood light, LED Bed lights, LED license plate lights, Tacoma tailgate 3d letters, Tacoma glovebox 3D letters, removed air dam, Custom TRD Sport emblems, Pro Shift Knob with Meso ECT Stealth button, Meso LED dome and map lights, Meso V3 smoked mirror turn signals, Meso Stage 2 Tail lights, Meso Mirror Puddle lights, Meso KC-5 Brake/Cargo light, Meso center console bucket with OG lid, Tailgate PNP kit, Garage door opener button in overhead console, Meso Minimalist keyfobs, Matte black Pro hood decal, KTJO4x4 Led door handle LED lights, Pioneer 6x9 3 way front speakers, Rockford Fosgate 6.75' rear speakers, TacoTunes tweeters, AJT black vent rings, JDM Gas cap cover.
    Me neither!!
    Tacospike[QUOTED] likes this.
  17. Sep 21, 2019 at 12:06 PM
    #3777
    mlr69
    South Carolina
    Parallel parking, every time.
    TFly, Jessrin, killthehippies and 3 others like this.
  18. Sep 21, 2019 at 12:09 PM
    #3778
    Tacospike
    Two Trucks
    True. I guess I just haven’t that I can recall.
    Now saying this, inevitably I will next week probably
    CygnusX191 and mlr69[QUOTED] like this.
  19. Sep 21, 2019 at 12:09 PM
    #3779
    THE_KiRRAx
    Tampa, Florida
    That resistor solved all my hyperflash problems, even while reversing with signals, so chock that up as another successful test.
    Can't wait to see what you come up with for future buyers. Hell, can't wait for those flip fobs....grrrr.
  20. Sep 21, 2019 at 1:26 PM
    #3780
    Derrick2972
    Derrick2972 Well-Known Member
    2016 Toyota Tacoma SR5 4x4
    Finally done with my install. I recieved the harness about a week ago. But I started experiencing the hyperflash on the left turn signal and @MESO sent me a resistor. That fixed the first issue. Then I started having problems with the right turn signal flashing both white and amber when signaling to the right. Meso again went out of his way and sent over a replacement light. Then I noticed that my right signal was hyper flashing when in reverse. But my left signal was perfect because Meso provided the resistor. So to fix the right signal I called up VLeds and ordered another resistor to install. I didnt want to bother Meso anymore. He's helped out so much and provided more assistance than I expected. I honestly wouldn't mind paying out of pocket for the resistors. Meso has always provided top quality products. After a week, everything works perfectly and it was worth the wait. Hopefully Meso will wait a few weeks before he releases another product. Gives me time to save up some money again.
    K-Bear and CygnusX191 like this.
