MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Nov 16, 2019 at 7:19 AM
    #3961
    Burritoma
    Burritoma Well-Known Member
    Deep South
    2019 Quicksand SR5 V6 DCSB
    I am in for a stage 2 when back in stock. Will be Meso mod #4. Black Friday may kill me this year, but I will die with a cool truck.
  2. Nov 16, 2019 at 10:28 AM
    #3962
    mboberick
    mboberick Active Member
    Mark
    Tacoma 3rd Gen
    With a little patience and a lot of needle file work, the bulb is in. The modification was in fact a bit off-center. Pardon my ignorance, but what do I do with the extra single wire and quick connect that came with the kit?
  3. Nov 16, 2019 at 10:36 AM
    #3963
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Glad you got it figured out. The extra wire is not used.
    CygnusX191 and Inferno__Taco like this.
  4. Nov 17, 2019 at 10:12 AM
    #3964
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    @MESO or anyone, Got any side by side pic or vid comparison of reverse and signals between S1 and S2?
    dullpup likes this.
  5. Nov 17, 2019 at 10:24 AM
    #3965
    Tacospike
    Two Trucks
    Meso has some output comparisons between the two. Follow his quotes using he arrows, it’s back a little ways
    CygnusX191 likes this.
  6. Nov 17, 2019 at 10:55 AM
    #3966
    MiTacoTRD
    N. Idaho
    Thanks! Found it. You’re right, it’s in post #3131. @Tacospike. Thanks for a lesson on how to use that arrow! LOL
  7. Nov 18, 2019 at 7:17 PM
    #3967
    MAYNIAC
    MAYNIAC Well-Known Member
    Bay Area
    2018 TRD Sport DCLB
    @MESO
    One of my tail light bulbs is constantly on in the bright setting (when you press the brake pedal). This did not occur when I first installed it. Any tips on how to fix this?
  8. Nov 18, 2019 at 8:44 PM
    #3968
    ALI3N_123
    ALI3N_123 ( -_・)ᡕᠵ᠊ᡃ່࡚ࠢ࠘⸝່ࠡࠣ᠊߯᠆ࠣ࠘ᡁࠣ࠘᠊᠊ࠢ࠘
    Eric
    Austin, Texas
    2021 Silver TuRD Squirt DCSB 4x4 // 2008 Black Rusty Shitbox DCSB PreRunner
    Tacospike, dullpup, NGray and 7 others like this.
  9. Nov 19, 2019 at 6:14 AM
    #3969
    NGray
    NGray Active Member
    Nigel
    FL
    1988 BJ73, 2016 TRDOR MT
    Installed the stage 1 kit yesterday as well. Huge improvement and easy to install. The only issue with hyper flashing that I had was when the truck was in reverse and turn signals on, which in reality will probably never happen, but I tried every combination I could think of.
  10. Nov 19, 2019 at 7:07 AM
    #3970
    Joe.Dirt
    Joe.Dirt Well-Known Member
    Colorado
    '19 Cavalry Blue TRD Off Road DCLB
    So the hyperflashing is a real problem? I back out of my driveway all the time and use my turn signals so if it's a major issue that might be a hard stop for me.
  11. Nov 19, 2019 at 7:09 AM
    #3971
    payrow
    payrow Well-Known Member
    Los Santos
    '18 DCSB Sport
    Sounds like your pop n lock is activated by your reverse lights o_O
    ALI3N_123[QUOTED] and CygnusX191 like this.
  12. Nov 19, 2019 at 7:13 AM
    #3972
    NGray
    NGray Active Member
    Nigel
    FL
    He has resistors I believe that will cure that, it just doesn’t come with the kit anymore. I live on a slow street so I have a bad habit I guess for not using my signals when backing out.
  13. Nov 19, 2019 at 7:13 AM
    #3973
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    I mean, does it take 10 minutes for you to back out? If it's only a few seconds shouldn't be a huge deal
    1bad2k likes this.
  14. Nov 19, 2019 at 7:17 AM
    #3974
    Joe.Dirt
    Colorado
    I expect my vehicle to function in all situations. You never know when you'll need XYZ feature and I don't want something that's going to be partly jacked up. Especially when it's a safety feature.
    mikmabz and RyanDCLB like this.
  15. Nov 19, 2019 at 7:20 AM
    #3975
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Is hyperflash really "jacked up" though? It's just flashing faster than normal for the 0.00001% of the time that the average driver uses a turn signal while parking/backing up etc.
    And I believe there are resistors solutions here in the thread, if you want to check that option out.
    Also can't remember if the stage 2s avoid the reverse hyperflash or not lol
  16. Nov 19, 2019 at 7:34 AM
    #3976
    MiTacoTRD
    N. Idaho
  17. Nov 19, 2019 at 7:35 AM
    #3977
    NGray
    NGray Active Member
    Nigel
    FL
    I can email you a video if you want to see for yourself. Before installing I asked about the resistors and was informed it’s not needed for most people, but he has them if you need them.
    They are a huge improvement and look great.
  18. Nov 19, 2019 at 7:39 AM
    #3978
    Joe.Dirt
    Colorado
    I think it's hyperbolic to say it's an ureasonably small fraction of the time anybody would use it.
    I use it regularly.
    Call me perfectionist but it would drive me nuts knowing that it would happen even in weird scenarios.
    I guess it's a non issue since there's a solution though.
  19. Nov 19, 2019 at 7:43 AM
    #3979
    Joe.Dirt
    Colorado
  20. Nov 19, 2019 at 7:51 AM
    #3980
    ALI3N_123
    Eric
    Austin, Texas
    It's the power lock option for the tailgate and locks together with the doors. If I press unlock on the fob then the doors and the tail gate will unlock and vice versa. Shifting the truck into R or D will lock the doors and tailgate as well.
