MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Aug 8, 2020 at 8:49 AM
    #4861
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Probably not at this time. The amount of customers that would want that(or lack thereof) probably wouldn’t justify the added cost increase to add additional connectors. The good news is since my harness is removable, the customer could splice their own connector outside the car so you won’t alter the OEM wiring.
  2. Aug 8, 2020 at 10:01 AM
    #4862
    crazyfingers
    crazyfingers Soft Sweet But True
    Chuck
    Annapolis, MD.
    TRD Off-Road DCLB Quicksand
    TRD Pro 17' Rims With Goodyear Wrangler DuraTracs Toytec 3" Boss Aluma Series With OEM HD Leafs. With A GoFast Camper
    @MESO or anyone that could recommend where one that’s lacking and technical skills to find both of the plugs to make something so that one doesn’t have to tap into any wires at all.
    deusxanime likes this.
  3. Aug 8, 2020 at 10:03 AM
    #4863
    MESO
    State of Jefferson
    Something like this would be fine. Just tap the 2 wires into my total tail harness (ground - and brake +) then the other end you can make an extension that goes up to a camper shell light
    https://www.amazon.com/MUYI-Waterpr...s=3+pin+tyco+waterproof&qid=1596906145&sr=8-9
    Hiebster and CygnusX191 like this.
  4. Aug 8, 2020 at 10:30 AM
    #4864
    crazyfingers
    Chuck
    Annapolis, MD.
    @MESO thanks for the help and the information I do really appreciate it. I’m really trying to avoid tapping into any wires from your kit or the OEM ones. Once you go Tapping into the wires you void your warranty and the OEM warranty which I do not want to do. I’m going to get some of those plugs and see what I can come up with. If anyone has done something like this please chime in. Thanks again Meso!!!!!
    CygnusX191 likes this.
  5. Aug 8, 2020 at 12:23 PM
    #4865
    CygnusX191
    CygnusX191 Gangster of Boats
    Timm
    St. Louis, MO
    So. Many. Stickers.
    keep in mind that even if you do tap the OEM wires, the only warranty you void is on those specific wires and the subsequent lights behind them. Since you'll have MESO lights in there, that is already null.
    crazyfingers[QUOTED] likes this.
  6. Aug 8, 2020 at 7:25 PM
    #4866
    deusxanime
    deusxanime Well-Known Member
    MN
    2020 Cement OR DCSB V6 6MT 4x4 Prem+AdvTech+LED
    Since I'm probably going to get a topper myself here soon, I've been thinking about that as well. I hate cutting/splicing into my factory wiring! I was thinking of picking up a trailer light kit for Tacomas, like this one, and then you could just have the installers use the taillight T-harness/insert piece to splice into for the topper's third brake light. (Hopefully that makes sense, having hard time wording it for some reason.)
    Annoying to spend $60 just for that T-harness and throw the rest away basically, but not sure how easy it would be find just that T-harness by itself anywhere else. And if I'm already going to spend $2000+, what's another $60, right?!
  7. Aug 8, 2020 at 7:28 PM
    #4867
    MESO
    State of Jefferson
    Just splice into my harness. It’s cheaper hacking into the OEM and you can’t really void my warranty.
  8. Aug 8, 2020 at 8:36 PM
    #4868
    crazyfingers
    Chuck
    Annapolis, MD.
    Now that’s what I’m talking about.
    I knew there had to be a way to do it without cutting any wires.
    @deusxanime Thank a lot...
  9. Aug 8, 2020 at 9:00 PM
    #4869
    deusxanime
    MN
    NP, I understand not wanting to splice into factory wiring! I was racking my brain trying to figure out a way to have them be able to tap into the brake light without splicing and it hit me that trailer lights need that as well, so a trailer light kit would have a brake wire that could be tapped into. Then it was just a matter of finding one that is a plug-and-play style and would have the T-harnesses already built out.
    I'm going to install the OEM tailgate auto-lock kit also before I get the topper, so that they can splice into that to have the topper rear window lock/unlock with the key fob too. That way at worst it is just the ~$100 tailgate lock kit wiring that gets messed up and not the truck's factory wiring. Not sure if you were thinking of getting that installed as part of yours as well, but just in case it is a bonus.
    Need to get that done and then get my topper ordered soon! Summer is running out quickly and I want it all done by fall.
  10. Aug 10, 2020 at 2:39 AM
    #4870
    Hiebster
    Hiebster Well-Known Member
    Andrew
    Long Island, NY
    '19 TRD OFFROAD
    My 5 amp panel fuse keeps popping every time I go to turn on my lights. It’s the fuse responsible for the climate controls backlighting. I’m wondering if this has anything to do with the tail light kit.
  11. Aug 11, 2020 at 12:07 AM
    #4871
    Logan.spencer
    Logan.spencer Well-Known Member
    Logan
    Southern VT
    '18 TRD OR DCSB Cement Manual
    2018 TRD OR DCSB 6 Speed MT Magnaflow Catback CBI T3 Front bumper RCI Skids (front, trans, t-case) RCI Rear Bumper (custom swivel recovery points) Rocky Road SuperSliders ARE Overland cap with area lighting Rigid SRQ backup lights Rigid DSS ditch lights Baja Designes 20" single row Baja Designs squadron sport fogs Icon Stage 9 SwitchPros power system ...i may be forgetting something...
    @MESO any idea when more kits will be available??
  12. Aug 11, 2020 at 8:25 AM
    #4872
    TacomaGuy7878
    TacomaGuy7878 Mmmm....Tacos
    CO Mountains
    2020 AG Pro
    So I installed MESO puddle pods a couple months ago and thought I heard a fuse pop when I went to start my truck after install. Tried searching for what popped and could never find but everything seemed to work fine. I hardly ever drive my truck at night (especially now without going out to dinner or happy hour or anything) and noticed the climate control/stereo lights, and auto dim on the screen are not working. Was wondering what fuse made all this work. I’ll try and replace and report back:thumbsup:
  13. Aug 11, 2020 at 2:36 PM
    #4873
    JRLYON
    JRLYON Well-Known Member
    Portland, OR
    2020 Cement TRD Off Road DCSB
    KDMaxx Tuned Bilstein 6112/5160 set at 2” w/ 1.5” Icon AAL 2020 TRD Pro Shocks and Struts (no longer installed) 2020 TRD Pro 16" Wheels Goodyear Wrangler Duratrac 265/75/16 tires Alpharex LUXX Series LED Taillights Black/Red (no longer installed) 2020 TRD Pro Taillights TRD Performance Air Intake TRD Performance Exhaust TRD Front Skid Plate Tyger T3 Soft Fold Tonneau Cover TacoGarage Pro Grille w/OEM sensor garnish Taco Garage DSM w/ magnetic phone mount Runnin4Tacos Smoked Amber Grille Lights (CURRENTLY NOT INSTALLED) Runnin4tacos amber grille lights) Runnin4Tacos Lower Control Arm Skid Plates Katzkin Black Leather Interior with red stitching and TRD logo in seat back TRD Pro Shift Knob TRD Oil Cap TRD Radiator cap TRD Off-Road Special Tailgate badge JLT 3.0 Oil Separator Catch Can Demon Brackets w 3/4" red/black Autmatch D-Ring Shackles Black Emblems and Tailgate badge OEM Bed Lights OEM Predator Tube Steps AVS In Channel Window Visors MESO Total Tail Stage 1 MESO Ultimate Map Lights (Dual Color) (CURRENTLY NOT INSTALLED) MESO Ultimate Map Lights (White) MESO Ultimate Dome Light V2 (Dual Color) MESO Chrome Delete Kit Red MESO Customs Red Start/Stop Ring MESO Customs Red 4x4 Select Ring MESO Customs Red Start/Stop Button (Small Letters) MESO Customs V5 Ultimate Turn Signals (Reverse Sequential) MESO Customs TRD Stearing Wheel Emblem cover MESO Customs red door handle chrome delete (CURRENTLY NOT INSTALLED) MESO Customs black door handle chrome delete TVDVinylDecal red door sill protector letters TVDVinylDecal red glovebox letters Redline Tuning Hood Struts Diode Dynamics SS3 Pro Fog Lights (White) (CURRENTLY NOT INSTALLED)Diode Dynamics LED 194 HP5 Map Lights (CURRENTLY NOT INSTALLED) Diode Dynamics LED HP6 29mm Festoon Dome Light Bulb (CURRENTLY NOT INSTALLED) Diode Dynamics LED 28mm Fuse Vanity Bulbs Diode Dynamics LED 194 HP3 License Plate Bulbs Taco Vinyl TRD Grille Badge Black/Red Cupholderhero cupholder/door/pocket rubber liners Front Tinted Windows to match rear OEM tint OEM Tacoma Rubber Bed Mat OEM Tacoma Bed Extender Tacos4Cheap TRD Coin Box JDMCAR Glove Box Organizer Insert JDMCAR Center Console Organizer Insert CeramicPro 9h Lifetime Ceramic coating
  14. Aug 11, 2020 at 2:39 PM
    #4874
    Kairide
    Kairide Well-Known Member
    2020 White SR5
  15. Aug 11, 2020 at 2:43 PM
    #4875
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    Doh, I just spent my current truck money on getting struts put together and that coil hitch skid group buy.... well, it’s ok, I’m interested in seeing the stage 2 version 2!
    Cipher94 and CygnusX191 like this.
  16. Aug 12, 2020 at 4:14 AM
    #4876
    Hiebster
    Andrew
    Long Island, NY
    '19 TRD OFFROAD
    I just dug around last night and discovered that it is indeed the puddle pods causing the fuse to pop. It’s a small 5 amp fuse on the inside of the truck in the fuse box under the drivers side of the dash labeled “panel”. I’ve changed the fuse 20 times and every time I go to turn the Lights on it pops. It only started happening a week ago but i’ve had the pods installed for about 2 maybe 3 months.
  17. Aug 12, 2020 at 5:18 AM
    #4877
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    if you've had them installed for 2 or 3 months and it's only just now starting to pop fuses, then it ain't the puddle pods. You might have a wiring short somewhere or maybe some insulation got cracked or chewed up or got water in it. definitely worth looking into, but I have a feeling you're going to have to dig a little deeper. Electrically issues are never that simple :D
  18. Aug 12, 2020 at 5:37 AM
    #4878
    Hiebster
    Andrew
    Long Island, NY
    '19 TRD OFFROAD
    I tore the whole car apart last night. radio out, tail lights out, headlights disconnected, etc. and the only time the fuse pops is when the puddle pods are connected to power. Thought maybe the switch was bad so I took it out of the equation and nope. It only happens when the wiring harness for the puddle pods itself is plugged into the oem plug. If i go oem to oem the lights don’t work but no fuse pops. So thankfully it’s not the oem wire harness that’s bad. I don’t know why this only started happening out of the blue.
  19. Aug 12, 2020 at 5:42 AM
    #4879
    CygnusX191
    Timm
    St. Louis, MO
    So. Many. Stickers.
    Hmm... I was thinking since they had been in for several months and nothing popped that it couldn't be them. Is there any kind of moisture inside the puddle pods?
    Hiebster[QUOTED] likes this.
  20. Aug 12, 2020 at 5:53 AM
    #4880
    Hiebster
    Andrew
    Long Island, NY
    '19 TRD OFFROAD
    I didn’t check the lights themselves. I’ll have to do that. But it’s most certainly the puddle pods causing this issue.
    CygnusX191[QUOTED] likes this.
