MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Jan 31, 2021 at 5:53 PM
    #5121
    HyTrojan
    HyTrojan Well-Known Member
    Jared
    South Louisiana
    2020 MGM Sport AT DCSB
    Nfab running boards, PapaRee Tune, T4R Pro SEMA rims
    Just ordered a set from Tacomabeast. Cant wait to install.
  2. Feb 5, 2021 at 1:50 PM
    #5122
    rubiconjp
    rubiconjp Well-Known Member
    Austin TX
    @MESO any info on when this will be back in stock? Thanks.
    CygnusX191 likes this.
  3. Feb 5, 2021 at 7:46 PM
    #5123
    Tacospike
    Two Trucks
    They were available from his vendors?? S1
  4. Feb 6, 2021 at 7:07 PM
    #5124
    5nahalf
    5nahalf I build dumb things
    Erik
    Minnesota
    2018 Inferno Longbed
    So I just ran into something goofy with my total tails and my remote start.
    Its -8 degrees out, so I hit the lock button 3 times to start the truck. I noticed out the window that when the lights flashed the first time they were white, then flashed amber the rest of the times.
    When we went out to the truck, I put it in reverse and I noticed that no reverse lights were on! After getting home, I parked, went inside. I went back out with hat and gloved to try to figure out why the reverse lights didnt work... I put it in reverse and only the left side was working, so park, then reverse again and now just the right side was working.... it kept switching sides. I turned on the hazards, then both lights worked again.
    So, if you ever have one or both of your reverse lights not work, just hit the 4 way flashers while in reverse and it should fix it.
    MiTacoTRD likes this.
  5. Feb 6, 2021 at 7:35 PM
    #5125
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Ghost in the machine or Gremlins...
  6. Feb 8, 2021 at 8:57 PM
    #5126
    jaymz25
    jaymz25 Well-Known Member
    Edward
    2020 Midnight Black Metallic Tacoma TRD Pro
    @MESO can i request for a total tail load resistors for hyperflashing issues? i did request one on the website a while back. you probably haven't got the chance to read it. thank you so much
  7. Feb 8, 2021 at 9:11 PM
    #5127
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    More Stage 1’s are in production. Little slow due to one of the components being hard to get.
    Stage 2’s are still waiting for finalized switchback bulb. It’s tough getting as much light from a Triton V6 into a smaller 921 bulb size. Size does matter...
    We try and stay on top of tickets, but sometimes they can slip past. PM me your order number, I’ll get you out a set
    Thanks for pointing this out! I’ve tested them in cold temps just probably not as cold as that. I’ll look into this negative temperature scenario.
    DirtyDan, rubiconjp and CygnusX191 like this.
  8. Feb 8, 2021 at 10:18 PM
    #5128
    5nahalf
    Erik
    Minnesota
    I actually think I figured out the cause, its not the cold, but rather the cold killed my battery, so there is not enough power for my 4 ways to turn on right when I unlock the truck. Its happened a few times now, and each time I have had it do it, I have had to jump start the truck. We got 10 more days of below zero temps, but Im going into the dealer wed to get a new battery installed. I'll keep you updated with what it does after I get the new battery.
    CygnusX191 and MESO[QUOTED][OP] like this.
  9. Feb 8, 2021 at 10:31 PM
    #5129
    jaymz25
    Edward
    Thank uou so much @MESO pm incoming.
  10. Feb 9, 2021 at 2:58 PM
    #5130
    Paddtac20
    Paddtac20 Well-Known Member
    Terry
    Iowa
    2020 Limited Quick Sand
    Stage 1s shipped today from runnin4tacos. Hope more Meso dome lights are available soon. The new Meso map lights map lights really make a difference
  11. Feb 15, 2021 at 5:06 AM
    #5131
    Skenderbeu
    Skenderbeu Well-Known Member
    2016 Tacoma
    I installed stage one the other day and I am getting flickering. Where can I purchase the resistors. Thank you
  12. Feb 15, 2021 at 5:12 AM
    #5132
    jmm2000
    jmm2000 New Member
  13. Feb 15, 2021 at 6:08 AM
    #5133
    Paddtac20
    Terry
    Iowa
    Anxious to get mine installed but highs still -0 here. Is there any evidence on certain years more prone to flickering? I’ve got a 20
  14. Feb 15, 2021 at 1:34 PM
    #5134
    Skenderbeu
    2016 Tacoma
  15. Feb 15, 2021 at 1:36 PM
    #5135
    Skenderbeu
    2016 Tacoma
    I have a 2016 and installed this the other day . For some reason only the right side is flickering
  16. Feb 15, 2021 at 1:54 PM
    #5136
    Paddtac20
    Terry
    Iowa
    Guess I won’t know until they’re installed.
  17. Feb 16, 2021 at 5:09 AM
    #5137
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    Correct.
    TheCochese and CygnusX191 like this.
  18. Feb 17, 2021 at 4:52 PM
    #5138
    5nahalf
    Erik
    Minnesota
    @MESO So I did some more testing after getting a new battery, and the temps getting above zero. The only time I have a reverse light out seems to be when I use the remote start. Something about flashing the hazards fast (3 click to start) is causing one or both of the reverse lights to not turn on. I can reset them by hitting the hazard switch while in reverse and they all work just as normal.
  19. Feb 17, 2021 at 8:24 PM
    #5139
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    I think I had this (or something similar) happen I believe way back but i can’t confirm specifics. Originally no resistors and no hyper then a random glitch of some sort that self healed after hazards. I think I changed my side mirror turns shortly after which then required me to add resistors.
    but I havent had a glitch since but also can’t confirm a fix being there was other variables. Not even sure if a resistor would make sense in your situation but maybe worth a shot?
  20. Feb 18, 2021 at 10:53 PM
    #5140
    JRLYON
    JRLYON Well-Known Member
    Portland, OR
    2020 Cement TRD Off Road DCSB
    KDMaxx Tuned Bilstein 6112/5160 set at 2” w/ 1.5” Icon AAL 2020 TRD Pro Shocks and Struts (no longer installed) 2020 TRD Pro 16" Wheels Goodyear Wrangler Duratrac 265/75/16 tires Alpharex LUXX Series LED Taillights Black/Red (no longer installed) 2020 TRD Pro Taillights TRD Performance Air Intake TRD Performance Exhaust TRD Front Skid Plate Tyger T3 Soft Fold Tonneau Cover TacoGarage Pro Grille w/OEM sensor garnish Taco Garage DSM w/ magnetic phone mount Runnin4Tacos Smoked Amber Grille Lights (CURRENTLY NOT INSTALLED) Runnin4tacos amber grille lights) Runnin4Tacos Lower Control Arm Skid Plates Katzkin Black Leather Interior with red stitching and TRD logo in seat back TRD Pro Shift Knob TRD Oil Cap TRD Radiator cap TRD Off-Road Special Tailgate badge JLT 3.0 Oil Separator Catch Can Demon Brackets w 3/4" red/black Autmatch D-Ring Shackles Black Emblems and Tailgate badge OEM Bed Lights OEM Predator Tube Steps AVS In Channel Window Visors MESO Total Tail Stage 1 MESO Ultimate Map Lights (Dual Color) (CURRENTLY NOT INSTALLED) MESO Ultimate Map Lights (White) MESO Ultimate Dome Light V2 (Dual Color) MESO Chrome Delete Kit Red MESO Customs Red Start/Stop Ring MESO Customs Red 4x4 Select Ring MESO Customs Red Start/Stop Button (Small Letters) MESO Customs V5 Ultimate Turn Signals (Reverse Sequential) MESO Customs TRD Stearing Wheel Emblem cover MESO Customs red door handle chrome delete (CURRENTLY NOT INSTALLED) MESO Customs black door handle chrome delete TVDVinylDecal red door sill protector letters TVDVinylDecal red glovebox letters Redline Tuning Hood Struts Diode Dynamics SS3 Pro Fog Lights (White) (CURRENTLY NOT INSTALLED)Diode Dynamics LED 194 HP5 Map Lights (CURRENTLY NOT INSTALLED) Diode Dynamics LED HP6 29mm Festoon Dome Light Bulb (CURRENTLY NOT INSTALLED) Diode Dynamics LED 28mm Fuse Vanity Bulbs Diode Dynamics LED 194 HP3 License Plate Bulbs Taco Vinyl TRD Grille Badge Black/Red Cupholderhero cupholder/door/pocket rubber liners Front Tinted Windows to match rear OEM tint OEM Tacoma Rubber Bed Mat OEM Tacoma Bed Extender Tacos4Cheap TRD Coin Box JDMCAR Glove Box Organizer Insert JDMCAR Center Console Organizer Insert CeramicPro 9h Lifetime Ceramic coating
    Truck went into shop after getting rear ended. Taillights need to be replaced and I forgot to remove my total tail kit smh. They're gonna wonder what the hell the extra wires are and take em off im sure
