MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. May 10, 2021 at 7:28 AM
    #5161
    mistareeman
    mistareeman Well-Known Member
    Your Mom
    2019 ORDCSBMT4x4
  2. May 10, 2021 at 7:30 AM
    #5162
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    Try the form perhaps? I believe it feeds a ticketing system so they can keep organized and track things.
  3. May 10, 2021 at 9:39 AM
    #5163
    mistareeman
    Your Mom
    2019 ORDCSBMT4x4
    Great advice. Done :)
    CygnusX191 likes this.
  4. May 10, 2021 at 9:44 AM
    #5164
    Loan Wolve
    Loan Wolve ‘18 DCSB OR 4x4
    San Diego
    Cement ‘18 OR 4x4
    Loving my Stage 1 tails, but I get hyperflash when going into reverse (every time). Do I need to get resisters or something? Anyone have a good/fast solution?
    CygnusX191 and mistareeman like this.
  5. May 10, 2021 at 9:46 AM
    #5165
    HelloFelix
    HelloFelix Well-Known Member
    Felix
    Las Vegas
    2017 MGM 4x4 OR Tacoma
    No solution . Per meso customs .
  6. May 10, 2021 at 9:54 AM
    #5166
    Tacospike
    Two Trucks
    Total Tail Load Resistors – MESO CUSTOMS LLC
  7. May 10, 2021 at 9:57 AM
    #5167
    daveeasa
    David
    PNW
    And switchback v5's if they ever come out of unobtanium status. I caved and got $50 Amazon cheapie sequential which are better than the chrome stuff. Still sort of holding off on doing puddles in the hope that the v5's are out so I can be one and done with boot wiring? Not sure exactly how it's all meant to connect and not sure I'm willing to stuff another wire through the firewall just for DRL.
  8. May 10, 2021 at 10:09 AM
    #5168
    Loan Wolve
    San Diego
    Cement ‘18 OR 4x4
    CygnusX191 and Tacospike[QUOTED] like this.
  9. May 10, 2021 at 10:18 AM
    #5169
    Tacospike
    Two Trucks
    Here is my understanding and maybe what I think you're asking about?
    With V1 puddles it will have to wired through the firewall and door boot for the factory DRL function with a headlight DRL harness. Same wiring if puddles are not installed.
    V2 Puddles have the pig tail for the DRL which will be on also long as the truck is on, no turning them off.
    Is that what you meant by how it's connected?
  10. May 10, 2021 at 10:20 AM
    #5170
    daveeasa
    David
    PNW
    I think with v2's the DRL can honor the stalk switch _if_ a feed is run from DRL (at the headlight) through the firewall and into the 4-pin, then supplied into the harness? Otherwise it's an "always on" situation?
  11. May 10, 2021 at 10:32 AM
    #5171
    Tacospike
    Two Trucks
    Below are some quotes from MESO. My assumption is that the V2's do not honor the stalk switch, but re-reading it wasn't clear with the puddle harness or maybe I read something in a different thread of his about the function of the V2 puddles, but I can't find it. I want to say the V2 puddles did not honor the stalk switch and always on, I could be wrong.
    Just to give an overall update and some background on the email I sent out....
    I know the V5’s have been a long journey. Many factors have contributed to it’s delay. When this project first started a long long time ago I was doing the full design myself(I.e circuit boards, led layout, wiring, optics, plastics, etc). They ended up getting neglected last year as new projects hit my desk and took priority. Then throw COVID in the mix which screwed up some of my supply for components.
    Fast forward to mid/late 2020 and I was fortunate enough to hook up with Morimoto to help bring this project to completion. Rebooted the V5 and we ended up throwing all original designs out the window. Testing a bunch of different prototypes and ultimately settling on a final design which I am pretty stoked on. (Both function and output).
    So where does it stand now?? As I mentioned this is a collaboration with MESO + MORIMOTO. I am supplying all the plastics, outside lens, etc. as they are my molds...the same as the ultimate turn signals(although there are some slight changes in the mold for the extra wires which most customers won’t even notice).
    Then the plastics get shipped to Morimoto where they are producing and assembling all the internal components. There will be TWO VERSIONS available on the V5’s.
    1) WHITE DRL / AMBER TURN
    2) AMBER DRL / AMBER TURN
    As much as I wanted the white/amber to be user configurable and switch to amber/amber it just wasn’t possible and required a new specific led board. Not a big deal, just 2 different SKUS to stock.
    At this time, the plastics have all been produced and Morimoto is assembling them as we speak.
    The reason for the email asking what headlights you have is I am taking these 1 step further and including a full PnP wiring kit for the DRL to work correctly. Whatever headlights you “upgraded” to whether it be OEM 2020 LED(with adapter harness), Morimoto, Alphrex, etc. doesn’t matter. All that matters is is what connector your truck came with since my T harness is going to be plugging into your STOCK DRL CONNECTOR behind the headlight. 16-20 are the typical 4 pin connector, 2020+ OEM LED use a 6 pin connector. Now you are probably asking... what about my puddle pods that are prewired?! Yes.. they will still work and you can wire the V5 to the unused 2 pin plug next to the puddle pod. *HOWEVER* the DRL will turn ON/OFF with the truck IGNITION only. For most people this is fine. But if you want the mirror signals to be controlled with the DRL switch on the steering column(like the headlights) unfortunately this circuit/wiring is not available in the A-pillar...which is where the puddles are tapped off. That will require you to run a new line into the engine bay and use the T harness behind the headlights. Hope this makes sense feel free to ask me any questions
    DRL harnesses with be included with all V5 kits. I was just trying to get a ratio of how many halogen vs OEM LED vehicles everyone has as I am starting on the production of said harnesses.
    The V5 DRL will mimic the stock headlight DRL. Daylight= full brightness. Then when you turn on headlights/parking the signals will dim just like the headlight DRLS. Essentially we are tapping off the headlight connector in the engine bay for TWO different signals; DRL(bright), HEADLIGHT(dim). Hope this makes sense.
  12. May 10, 2021 at 10:35 AM
    #5172
    daveeasa
    David
    PNW
    Yeah, I read that as, with DRL harness and wire through the firewall, stalk switch DRL on/off is honored (which is the only way I'd want it). Gotta have some way to creep up on people in the dark right?
    But this discussion probably belongs in the mirror turn thread now, rather than total tails.
    CygnusX191 and Tacospike like this.
  13. May 14, 2021 at 11:17 AM
    #5173
    mistareeman
    Your Mom
    2019 ORDCSBMT4x4
    Shoutout to @MESO - contacted as mentioned by @daveeasa via the interwebs. They contacted me back and I've been able to purchase a replacement bulb (out of warranty). The replacement was a reasonable price and they were fast in their reply. Highly recommend MESO.
    THANKS!
    CygnusX191 and daveeasa like this.
  14. May 14, 2021 at 11:26 AM
    #5174
    HelloFelix
    Felix
    Las Vegas
    hopefully replacement bulbs will be an item on meso’s website.
  15. May 14, 2021 at 7:06 PM
    #5175
    jjrek9
    jjrek9 Well-Known Member
    Meso, any updates of the status of the stage 2?
    dci_birdman and CygnusX191 like this.
  16. May 27, 2021 at 1:57 PM
    #5176
    Tacospike
    Two Trucks
  17. Jun 4, 2021 at 10:33 AM
    #5177
    LightningTuned
    LightningTuned Member
    2016 Tacoma SR5 4x4 Inferno
    is there an ETA for when the stage 2 will be back in stock? I have been eagerly waiting to buy them.
  18. Jun 4, 2021 at 10:48 AM
    #5178
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    No stage 2 planned, but more stage 1’s are getting produced
  19. Jun 4, 2021 at 10:51 AM
    #5179
    LightningTuned
    Alright, sounds good, standing by! Thanks!
  20. Jun 21, 2021 at 6:46 AM
    #5180
    Alby22
    Alby22 Well-Known Member
    Ashville, Ohio
    Cement 2020 Toyota Tacoma TRD Sport 4x4 Double Cab, Long Bed
