MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Feb 28, 2019 at 9:22 PM
    #521
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    As for the shake....
    I've been thinking of this. It *could* be the o-ring.
    Either too thin or flexes when heated.
    Some who have the cheaper HIDs doesn't have the shake. So what I *think* is the o-ring. The cheaper ones could have a thicker o-ring that resists heat more. I would try match an o-ring that is slightly thicker from an auto shop, especially engine o-ring since it resists heat, oil whatever .
    The o-ring could be too thin. I'd look at it and see what's going on back there.
    * OR*...... pull out the o-rings from the halogen stock bulbs if it is thicker .
    Inferno__Taco likes this.
  2. Feb 28, 2019 at 9:30 PM
    #522
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    U talking about the seal around the bulb? The one that creates the resistance that holds the bulb in? I had a theory that it was how the projector was mounted in the lens. It seemed so flimsy.
  3. Feb 28, 2019 at 9:32 PM
    #523
    Boosted_Carrera
    Hawaii
    Yea...that o-ring . If it works , you can replace with Viton o-rings. They resist heat up to 500deg. not that you'll need it but never softens.
  4. Feb 28, 2019 at 9:45 PM
    #524
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Update for stage 2 folks-
    I spoke with VLEDs, and was informed the 7443 Red’s are due in a few weeks. I apologize for the delay, but I did hit them hard with a large QTY all at once...so they had to make a brand new batch for me. Although they ARE listed on the website, they have LIMITED stock. No where near enough to meet my entire fulfillment.
    So everyone’s getting theirs all at once.
    Also..
    It’s seems like a pretty good number of people are NOT needing resistors. I can drop the prices on the Stages if I take them off. That way you can use the savings on another MesoMod. :)
    Is your Stg. 2 kit back from vacation yet?!
  5. Feb 28, 2019 at 9:55 PM
    #525
    Boosted_Carrera
    Hawaii
    Hell, it spent couple days in Kansas visiting Dorothy and according to tracking you sent in your email (VIEW ORDER) I think it is here but USPS tracking has it elsewhere.:facepalm::annoyed:
  6. Mar 1, 2019 at 3:23 AM
    #526
    chadabear
    chadabear Well-Known Member
    Chad
    Louisiana
    2018 DCSB 4x4
    How much is the stage 2 kit?? It's not on page 1 or your web site on paypal??
  7. Mar 1, 2019 at 3:32 AM
    #527
    dead.fm13
    dead.fm13 Well-Known Member
    Chesapeake, VA
    2017 Tacoma TRD Sport
    5100/888's front, JBA UCA's, 5160's/Dakar's rear, Ray 10 MDB 17", 285/70/17 Ridge Grapplers, Hondo Garage Radio Knobs, MESOJDM Ultimate Turn Signals, MESOJDM Ultimate Combo Maps/Dome, MESO Total Tail Stage II, MESO Puddles
    $240 IIRC
  8. Mar 1, 2019 at 3:37 AM
    #528
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    The trick to it is upside down. If anything gets inside, use a bendy-straw taped to a vacuum to get around inside(EDIT:could also use rubber vacuum tube/hose). With hot-knife and MESO offering to sonic-knife anything sent to him, there are options for those who might be too nervous/OCD to attempt.
    TC_Mic likes this.
  9. Mar 1, 2019 at 5:33 AM
    #529
    ShadyCoh
    ShadyCoh Well-Known Member
    Burnet, Tx
    I would suggest if you use a step drill add a good amount of grease or petroleum jelly and have the light upside down drill slow and clean the bit and add more grease as needed.
    you will have to clean the area really well before gluing in the new fixture.
  10. Mar 1, 2019 at 6:03 AM
    #530
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Another thought I had at the time (but did not try) was to use an appropriately sized holesaw or wood paddlebit. Both would only cut at the outer ring and essentially leave the rest whole. I just decided not to be experimental, since I had the already suggested step-bit recommendation.
    Soul Surfer likes this.
  11. Mar 1, 2019 at 7:02 AM
    #531
    Red18Taco707
    Red18Taco707 Well-Known Member
    Richi
    Nor Cal
    Red 18 TRD POOR
    I did have it upside down. Cutting carefully. I would cut a bit and clean it out then cut again.
  12. Mar 1, 2019 at 7:14 AM
    #532
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    Stage 2 complete (minus red LEDs)
    848D5DC8-2399-465A-B548-D396C167CAA8.jpg B52FA116-EFB0-46FB-984E-5422D9EFD74D.jpg D6C5DD5A-98E8-4B63-8BFF-9F22CEE8B094.jpg
  13. Mar 1, 2019 at 7:19 AM
    #533
    KaizerWilhelm
    KaizerWilhelm Well-Known Member
    Will
    Seattle
    2017 TRD OR DCSB Super White
    Whole bunch of stuff in my garage
    subbed for in stock!
  14. Mar 1, 2019 at 7:34 AM
    #534
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    I wouldn't want to over-complicate the process, but perhaps connecting some sort of blower to the open taillight sockets would force the air and bits out the hole while drilling?
    The one thing you don't want is those bits flying around like it's a "Tornado Money Grab" session. There are alot of 'interesting' spots for things to end up (I've earned the scout merit badge for this).
    Skydvrr likes this.
  15. Mar 1, 2019 at 7:39 AM
    #535
    Red18Taco707
    Richi
    Nor Cal
    Red 18 TRD POOR
    I thought about it but didn’t want them flying everywhere. It was only a couple pieces. Doesn’t bother me you can’t even see them.
  16. Mar 1, 2019 at 9:10 AM
    #536
    skynyrd87
    skynyrd87 Well-Known Member
    2023 TRD Pro Solar Octane AT 2001 TRD OR White MT
    Is there a significant difference in between the brightness of both stages?
  17. Mar 1, 2019 at 9:58 AM
    #537
    Magnetik
    Magnetik Active Member
    Cecil
    SW VA
    16 Blazin' Blue TRD OR
    I used the hot knife on my soldering iron, worked great. I bought some DEPO Bro's for this as well, so I'll have a set of factory tails in spare or for sale. :laser:
  18. Mar 1, 2019 at 10:19 AM
    #538
    HolyReptar
    HolyReptar Well-Known Member
    Bry
    Thousand Oaks
    17 TRD Offroad 4x4
    Some Bolt ones here and there
    yes
    NoOne likes this.
  19. Mar 1, 2019 at 10:27 AM
    #539
    TacoRef10
    TacoRef10 Well-Known Member
    Joe
    2017 Inferno TRD Offroad
    When do you expect to have more Stage 1 kits available?
    Boxerocks and tacopromatt like this.
  20. Mar 1, 2019 at 11:03 AM
    #540
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    yes
