MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Jan 4, 2022 at 8:06 AM
    #5581
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    Installed my kit yesterday, no hyper flash with the OEM LED headlights and fog lights. I ordered the load resistors with the kit, and likely won't need them after I drive it for a week just to be sure (I know I'm weird, if it was gonna happen it'd be happening already).
    For those who have experienced hyper flash, does it make the turn indicator on the dash hyper flash too? Is the hyper flash in reverse noticeable from the rear view camera? I tested mine alone with the engine off but ignition on and everything seemed to be working fine.
  2. Jan 4, 2022 at 8:10 AM
    #5582
    huskcummerbund
    huskcummerbund Well-Known Member
    2020 TRD-OR MT
    Yes to both questions. Both the yellow and white are pretty bright so it's a little weird when the light flickers back and forth on one side but I'm ok with that. IMO the camera should only be used for the first and last foot of backing up, though. The rest of the time I look over my shoulder.
    CygnusX191 likes this.
  3. Jan 4, 2022 at 9:04 AM
    #5583
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    Are you saying you get both colors flashing when using your turn signal or reverse?
  4. Jan 4, 2022 at 9:22 AM
    #5584
    huskcummerbund
    2020 TRD-OR MT
    no, no. Back and forth, white yellow white yellow but at hyperflash speeds. To be clear, this only happens when I use my turn signal while also in reverse (like parallel parking). During normal operation I have no hyperflash.
  5. Jan 4, 2022 at 9:28 AM
    #5585
    LiquidArrogance
    LiquidArrogance Well-Known Member
    Streets of Bakersfield
    2021 SSM Sport 4x4
    I never even thought to check the turn signals in reverse. Going to have to give it a shot when I get home now :laugh:
  6. Jan 4, 2022 at 9:29 AM
    #5586
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    Copy that, and I think reverse + turn signal was the only permutation I didn't test. If that goes well, I believe I will have my unopened resistors ready to return to @MESO so they can stock them for the next lucky customer!
  7. Jan 4, 2022 at 9:31 AM
    #5587
    FishnTx
    South East Texas
    ‘17 OR
    I’m purdy sure that’s normal… I’m sure mine would do that too.. never have use to have a blinker on in reverse … @Tacospike Care to chime in?
    CygnusX191, Tacospike and tclavell like this.
  8. Jan 4, 2022 at 9:32 AM
    #5588
    huskcummerbund
    2020 TRD-OR MT
    Even with it I'm not even really tempted to try to fix it by installing the resisters. Since nobody around here seems to understand that turn signals mean, much less in that situation, the hyperflash may be considered a feature rather than a bug.
  9. Jan 4, 2022 at 9:35 AM
    #5589
    Tacospike
    Two Trucks
    I never use blinker in reverse :confused:
  10. Jan 4, 2022 at 9:36 AM
    #5590
    huskcummerbund
    2020 TRD-OR MT
    I don't always use my turn signal in reverse, but when I do it's because I'm parallel parking.
  11. Jan 4, 2022 at 9:39 AM
    #5591
    tclavell
    Troy
    Phoenix, AZ
    G70
    i'd say, as mentioned, you'll find that scenario prime for hyper flash. I haven't parallel parked in 25 years but did test the function, it hyper flashes for sure.
  12. Jan 4, 2022 at 9:42 AM
    #5592
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    Do you have the OEM LED headlights? From the limited reading I've done it appears that that part of the electrical system plays more nicely with this kit.
    CygnusX191 and huskcummerbund like this.
  13. Jan 4, 2022 at 9:42 AM
    #5593
    tclavell
    Troy
    Phoenix, AZ
    G70
    no, sir! Morimoto LED. OEM was halogen.
  14. Jan 4, 2022 at 9:46 AM
    #5594
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    Hooray, more data haha! I have the OEM LED lights, I'll report back on the turn + reverse without resistors when I know more.
  15. Jan 4, 2022 at 9:49 AM
    #5595
    TacomaGuy7878
    TacomaGuy7878 Mmmm....Tacos
    CO Mountains
    2020 AG Pro
    Yes the turn indicator in the dash will hyper flash (sort of like when your blinker bulb goes out), and yes you can see the hyper flash in reverse on the camera but you can see your blinker (not directly just the reflection off of the pavement) in the camera when not hyper flashing as well because they are so bright! It is not blinding the camera by any means. Your license plate lights are what blinds the camera:thumbsup:
    I do have stage 2 taillights though
  16. Jan 4, 2022 at 9:51 AM
    #5596
    huskcummerbund
    2020 TRD-OR MT
    I already fixed that using the $7 tag light shield kit. :p
    CygnusX191 and Jackie Moon like this.
  17. Jan 4, 2022 at 9:59 AM
    #5597
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    Thanks for the info! Stage 1s for me, but I could easily see my turn signal on the pavement from my side mirror at dawn this morning! See below regarding plate light glare.
    I got those too, a great lo-tech solution!
  18. Jan 4, 2022 at 11:01 AM
    #5598
    Scottyskywalker
    Scottyskywalker Well-Known Member
    Scott
    Kantukee
    2020 Silver Sky SR V6 4X4 SX
    RCI sliders, RCI front skid, RCI trans skid, Bridgestone Revo 3 AT, OTT tune, Fox 2.0 rear, Front Summo springs, Truxport roll up bed cover, Tekonsha P3, Meso total tails, rear diff breather relocate. JCW front bumper, Apex 12k winch, bar light. Alpine ILX 507, Kicker DX speakers, amber grill light bar, yellow LED fogs, LED headlights, bed mat, bed lights, front camera, rock lights, dash cam, seat jackers, recovery gear, Overland Equipment Aux fuse kit, C4 bumber braces.
    linky linky please
  19. Jan 4, 2022 at 11:03 AM
    #5599
    huskcummerbund
    2020 TRD-OR MT
  20. Jan 4, 2022 at 11:23 AM
    #5600
    SpyGoat
    SpyGoat I miss you Hobbs
    Tom
    Long Island, NY
    2021 TRD Off Road MGM DCSB, 2025 Land Cruiser
    A bunch..and no build thread!
    Everything I've ordered from MESO (3 orders now) have come within a week and I am in NY.
