MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Jan 4, 2022 at 12:00 PM
    #5601
    Jackie Moon
    Jackie Moon Well-Known Member
    CO
    2021 DCSB OR 6MT
    I get hyper flash in the turn + reverse combination, and it "latches" resulting in turn signal hyper flash until I put it in gear and drive on. I have the OEM LED headlights and fog lights. I will install the resistors and see how that affects the whole configuration, hopefully all hyperflash is avoided.
  2. Jan 4, 2022 at 4:39 PM
    #5602
    lefty9206
    lefty9206 Well-Known Member
    Jarrod
    2021 gray TRD off road
    None yet
    Awesome thank you
    CygnusX191 likes this.
  3. Jan 5, 2022 at 7:54 AM
    #5603
    jeejay
    jeejay Well-Known Member
    Jino
    SoCal
    '20 Tacoma Ltd MGM 4WD
    1st 2020 Nightshade Conversion|RetraxPro XR|DesertDoesIt Front Seat Jackers|Meso Customs V2 Ultimate Dome Lights|Meso Customs V2 Maplight Dual Mode|OEM 2nd Gen running boards|OEM bed lights|OEM tailgate lock|OEM bed mat|Meso Total Tail Stage 1|AVS Side Window Deflectors|Liftd Gas Cap Holder|Meso Headlight Trim Plates
    I have the OEM LED headlights and fog combo and the resistor addressed the hyper flash issue when I installed the TTL last year.
  4. Jan 5, 2022 at 8:00 AM
    #5604
    Jackie Moon
    CO
    2021 DCSB OR 6MT
    Thanks for the feedback! Just to clarify since I haven't had a chance to work on mine again yet, did it fix the reverse + turn situation without affecting any other operation? I live in the city and parallel park often so it is important to me for everything to function normally without exception.
  5. Jan 5, 2022 at 8:20 AM
    #5605
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Will not affect any other functions. Resistor all just Fix the hyperflash(whether it’s hyperflash during normal signal or in reverse)
  6. Jan 5, 2022 at 8:34 AM
    #5606
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    I read in a different thread that too much load/resistance was causing issues with turn signals in the OEM LED headlamp assembly. I haven't had time to swap mine out yet, but am prepared to remove the MESO load resistors in my tails if I experience a problem with the OEM LED turns in the front.
  7. Jan 5, 2022 at 8:36 AM
    #5607
    MESO
    State of Jefferson
    Usually if a customer has already installed resistors(be it front or rear) and then ADD mine, it overloads the system. But 1 set should be good to go.
  8. Jan 5, 2022 at 8:39 AM
    #5608
    mlr69
    South Carolina
    Do you know if the OEM LED headlamp assembly has a built-in resistor? If it does, maybe that's why the extra one on the tail is too much?
  9. Jan 5, 2022 at 8:55 AM
    #5609
    MESO
    State of Jefferson
    Does not.
  10. Jan 5, 2022 at 10:26 AM
    #5610
    jeejay
    Jino
    SoCal
    Based on my truck that came with OEM LED headlights and fogs, no new issue after adding the resistor to address the hyper flash while in reverse and turn signal is on with TTL S1. Furthermore, I also added MESO V5 switchback mirror turn signals a couple of months ago and all works well together.
    Edit: forgot to mention they are OEM LED headlights and fogs.
  11. Jan 5, 2022 at 10:37 AM
    #5611
    mlr69
    South Carolina
    My truck came with halogen headlights/turns and I'm swapping out the full assembly to the OEM LED. I would have to think there's something different somewhere in the truck between the OEM halogen assembly and the OEM LED assembly - otherwise, why would a stock truck with OEM LED not hyper-flash? Does that make sense? No need to answer, just thinking out loud. I'll know soon enough, once I get the install done.
  12. Jan 5, 2022 at 10:57 AM
    #5612
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    You’re overthinking it. Simply - Halogen has a standard incandescent signal bulb. LED has electronics to handle the sequencing signal.
    MESO[OP], tclavell and CygnusX191 like this.
  13. Jan 5, 2022 at 11:15 AM
    #5613
    mlr69
    South Carolina
    I get all that. And yes, I'm overthinking it. And yes, I've hijacked this thread, sorry. But the whole reason for the resistor is because the turn LED doesn't create the same load as the halogen turn. That's why I assumed the OEM LED assembly must have a load resistor built-in, but MESO says no.
    doublethebass and CygnusX191 like this.
  14. Jan 5, 2022 at 6:24 PM
    #5614
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    I just ordered a set of the V5 turns, should I remove the resistors I added with my total tails?
  15. Jan 5, 2022 at 6:29 PM
    #5615
    Tacospike
    Two Trucks
    See how it works first
  16. Jan 5, 2022 at 6:38 PM
    #5616
    Absolut_Boost
    Cincinnati, OH
    copy, thanks for the quick reply
    CygnusX191 and Tacospike[QUOTED] like this.
  17. Jan 5, 2022 at 7:15 PM
    #5617
    MESO
    State of Jefferson
    X2. Prob won’t affect anything swapping to V5’s
  18. Jan 6, 2022 at 9:19 AM
    #5618
    508Tacoma
    508Tacoma Well-Known Member
    MA
    2017 TRD OR 4x4 DCSB
    I know the etiquette about searching the thread, which I've done my best, but still couldn't get a straight forward answer. I'm looking to add the Total Tail Stage 1 to my stock 2017 TRD Off-road tail lights. My question is, will I need the load resistor? There is mixed info about some people experiencing the hyper flash and some do not. Thank you.
  19. Jan 6, 2022 at 9:23 AM
    #5619
    tclavell
    Troy
    Phoenix, AZ
    G70
    Won't hurt to have them. Seems the common hyperflash is reverse with blinker. For most, no worries, but if that is something you may be concerned with, resistors will eliminate that worry.
  20. Jan 6, 2022 at 10:19 AM
    #5620
    508Tacoma
    MA
    Appreciate the response. I don't think that would be a big concern for me. I can't imagine I would be in reverse and have my turn signal on that often if ever.
    CygnusX191 and tclavell[QUOTED] like this.
