MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Jun 22, 2022 at 2:45 PM
    #5681
    TacoTruck808
    TacoTruck808 Well-Known Member
    Oahu in the Aloha State!
    2016 Tacoma TRD Sport DCSB, Prem & Tech Pkg, MGM
    Same here. I have the V5 and resistors but didn't think to try them without the resistors after installing the V5.
    CygnusX191 likes this.
  2. Jun 22, 2022 at 3:21 PM
    #5682
    nevadawolf03
    nevadawolf03 Well-Known Member
    PNW
    2016 SR5 DCLB
    SR wheels, side marker black-out, Clazzio's, Tweeters, Tailgate inserts, interior vinyl inserts
    If either of you need to off load those resistors, let me know. I installed the Stage 1 into my SR5 and I have hyper flashing on one side and MESO is out of stock so I need at least one.
  3. Jun 22, 2022 at 6:44 PM
    #5683
    Absolut_Boost
    Absolut_Boost Well-Known Member
    Cincinnati, OH
    2021 Tacoma TRD OR DCSB Cement
    PM sent
    Tacospike and CygnusX191 like this.
  4. Jun 25, 2022 at 6:06 AM
    #5684
    Absolut_Boost
    Cincinnati, OH
    Resistors built into V5’s don’t appear to be strong enough to stop the hyper flash with a turn signal on while in reverse. At least not on my truck. I tried it this morning and it happened when I disconnected the resistor pack, but not while it was connected.
    CygnusX191 and NoOne like this.
  5. Jun 25, 2022 at 7:03 PM
    #5685
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    I don’t think the V5’s have resistors in them. The V4’s were advertised that way but I have never seen that for 5’s. I also saw reviews that said the V4’s would quit working after a few minutes, I’m assuming that was a safety feature due to heat from the resistor. I would assume they didn’t like that and quietly ditched resistors for V5.
    for anyone who needs resistors to stop their reverse + turn signal hyperflash on the Meso kit, get this resistor kit from VLEDS:
    https://www.vleds.com/vlr-15-wp-t-adapter-2.html
    It is a higher ohm kit which means less amp draw (anyone who knows the electrical formulas knows that higher resistance equals less electrical movement and as such, less amp draw) so they don’t get near as hot as your standard 1 bulb replacement 6 ohm or 2 bulb replacement 3ohm resistor.
    Simply plug these in using the included Y’s in between the Meso switchback and the Meso harness, stick the resistor to metal and you will be good to go, reverse or not. I believe these are basically the same principle as what Meso sells and is out of stock on currently.
    CygnusX191 and Road_Warrior like this.
  6. Sep 8, 2022 at 11:18 AM
    #5686
    MT_Advocate
    MT_Advocate Ramblin' In the Rambler
    Flagstaff, AZ
    2022 TRD Off-Road 6MT
    TRD Lift Kit; GFC; CaliRaised Trail Sliders
    Not sure parallel parking is a very specific and uncommon situation - I do it almost every single day. It's worth it to snag the resistors to stop that issue.
    CygnusX191 and doublethebass like this.
  7. Sep 8, 2022 at 11:26 AM
    #5687
    BLtheP
    Plano, TX
    Agreed fully. I wanna say for me to buy the correct ones from VLEDS, it ran me like $20 and they were fully plug and play. I see no reason to skimp.
  8. Sep 8, 2022 at 11:32 AM
    #5688
    Tacospike
    Two Trucks
    MESO offers them as well. If one doesn't want to navigate the VLED site
    Total Tail Load Resistors – MESO CUSTOMS LLC
    CygnusX191 and BLtheP[QUOTED] like this.
  9. Sep 8, 2022 at 11:37 AM
    #5689
    BLtheP
    Plano, TX
    Cool. Those used to be out of stock all the time which is why I went the VLEDS route. Plus I was buying a few other things too so it made sense to throw them in the basket.
    CygnusX191 and Tacospike[QUOTED] like this.
  10. Sep 9, 2022 at 6:10 AM
    #5690
    OldGregg
    OldGregg Well-Known Member
    New Mexico
    2021 TRD OR Access Cab Cement
    Does anyone know what a good replacement for the Red LEDs in the Stage 1 Kit would be? I had one totally die on me after a year and need a replace and probably want to pick up a spare or two to have in hand (I live rural).
  11. Sep 9, 2022 at 6:19 AM
    #5691
    BLtheP
    Plano, TX
    I like these much better:
    https://www.vleds.com/7443-50-r.html
    swapped all 4 of mine out for them. Better low brightness (dimmer so as to not fatigue others) and brighter on bright mode. Definitely better quality, I have never had a VLEDS failure in multiple years and tons of products from them.
  12. Sep 9, 2022 at 6:21 AM
    #5692
    Tacospike
    Two Trucks
    That's what I run in the Tacoma if you don't want to go Tritons. I did in the Tundra though
    EDIT: They just ran a 15% labor day sale. But you can use a TOYOTA10 year round for 10% off. Don't think the next good one will be until black Friday.
    CygnusX191 and tclavell like this.
  13. Sep 9, 2022 at 6:42 AM
    #5693
    tclavell
    Troy
    Phoenix, AZ
    G70
    I have 4 spare Stage 1 brake light bulbs if you want them.
    Soul Surfer, Tacospike and CygnusX191 like this.
  14. Sep 9, 2022 at 6:53 AM
    #5694
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    If the OP passes message me and let me know. I wouldn't mind having spares for my stage 1 handy :)
  15. Sep 9, 2022 at 6:54 AM
    #5695
    tclavell
    Troy
    Phoenix, AZ
    G70
    :thumbsup:
    CygnusX191 and Tacospike like this.
  16. Sep 9, 2022 at 7:03 AM
    #5696
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    I just had a red 7443 S1 go out too. Opened a ticket on MESO's website, waiting to see what my options are.
  17. Sep 9, 2022 at 7:07 AM
    #5697
    Tacospike
    Two Trucks
    There are replacement bulbs on the site, but I've never seen them in stock. I think he probably just sends out replacements.
    mlr69, CygnusX191 and tclavell like this.
  18. Sep 9, 2022 at 7:11 AM
    #5698
    tclavell
    Troy
    Phoenix, AZ
    G70
    I had eight spare bulbs at one time :anonymous:
    I forgot about the initial four @Soul Surfer provided me and then bought another four from Meso when the last batch of Stage 1 Kits were released.
    For anyone wanting a bulb, I have no problem providing a single bulb or two for free...
    @FL_TRD Sport
    @OldGregg
  19. Sep 9, 2022 at 7:13 AM
    #5699
    Tacospike
    Two Trucks
    :fistbump: ^ this guy
  20. Sep 9, 2022 at 7:17 AM
    #5700
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    I'll gladly at least cover your shipping costs for two of them and leave two for @OldGregg. I don't want you to be out of pocket to send them to me. I'll DM you :)
