MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Sep 9, 2022 at 7:16 PM
    #5741
    Tacospike
    Two Trucks
    MiTacoTRD[QUOTED] likes this.
  2. Sep 9, 2022 at 7:24 PM
    #5742
    MGMDesertTaco
    For I second I thought the truck was yellow like the pizza planet tacoma from toy story. I might go this route if I can't get the limited edition meso clear tails.
    MiTacoTRD[QUOTED] and Tacospike like this.
  3. Sep 9, 2022 at 7:40 PM
    #5743
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Yes, V6 is plenty bright. I have it as my backup.
    Tacospike[QUOTED] likes this.
  4. Sep 9, 2022 at 7:41 PM
    #5744
    MiTacoTRD
    N. Idaho
    I’m really happy with them.
    MGMDesertTaco[QUOTED] likes this.
  5. Sep 9, 2022 at 9:52 PM
    #5745
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
    Thanks for the comparison.
    Just to clarify, the tritons being the ones that pop right into the reverse housing (meant to replace the stage 1 switchback), and the triton extremes being the larger ones you have to modify the hole for?
    just want to make sure because if so, then I’m curious why the Tritons I tried were so bad. They were terrible compared to the mess stage 1 SBs. Maybe it’s just because your video is dark. Your extremes look good though.
  6. Sep 9, 2022 at 10:10 PM
    #5746
    BLtheP
    Plano, TX
    Ok, I see now that the stage 1 VLEDS “upgrade” is indeed not really an upgrade and that’s why I was disapppinted. Those are Tritons which are an over 10 year old design. They are rated at 500 lm amber and 900 white. The Meso stage 1 switchback is 500/500 but it makes better use of the reflector than the 3 amber or 3 white LEDs of the Triton.
    I do NOT recommend these
    https://www.vleds.com/2016-up-toyota-tacoma-meso-total-tail-v6-triton-921.html
    Then there is the V6 extreme which is 1400 lumens amber and 1000 lumens white. Now THAT seems pretty damn solid! These require the Meso bulb adapters. I’m assuming the larger bulb ends up being pretty brilliant compared to the Meso stage 1 or the VLEDS triton stage 1 “upgrade”. Damn it, now it makes me want to get some bulb adapters and see! :rolleyes:
    Stage 2 V6 extreme bulb that requires Meso adapter:
    https://www.vleds.com/2016-up-toyota-tacoma-meso-total-tail-v6-extreme-switchback.html
    Meso adapter:
    https://mesocustoms.com/products/vled-triton-bulb-adapters?variant=16289397571697
    And for anyone randomly wanting to upgrade their stage 1 reds to what comes in stage 2, then 4 of these bad boys will do the trick.
    BSFord, dilbert and Tacospike like this.
  7. Sep 10, 2022 at 6:48 AM
    #5747
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    Just FYI, I emailed Meso about spare switchbacks to have on hand and Austin replied last night. They are $27 each, said he could send me 2 so I grabbed them. So now I will have 2 7443 reds and 2 switchback bulbs on hand as spares for my stage 1.
    Tacospike likes this.
  8. Sep 10, 2022 at 7:07 AM
    #5748
    mlr69
    mlr69 I had a savings account before I joined TW
    South Carolina
    2018 TRD Sport 4x4 DCSB
    2" ToyTec/Eibach Pro Sport Lift Kit -SparksParts.com 3/4" ToyTec Front Top Plate Spacer Kit -SparksParts.com SPC Performance Upper Control Arms -SparksParts.com Nitto Ridge Grapplers 285/75/17 (34") -SparksParts.com 1.25" Spidertrax Wheel Spacers -SparksParts.com Hypertech Speedometer Calibrator -hypertech.com Predator Tube Steps -SparksParts.com BAKFlip G2 Tonneau -SparksParts.com OEM Rubber Bed Mat -SparksParts.com OEM All-weather Floor Liners -SparksParts.com Gentex Frameless Mirror with Homelink @RJP869 Subaru/Kicker Tweeters -amazon.com Kicker Door Speakers (x4) -crutchfield.com Radio Knobs @Tacowiede Vehicle OCD Glove Box Organizer -amazon.com ‎JoyTutus Center Console Tray -amazon.com FormulaOne Pinnacle Window Tint -SparksParts.com ACDF Horn Kit @BartMaster1234 Total Tail Light S1 Kit @MESO ECT Button Relocation Kit @Tacowiede Minimalist Key Fobs @MESO Ultimate Map & Dome Lights @MESO Fortin EVO-ALL Remote Start w/Cell Module @jmeitz Coin Bucket with Lid @MESO GermesLab Camera Control System @FreshMexicanTaco Natika Front View Camera -amazon.com VLEDS LP Reverse Light System -vleds.com LIFTd Customs Fuel Cap Cradle @JIMMEISTER OEM Power Tailgate Lock -SparksParts.com OEM 2022 Limited Grille -SparksParts.com OEM 2022 Limited LED Headlamps -SparksParts.com LED Headlight Conversion Harness @daveeasa Headlight Trim Plates @MESO OEM Door Sill Protectors -SparksParts.com Diode Dynamics Elite Fog Lights @memario1214 Fog Light Backlighting PNP Harness @daveeasa TacomaTime Dash Cubby Drawer -etsy.com FPE Fogs + High-Beam Module @memario1214
    What email address did you use? I filled out the form on the MESO website about a week ago and have yet to get a response.
    OldGregg likes this.
  9. Sep 10, 2022 at 7:17 AM
    #5749
    Tacospike
    Two Trucks
    Just the 921 bulbs needs no modification.
    Both the larger non extreme and extreme triton bulbs need modification to the taillights, not just the extreme. If I read that right*
    I keep a spare set of adapters. I busted one of my taillights last year and had to wait a few months for the 3d printing window to open up for replacement.
    30E8E71D-643F-4C7A-88BD-8C7817B60C9E.jpg 9E1B9544-D102-45DD-8B39-CEC26A9CAC36.jpg
    BLtheP[QUOTED] and MiTacoTRD like this.
  10. Sep 10, 2022 at 10:09 AM
    #5750
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    I didn't send an actual email sorry. I used their chat to generate a contact form. Austin got back to me in about 48 hours.
  11. Oct 11, 2022 at 7:15 AM
    #5751
    jayandersen5
    jayandersen5 Well-Known Member
    Jay
    South Carolina
    2017 TRD Pro
    OTT Tuned Yukon 5.29s 35x12.50r17 Yokohama MTs RRW RR7-H Wheels Dobinsons MRRs RRW hybrid front bumper ATH rear swing out high clearance bumper Alucab Explorer Canopy iKamper skycamp 2.0 Diode Dynamics SS3 (x4) and SSC2 SOS Sliders C4 full skids Smittybilt X20 Gen3 10k winch Prinsu Cabrack Expedition Essentials 3TPAM Caliraised 40" light bar ExtremeLED 30" light bar Total Chaos spindle/cam tab gussets and bed stiffeners Switch Pro SP9100 Power Tray
    Recently sold my stock pro taillights with the total tail stage 1 kit and for some reason the turn signals are now hyperflashing for the new owner. He has an SR5 (not sure that would make a difference) and is getting a hyperflash even when not in reverse. Does anyone know what would cause this? I never had a problem in the 2+ years I had the kit.
  12. Oct 11, 2022 at 7:20 AM
    #5752
    FL_TRD Sport
    Hector
    Port St. Lucie, FL
    Its hit or miss depending on the truck. Some hyperflash, some don't. Mine did not with the total tail stage 1. He needs to put in resistors.
  13. Oct 11, 2022 at 7:21 AM
    #5753
    BLtheP
    Plano, TX
    The SR/SR5 models have different hyperflash parameters. He can get a plug and play resistor to solve it.
  14. Oct 11, 2022 at 7:38 AM
    #5754
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    I’m not certain the ECU sensitivity is different. That’s an interesting question and one we might be able to answer if we could isolate things. I believe the observed differences are more about the circuit itself. Wiring harness is different, no mirror turn signals and different bulbs in the front. Plus no combination of DRL and Turn.
    Net effect is what you say, SR & SR5 are different, but I’m not certain it’s from numeric configuration.
    ETA: unless maybe you’ve seen stuff in techstream?
  15. Oct 11, 2022 at 7:55 AM
    #5755
    CanadaToy
    CanadaToy Well-Known Member
    Greg
    Toronto
    17 DCSB TRD OR Alpine
    TRD Pro grille & skid, OEM tonneau and roof racks
    They may not have the mirror turn signals, so there is less resistance in the system.
  16. Oct 11, 2022 at 8:24 AM
    #5756
    BLtheP
    Plano, TX
    No, for correctness, I probably should not have said different hyperflash parameters. What I did mean by that is actually what you said, that the trucks are different. I don't know what they're looking for. I do know on my TRD, it is not looking for much. Any LED wired in is enough to keep the hyperflash at bay. First thing I did on day one was LED turn signal bulbs (LED, stock design not MESO yet) and front ambers in the halogen headlights. They worked perfectly fine from the get go. It was when I introduced the Meso switchback to the truck that hyperflashing happened (the parallel parking situation: reverse with blinker on). I suspect the Meso bulbs having that specific issue is directly related to their circuitry. I believe the circuitry in the bulb powers the blinker with the reverse power supply when reverse is active, hence why the turn circuit starts to hyperflash.
    The part about the mirrors is a good point, I'm not sure what would happen to a TRD if you were to unplug the mirrors, then run LEDs front and rear. Maybe hyperflash? Maybe not. If I'm bored one day I may try it and report back. If a TRD hyperflashed due to the mirror being unplugged, then I'd be more inclined to believe the SRs are more similar to the TRDs than I thought.
    I have no way to prove this, but I suspect Toyota knew in 2016 that eventually they were going to install full-LED headlight assemblies on TRD models (which turned out to be 2020) so they set up the circuits to hyperflash if no current, otherwise ANY current draw keeps the hyperflash away. I believe that because even 2016s which all came with halogen and incandescent bulbs, still don't hyperflash.
    But really my main point in the first comment was that at surface level, TRDs do not hyperflash with LED bulbs installed, while SRs do, so I stated they have different parameters.
  17. Oct 11, 2022 at 9:53 AM
    #5757
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    I have '17 with Total Tail 1. No hyperflash when in normal use but hyperflash activates when reverse in use with turn signal on. I don't care about that since I don't use turn signals in reverse. I also have UTS for side mirrors.
  18. Oct 11, 2022 at 10:32 AM
    #5758
    BLtheP
    Plano, TX
    Yours is normal. the only time the hyperflash thing would show itself would be when parallel parking. For me, just knowing it would do that was enough for me to want to buy the resistors to fix it, but not everyone cares that much. It was only $15 and I was buying something else already so I threw them in the cart. It was plug and play so no sweat whatsoever.
  19. Oct 12, 2022 at 3:14 PM
    #5759
    nevadawolf03
    nevadawolf03 Well-Known Member
    PNW
    2016 SR5 DCLB
    SR wheels, side marker black-out, Clazzio's, Tweeters, Tailgate inserts, interior vinyl inserts
    I have a SR5 and I did get hyperflashing only on one side but only when using the turn signal. I also didn't get hyperflashing with the emergency hazard lights. I popped one resister in and it solved it.
  20. Oct 17, 2022 at 7:04 PM
    #5760
    Tacospike
    Two Trucks
    Passenger or driver?
