MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Nov 22, 2022 at 5:03 PM
    #5801
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission ADD delete with FJ full-time tube FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Operable (Switched) Clutch Safety Bypass
  2. Nov 23, 2022 at 7:16 PM
    #5802
    hwntaco20
    hwntaco20 Well-Known Member
    2020 Tacoma TRD Offroad 2wd
    The resistors arrived today, order to arrival in Hawaii only 3 days, way 2 go Meso!:thumbsup: All bulbs still working.
    Good news, no more hyper flash in reverse.
    Bad news, FM reception still really bad, must be something else. Will start troubleshooting. Hopefully will find loose antenna connection.
    MGMDesertTaco and Soul Surfer like this.
  3. Nov 23, 2022 at 7:38 PM
    #5803
    BLtheP
    Plano, TX
    Did you not swap the bulbs to test for interference?
    resistors won’t do anything at all for interference. Need to backtrack on the bulbs.
    Soul Surfer and MiTacoTRD like this.
  4. Nov 23, 2022 at 9:22 PM
    #5804
    hwntaco20
    Uh. .. 4got. Will try later.
  5. Nov 24, 2022 at 9:42 AM
    #5805
    MiTacoTRD
    MiTacoTRD Well-Known Member
    N. Idaho
    2019 Tacoma TRD Off-Road DCSB
    Most LEDs will have interference in some frequencies…I replaced my garage door bulb with incandescent and the remote distance improved significantly.
  6. Nov 24, 2022 at 9:44 AM
    #5806
    BLtheP
    Plano, TX
    I can’t find any good incandescent bulbs anymore. I went with “garage door LEDs” from Genie and a year and a half later, they work great with no remote problems. I had some Great value standard LEDs and range was horrible, couldn’t open the door from 10ft away if the lights were on.
    In the automotive world I’ve had no interference issues with the quality (but expensive) brands. Cheaper stuff has always been hit or miss, definitely had a bunch of interference issues with some of them.
  7. Nov 24, 2022 at 7:16 PM
    #5807
    MiTacoTRD
    N. Idaho
    I think you can still get garage motor specific bulbs, but they just cost a bit more than reg bulbs.
  8. Nov 25, 2022 at 6:49 AM
    #5808
    WhiteTaco20
    WhiteTaco20 Well-Known Member
    Perkasie, PA
    SW 2020 TRD Sport DCSB
    meso's tt are 75 for meso blk friday sale
    AmateurTaco1313 and MiTacoTRD like this.
  9. Nov 25, 2022 at 5:48 PM
    #5809
    hwntaco20
    Update, replaced the 4 back to oem, drove a bit, no chg
    Next I removed the reverse leds and put the stock back on the harness, no chg.
    Next, disconnected the negative battery terminal, pulled the hu and unplugged all connectors, looked at all the wires, nothing unusual, put it all back and still no change. At least I ruled out the Meso Tails as the cause. Not sure where else to check. Only thing had done recently was the body shop replaced my front bumper, valence and black pieces under the grill. Wonder if a ground strap or something was undone and not reinstalled.
    I'll just use my thumb drive or BT more for now.
  10. Nov 26, 2022 at 7:51 AM
    #5810
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    Did you change 3rd brake? I’ve heard some folks originate there after a swap. If not, definitely a ground, as that’s the fix for the 3rd brake. There is a ground strap in the radio area as well. From the bolt area towards the driver’s side to the listed ground.
  11. Nov 26, 2022 at 10:58 AM
    #5811
    hwntaco20
    no, I didn't touch the 3rd brake light, to much risk of water intrusion. Yesterday was the 1st time removing the hu, it's all stock, just wanted to check the connections.
  12. Nov 27, 2022 at 9:50 AM
    #5812
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    Don’t have much other to offer. Check main grounds, battery, body, under hood fuse block, etc.
  13. May 30, 2023 at 3:31 PM
    #5813
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    2016 Black TRD Sport OnRoad 4x2
    Well one of my red Stage 1 bulbs has given out, long shot but does anyone have a replacement for sale. Or does anyone know of a good replacement?
  14. May 30, 2023 at 3:35 PM
    #5814
    BLtheP
    Plano, TX
    VLEDS 50-led is decent. Personally I’ve been running incandescents in my 4 brake lights. They are as bright as LEDs to the eye and a more visible color in daylight. At night the LEDs are more intense. Meso bulbs are hot garbage.
  15. May 30, 2023 at 3:37 PM
    #5815
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Thanks appreciate it, yeah may just do that since I still have the incandescents
    Tacospike and BLtheP[QUOTED] like this.
  16. May 30, 2023 at 3:46 PM
    #5816
    Tacospike
    Two Trucks
    And vled has a sale running right now
    RockHed[QUOTED] and BLtheP like this.
  17. May 30, 2023 at 3:48 PM
    #5817
    BLtheP
    Plano, TX
    I’ll add that I just spent the money to try VLEDS newer “V6” kit which has their extreme red bulbs. Quite expensive, but want to test. I’m not anti LED at all, just didn’t feel like the lower brightness LEDs were much of an improvement over the incandescents, though I do like the “instant on” factor. The new ones I’m getting should be brighter though which I’m looking forward to trying.
    Tacospike and RockHed[QUOTED] like this.
  18. May 30, 2023 at 3:50 PM
    #5818
    RockHed
    RockHed TTC #051
    Danny
    San Antonio TX
    Thanks I'll look into it then
  19. May 30, 2023 at 3:51 PM
    #5819
    BLtheP
    Plano, TX
    Pretty sure buying VLEDS entry level kit (stage 1 equivalent) will end up being cheaper than buying 4 single red bulbs. But, worth a check.
    RockHed[QUOTED] likes this.
  20. Jun 23, 2023 at 4:44 AM
    #5820
    HighCountryTacoma
    HighCountryTacoma Well-Known Member
    Colorado
    2017 DCSB TRD Off Road Quicksand
    Are there any differences between this kit and the VLED kit?
