MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Apr 6, 2019 at 10:01 PM
    #1681
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Yeah just patiently waiting
    It’s killing me with all the post from ppl getting there’s today or tomorrow blah blah
  2. Apr 6, 2019 at 10:03 PM
    #1682
    SandyTaco4x4
    SandyTaco4x4 Well-Known Member
    Southern CA
    17 DCSB/AT QS TRD Sport 4x4
    Ohh yikes ok got it thanks.
    Are they neccessary? I tested mine without them and everything seemed to work fine? Maybe I'll just remove them
  3. Apr 6, 2019 at 10:04 PM
    #1683
    danyo_saan
    danyo_saan Well-Known Member
    Daniel
    Honolulu, HI
    2016 Tacoma TRD OR DCSB
    Bilstein 5100|OME 887|Icon AAL|Icon UCA
    I’ve just installed my stage 1s and I absolutely love it! I didn’t even end up using the load resistors at all. Works perfectly normal!
  4. Apr 6, 2019 at 10:05 PM
    #1684
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    Might have something to do with hyper flash when using the reverse and turn at the same time. The stage 2 noted that the resistor aren't needed but could be purchased. Anyone confirmed the hyper flashing?
  5. Apr 6, 2019 at 10:09 PM
    #1685
    SandyTaco4x4
    Southern CA
    I tested all possible light combos, reverse and turn works the same with or without the resistors. Does that mean I'm good to just remove them?
  6. Apr 6, 2019 at 10:10 PM
    #1686
    SandyTaco4x4
    Southern CA
    Same here. Thought it was only stage 2s that didnt end up needing the load resistors. Did you just leave them off or what did you end up doing?
  7. Apr 6, 2019 at 10:11 PM
    #1687
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    I say so if you tried all different combos and all works well. I still have to order V6 bulbs for my kit.
    SandyTaco4x4[QUOTED] likes this.
  8. Apr 6, 2019 at 10:12 PM
    #1688
    VegasKnights
    VegasKnights Well-Known Member
    2019 TRD Off Road 4x4 Double Cab
    Stock otherwise lighting wise?
  9. Apr 6, 2019 at 10:13 PM
    #1689
    SandyTaco4x4
    Southern CA
    Got LED lighting in the cabin but not mesos, and mesos turn signals but stock besides that.
  10. Apr 6, 2019 at 10:19 PM
    #1690
    VegasKnights
    Interesting, i thought i read earlier in the thread of others with the turn signals not needing the resistors. Maybe the combination is a win. I will install mine without the resistor tomorrow and see what the result is. (i do not have the turn signals. Yet. Ordered today lol.) I am stock brake and turn light wise.
  11. Apr 6, 2019 at 10:28 PM
    #1691
    danyo_saan
    Daniel
    Honolulu, HI
    I just left it as it is.
  12. Apr 6, 2019 at 10:30 PM
    #1692
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I think rattling will be the least of your issues.
    I think the consensus is if you dont get hyperflashing, load resistors aren't needed. If you get hyperflashing use the load resistors.
    If you use the load resistors, make sure you mount them in a way where it's out of the way of other wires as to not melt or damage any wires that may contact the load resistors. I believe it's best to mount them on metal so it acts as a heat sink. Those load resistors are supposed to get extremely hot.
    _gray_knight_ likes this.
  13. Apr 6, 2019 at 10:32 PM
    #1693
    MGMSangTaco
    MGMSangTaco Colorado Toyota Tuning
    Denver, CO
    2017 TRD OR MGM DCLB
    I think it may have something to do with the meso turn signals already having resitors in them. But I’m not sure why some people with meso turns have hyper flashing in rear turns while in reverse and some don’t.
    NoOne likes this.
  14. Apr 6, 2019 at 10:34 PM
    #1694
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Those that are having hyperflash without the resistors, what year and model trim is your rig? That might help to understand things??
    VegasKnights likes this.
  15. Apr 6, 2019 at 10:35 PM
    #1695
    VegasKnights
    Cool. I thought they might but wasn't sure. Definitely makes sense... and then the some people don't. Definitely should start a list of hyper flashers and specs.
    MGMSangTaco[QUOTED] likes this.
  16. Apr 6, 2019 at 10:35 PM
    #1696
    slowlane
    AZ
    16 double cab MGM
    I have hyperflashing, I haven't installed the resistors yet. I'll do that tomorrow. But I have led turn signals up front. My guess is that's my problem.
    But no hyperflashing prior.
  17. Apr 6, 2019 at 10:38 PM
    #1697
    SandyTaco4x4
    Southern CA
    Thanks for the info. I tried every possible combo and didn't seem to need them so I removed them entirely.
  18. Apr 6, 2019 at 10:38 PM
    #1698
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Good point on the front LED signals as that might having something to do with it. Maybe @meso can shed some light on this, pun intended :p
  19. Apr 7, 2019 at 1:12 AM
    #1699
    VegasKnights
    Stock 2019. Stage 1. Required Resistors. My passenger side hyper flashed.
  20. Apr 7, 2019 at 6:46 AM
    #1700
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Just installed my stage 1. No hyperflash, so didn’t use the resistors. I have Auxbeam led headlight and fog light bulbs. Along with Meso v4 turn signals.
    Night and day difference from stock.
    Thanks again @mesojdm
    cshrum likes this.
