MESO Total Tail Light Kit
Discussion in '3rd Gen Tacoma Parts Marketplace (2016-2023)' started by MESO, Feb 20, 2019.
  1. Apr 7, 2019 at 6:51 AM
    #1701
    _gray_knight_
    _gray_knight_ Well-Known Member
    SoCal
    '18 Mall Crawler
    Just washed
    What bulb type are you using for your front turn signals? Stock?
  2. Apr 7, 2019 at 7:01 AM
    #1702
    Frsh2df
    Frsh2df Well-Known Member
    2017 MGM TRD Off Road 4x4
    Yes, i only swapped out the high / low beam and fog light bulbs.
  3. Apr 7, 2019 at 7:07 AM
    #1703
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    2022 Tacoma DCLB OR (AT) - BC
    2018 SR5 - (Sold) 2018 OR - RIPieces 2022 OR - BluCrush
    My guess is stock front/MESO Ultimate Turns (10 ohm resistor built-in)/MESO Ultimate Tails (either version) will likely work without additional resistors, or at least be borderline. Once you add in upgraded front turns, etc. the dynamics change on what might be needed.
    Frsh2df[QUOTED] and MESO[OP] like this.
  4. Apr 7, 2019 at 7:09 AM
    #1704
    logges
    logges Member
    Logan
    2019 Cement TRD Off Road
    I haven’t mounted yet, but I’ll likely be mounting them similar to post #1044 in this thread, page 53.
    I’m not sure how to tag that specific post, or else I would, lol
  5. Apr 7, 2019 at 7:09 AM
    #1705
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Im thinking the same thing. Front turns stock with only upgraded to meso sides turn will work fine with either stages. If you have swapped your front turns to LEDs, that's where the hyperflash will happen. i think that will be my case as I have LED turns up front as well meso V4 sides.
  6. Apr 7, 2019 at 8:19 AM
    #1706
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    Thanks for the support guys! Everyone should be receiving stage 1's, and stage 2's shipped Friday so expect them throughout this next week.
    Keep an eye out here for updates on new releases:D
    Thanks! The reason it's tighter than stock is a few reasons;
    1)I made the tolerance gap a little less. I wanted a TIGHT waterproof fit
    2)The O-Ring I use has a little harder durometer than the stock O ring.(softer material).
    That is why I designed a hex or wrench flats onto the bulb, if it's tight just take some pliers or a wrench to lock it in tight!
    ME as in ME, Myself, and I
    OR like MESO horny, MESO soup, MESO----whatever you want!
    It all depends on what I have going on in production. If ALL I did was total tails, it would probably be a week or less. But I am juggling other projects, and tend to jump around.
    Yes those are the same bulbs I use in my stage 2 kit. The 5K is out of stock at the moment(I wiped them out) But you can get the 6k if you need them ASAP.
    I would just make sure it isn't zip tied directly to a wiring harness. Although they will get warm, I don't think they will get hot enough to melt though any wiring...but just an extra precaution. I include 3M VHB tape installed (which is designed for thermal expansion), so I suggest mounting them to the metal inner fender well.(if you need them)
    I'm trying!
    Another batch of stage 2 will be next. Then hopefully my custom stage 1 VLED bulbs will be manufactured and I will have MANY more kits to go around:D Baby steps...
    Glad you like it!! I put a lot of time and effort into making this as seamless, functional, and installer friendly as possible;)
    I think this combo is pretty solid without resistors. I just include them because everyone's setup is different. Another reason why I made the quick disconnect harness so you won';t have to be yanking wire taps off if you do not need the resistor.
    Cl4aub, cshrum, Rewilliams and 5 others like this.
  7. Apr 7, 2019 at 8:23 AM
    #1707
    _gray_knight_
    SoCal
    '18 Mall Crawler
    Just washed
    Thanks for confirming, ordered the 6k bulbs.
    MESO[QUOTED][OP] likes this.
  8. Apr 7, 2019 at 8:37 AM
    #1708
    NoOne
    NoOne El Taco Guapo
    Ø ©
    Gulf South
    See, and all this time I thought it was MÊSŌ ... like Mess-Oh.
    As in I got a MESO mods to work on today. There sure is a MESO people stalking these threads... you get the idea.
  9. Apr 7, 2019 at 9:12 AM
    #1709
    SLACKBOY
    SLACKBOY Toyota For Life!
    Erich
    Washington State
    2016 MGM Toyota Tacoma OR 4x4
    Blacked Out Emblems Wet Okole Seat Covers Installed Tinted Front Windows Weathertech Digital Floor Liners for the Front Plasti Dipped OF Grill - Removed BAMF Grill - MGM Installed Icon Stage 2 Kit. TRD Pro Wheels - 17's Ko2s installed (275 70 17) TRD PRO Rigid Led Fogs N Fab 3" Step Bars TRD Pro Auto Shift Knob TRD Pro Tail Lights
    Thanks for the update MESO !
    I’m waiting for the Stage 1 kits Not having to cut my PRO tail lights. Let me know.
  10. Apr 7, 2019 at 9:12 AM
    #1710
    VegasKnights
    VegasKnights Well-Known Member
    2019 TRD Off Road 4x4 Double Cab
    Is no one liking the 3m tape for resistors? A lot of post are saying about mounting them.
  11. Apr 7, 2019 at 9:12 AM
    #1711
    SLACKBOY
    Erich
    Washington State
    I would use 3M
  12. Apr 7, 2019 at 9:44 AM
    #1712
    Esprit09
    Esprit09 Active Member
    17' TRD Sport
    Hoping you make more kits!!!
  13. Apr 7, 2019 at 9:51 AM
    #1713
    slowlane
    slowlane Well-Known Member
    AZ
    16 double cab MGM
    I just installed the resistors. Got rid of the hyperflashing. I mounted the resistors behind the metal brackets towards the top inside the taillight cavity. I figured this was the only place that wouldn't contact any other wires. But I guess per MESO they wouldn't get hot enough to melt any wires. Oh well. But I also just used the 3m tape, my experience with 3m tape is, its just as good mounting them with hardware.
    Stage 1's are a vast improvement over stock. I always hated the way the taillights lit up. They always looked like a bulb was out. Now they are exactly how it should be. I cant imagine how bright the stage 2's are gonna be. Stage 1's are great. Stage 2's must be greater. Haha.
    Shout out to @Panchovilla6192002. Good dude! He helped to hook me up with a stage 1 when I was out of the country.
  14. Apr 7, 2019 at 10:09 AM
    #1714
    Viper1092
    Viper1092 Well-Known Member
    2019 cement Tacoma TRD OffRoad
    @mesojdm will the new v1 switchbacks work with the old version v1’s
  15. Apr 7, 2019 at 10:13 AM
    #1715
    MESO
    State of Jefferson
    Yes everything is cross compatible as far as wiring goes.
    oly51 and Inferno__Taco like this.
  16. Apr 7, 2019 at 10:20 AM
    #1716
    Frsh2df
    @mesojdm Will you or are you planning to offer the stage 1 switch back bulbs / harness for purchase ? Was looking to get a set as a back up pair as a “just in case “ something happens to the ones that came in the kit down the road. Would love to have a spare set i could keep in the truck.
    Thanks
  17. Apr 7, 2019 at 11:15 AM
    #1717
    Tommyb08
    Tommyb08 Well-Known Member
    Tom
    Jersey Shore - Ocean County
    2017 TRD Sport 4X4 DCLB Black
    I did mine last night. I did mine behind the circled portion.
  18. Apr 7, 2019 at 11:42 AM
    #1718
    Panchovilla6192002
    Panchovilla6192002 Well-Known Member
    Arizona
    2019 Cavalry Blue TRD SPORT 4X4 DCSB MT 2003 Red ExtraCab MT 5 lug
    Funny thing is, I did a comparison (that night) with the stock bulbs using only the harness and the other side using the red leds......
    I’m terms of brightness, they looked about the same to me. However, the color is where I could tell the difference.
    The LED side was a true red whereas the regular bulb looked almost orangeish.
    Having the amber turn signal is awesome and is definitely super bright. I need to take another look at the reverse lights in use at night.
    Maybe the 2019’s come with brighter taillight bulbs. Or maybe my bulbs are still fairly new and haven’t lost any brightness. I don’t do that much night driving in the taco.
    It would have been good to have done a comparison @slowlane
  19. Apr 7, 2019 at 12:40 PM
    #1719
    Boosted_Carrera
    Boosted_Carrera Well-Known Member
    Hawaii
    2018 TRD SPORT, 1996 911 Turbo
    This is a stage 1 or 2 ?
    2 is definitely brighter than stock.
  20. Apr 7, 2019 at 2:35 PM
    #1720
    Panchovilla6192002
    Arizona
    Stage 2
    I used the harness to use both parts of taillights with regular bulbs
