Meso Total Tail Stage 1 - Problem
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Jprocs24, Jan 24, 2025.
  1. Jan 25, 2025 at 4:09 PM
    Road_Warrior
    Road_Warrior There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    Awesome thank you sir! Yeah I don’t have any plans to change, I just wanted to make sure I know that’s a good alternative if my total tails ever start burning out or malfunctioning.
    BLtheP[QUOTED] likes this.
  2. Jan 25, 2025 at 4:54 PM
    Jprocs24
    Jprocs24 [OP] Well-Known Member
    I mainly wanted the kit for the different orientation of the lights, and brighter reverse lights.
    Do you have any of the resistors installed in with your kit? I'm assuming hyper-flashing would still be an issue with a signal on and putting it in reverse? I lived with that for the 2.5 years and found myself rarely in that situation, so it's a non issue
  3. Jan 25, 2025 at 11:13 PM
    scouterjan
    scouterjan Well-Known Member
    Jan
    22 TRD OR AC in good old white
    VLED is the best option IMHO
  4. Jan 31, 2025 at 2:33 PM
    Dzsnelling
    Dzsnelling New Member
    any luck with getting switchback bulbs from VLEDs for the MESO total tail kit?
  5. Jan 31, 2025 at 5:08 PM
    AZPhys13
    AZPhys13 Well-Known Member
    2021 TRD OR DCLB - MGM
    Is there any chance this could be related to the weather/season? It has been my understanding that the resistance in the lights/harness in the Meso kits was always teetering on angering the trucks electrical system. Reading through posts when I got my own Stage 1 kit, the need for resistors seemed hit or miss among other owners. The reverse/turn signal scenario didn't even happen every time with my lights, I just bought the resistors to eliminate the problem one and for all. Could the whole system be sensitive enough that colder winter temperatures can have an affect?
  6. Jan 31, 2025 at 5:21 PM
    BLtheP
    Plano, TX
    2021 MGM TRD On-Road DCSB MT
    RC60F Transmission 5.29 R&P FJ Metal Clutch Pedal OEM Mexico-Spec Condenser Fan 265/70R16 Michelin Defender LTX M/S 2 OEM 1-Piece Lug Nuts Custom Built Switch Panel for all Electrical Accessories Rigid Amber Pro D-SS Ditch Lights Rigid 30" SAE High Beam Driving Light Bar Rigid SR-Q Pro Back-Up Light Kit (Recessed) VLEDS Tail Conversion VLEDS Bed Light Kit VLEDS Foot Well Light Kit KC HiLites Cyclone V2 Under Hood Lights Customized 2WD Low Operable (Switched) Clutch Safety Bypass
    I don’t think temperature plays a part. Hyperflash is based solely on amp draw, which varies directly based off of the voltage at any given moment. In my experience, all TRD models (Sport, OR, Pro) and Limited needed the resistors to prevent hyperflash in reverse, but they did not need anything for just normal turn signaling.
    Most of the SR/SR5 models I’ve seen post up here needed resistors simply from installing the bulbs. So those should plan on resistors regardless.
    I think the hyperflash on TRD models is directly related to bulb/switchback design. A TRD will hyperflash if there is no bulb at all. It will not hyperflash with an LED in place. So we know it is monitoring current for bulb outage alerts, but it is not needing much current since even a measly LED can satisfy it. The fundamentals of a switchback is that the white mode is a constant mode and turn signal overrides the constant mode. They have to build it this way because switchbacks are means to be used as a DRL type function where turn signaling always takes priority. I think what ends up happening is that when you turn signal normally (not in reverse), the turn signal pulls current like always which keeps the system happy. When you’re in reverse, I think it routes the constant reverse feed to power the Amber circuit and just blinks it until the turn signal request goes away. Meaning it’s no longer pulling any measurable current on the turn signal circuit while the truck is in reverse, and hence no hyperflash.
    I think the reason for the differences between SR/SR5 trims and TRD is that Toyota probably knew when they designed the 2016 that LEDs were coming later (like in 2020). So they probably designed the amperage needed to prevent hyperflash to be lower due to the future LED options. Just my guess.
    As to why yours doesn’t always hyperflash on reverse, is there a chance you sometimes do your testing with the engine off? With the engine off, voltage will be lower and so amp draw will be higher. With the engine running I can’t see why bulb function in reverse would ever change - it should be constant and it seems like everybody hyper flashes while running the turn signal in reverse (unless they installed resistors to fix it).
