Meso Total Tail Stage 2 pin out
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Puppypunter, Jul 9, 2020.
  1. Jul 9, 2020 at 11:19 AM
    Puppypunter
    Puppypunter [OP] Well-Known Member
    Johnny
    2019 Black SR
    Does anyone know the pin out on the connectors where the @MESO Total Tail harness plugs into the OEM harness? Like which one is reverse, brake, etc? I’m really just trying to find the one for the turn signal. Thanks in advance!
    @caribe makaira would probably know as well Meso, so throwing him on here in hopes as well.
  2. Jul 9, 2020 at 11:26 AM
    Ronzio
    Ronzio Well-Known Member
    Pennsylvania
    17 DCSB TRDOR
    Use your scope on a rope (test light) and probe the connector with the turn signal in the on position the test light will blink.
    tonered likes this.
  3. Jul 9, 2020 at 11:36 AM
    eurowner
    eurowner Duke Sky
    Scoty
    Did you reach out to Meso off his website or email?
  4. Jul 9, 2020 at 11:36 AM
    Tacospike
    Two Trucks
    If I'm reading it correct, you just want to identify which one is which?
    Put you hazards on and mark the ones that blink with tape, leaving the other ones as the brakes.
  5. Jul 9, 2020 at 11:38 AM
    Puppypunter
    Johnny
    2019 Black SR
    I was trying to be lazy. Didn’t feel like pulling the light, but I could do that.
    I haven’t. Figured someone here might have it handy. Tried searching, but I have zero luck with the search function.
  6. Jul 9, 2020 at 11:39 AM
    Puppypunter
    Johnny
    2019 Black SR
    I am hoping to find the wire itself so I can tap it.
  7. Jul 9, 2020 at 11:40 AM
    Tacospike
    Two Trucks
    Gotcha
  8. Jul 9, 2020 at 12:57 PM
    MESO
    MESO Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    FROM LEFT TO RIGHT.
    REVERSE PLUG: GROUND, POWER----TURNSIGNAL PLUG: TURN, PARKING, GROUND----BRAKE PLUG:pARKING, BRAKE,GROUND
    hope this helps:)
  9. Jul 9, 2020 at 4:32 PM
    caribe makaira
    Caribbean, Puerto Rico
  10. Jul 9, 2020 at 6:14 PM
    Puppypunter
    Johnny
    2019 Black SR
  11. Jul 9, 2020 at 6:17 PM
    caribe makaira
  12. Jul 9, 2020 at 6:17 PM
    caribe makaira
    OP, Whatcha working on?
  13. Jul 9, 2020 at 6:28 PM
    daveeasa
    daveeasa FBC Harness Solutions
    David
    PNW
    2016 Tacoma OR DCSB 6MT, 2005 RC 5MT PreRunner, 2002 Tundra SR5 RCLB 4x4
    My guess is he has a new weight sensing switch which will flash the turn signals once for every pomeranian detected inside the vehicle as they enter/exit?
  14. Jul 9, 2020 at 6:36 PM
    Puppypunter
    Johnny
    2019 Black SR
    I’m attempting to put in side cameras. Kind of blind spot/side view cameras. I need the turn signal for a trigger. It will trigger a delay timer that supplies power to the side camera, as well as acts as a trigger to the head unit. So when you turn on the left turn signal, the left camera comes up on the screen, same for the right. Turn the turn signal off, and the screen goes back to normal (with a slight delay, about a second). The delay comes from the timer, it needs to keep the power constant, otherwise the camera will turn on and off with the turn signal... These cameras will also have an “anytime” switch override as well.
    daveeasa likes this.
  15. Jul 9, 2020 at 6:37 PM
    Puppypunter
    Johnny
    2019 Black SR
    That wasn’t the idea.... UNTIL NOW!
  16. Jul 9, 2020 at 6:37 PM
    daveeasa
    David
    PNW
    How are you switching the video feeds?
  17. Jul 9, 2020 at 6:41 PM
    Puppypunter
    Johnny
    2019 Black SR
  18. Jul 9, 2020 at 6:50 PM
    caribe makaira
  19. Jul 9, 2020 at 6:55 PM
    Puppypunter
    Johnny
    2019 Black SR
    Where is that in the truck?
  20. Jul 9, 2020 at 6:58 PM
    caribe makaira
    Combination Switch..."light stalk"
