MESO X MORIMOTO Full LED Tail lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Aug 11, 2021.
  1. Mar 19, 2022 at 12:02 PM
    #1261
    mclslee
    mclslee Well-Known Member
    2021 OR LB
    More pics / vids those who have em, please! :D:p
    bubba swift likes this.
  2. Mar 19, 2022 at 12:09 PM
    #1262
    bubba swift
    bubba swift Well-Known Member
    Orange County CA
    2018 Black TRD OR
    yesss, still have yet to see them on a black truck
    Idahotaco88 likes this.
  3. Mar 19, 2022 at 12:27 PM
    #1263
    Cedric781
    Cedric781 Member
    Had mine on for a day and both sides got condensation
  4. Mar 19, 2022 at 12:35 PM
    #1264
    Roadkill1081
    Roadkill1081 Well-Known Member
    Maryland
    2020 DCSB TRD SPORT CEMENT
    Waiting for someone to post pics of a cement with the red version. How about a few different angles?
  5. Mar 19, 2022 at 1:59 PM
    #1265
    LunarRockV
    LunarRockV Well-Known Member
    Kyle
    2022 Lunar Rock SR5 Trail Tacoma
    I think meso said that with the first batch, there was a lot that got damaged in shipment. I'm sure they will take care of the issue
  6. Mar 19, 2022 at 3:12 PM
    #1266
    Cedric781
    Cedric781 Member
  7. Mar 19, 2022 at 3:16 PM
    #1267
    mysubiewasalemon
    mysubiewasalemon Well-Known Member
    How shitty , for that price those shits better be water tight
  8. Mar 19, 2022 at 3:30 PM
    #1268
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    That's not how condensation works
    Skydvrr, forrest1st and ktbell444 like this.
  9. Mar 19, 2022 at 3:31 PM
    #1269
    mysubiewasalemon
    Then do explain professor, just for you pumpkin
    MaxGeog likes this.
  10. Mar 19, 2022 at 3:34 PM
    #1270
    GrundleJuice
    Michigan
    2016 TRD Bro
    ktbell444 likes this.
  11. Mar 19, 2022 at 3:35 PM
    #1271
    mysubiewasalemon
  12. Mar 19, 2022 at 3:45 PM
    #1272
    malatx
    malatx Well-Known Member
    2022 TRDOR DCLB Army Green
    ok, in all seriousness, I'm assuming that when the tail lights were sealed from factory, the air in the compartments was not sucked out.
    So, depends on how humid the air that's trapped in the sealed compartment is, when the condition (temperature mostly) is met, the water molecules can form condensation.
    If the seal is tight, then the amount of condensation should be a constant because no extra moisture can get in.
    If the condensation gets progressively worse, then it's fair to suspect bad sealing?
    ceh527, doublethebass and MaxGeog like this.
  13. Mar 19, 2022 at 3:46 PM
    #1273
    MaxGeog
    MaxGeog Well-Known Member
    Max
    Alberta
    2022 TRD Sport Premium WCP DCSB MT
    Toyota Factory Lift TRD Rims 275/70/17 KO2s
    Thanks for actually adding value here this is a great explanation for anyone who doesn't have this info already!
    Rainoffire and skeletron like this.
  14. Mar 19, 2022 at 3:48 PM
    #1274
    TacoQC1
    TacoQC1 Well-Known Member
    TRD Off Road
    There was a note included in the box about condensation. I’ll take a picture of it later if I remember
    MaxGeog likes this.
  15. Mar 19, 2022 at 3:52 PM
    #1275
    willd0ugh
    willd0ugh Well-Known Member
    2020 Cement TRD OR DCSB
    Can’t wait to get my hands on a set. They look beautiful nice work!
  16. Mar 19, 2022 at 3:54 PM
    #1276
    GrundleJuice
    Michigan
    2016 TRD Bro
    If the gas that gets trapped in a sealed assembly at manufacture is high enough in moisture (relative humidity), the the dew point may be above the temp that it has cooled to in that environment. It's like a cold drink on a hot day. There may be a way to prevent or eliminate this, but it depends on the design of the assembly.
    ktbell444 and malatx[QUOTED] like this.
  17. Mar 19, 2022 at 4:00 PM
    #1277
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    Nitrogen will remove moisture in the air. Use it all the time in our thermal chambers at work to prevent ice build up on the electronics we were testing while at low temperatures.
  18. Mar 19, 2022 at 4:01 PM
    #1278
    malatx
    Anyone knows who actually manufacturer these lights? I speculate somewhere in China and most likely one of the coastal regions so humidity probably is fairly high, but at least they should make sure the assembly place air is low dust and low humidity (air filter and dehumidifiers can do). Sucking it vacuum is probably too costly
  19. Mar 19, 2022 at 4:05 PM
    #1279
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Morimoto manufactures the lights
    malatx[QUOTED] likes this.
  20. Mar 19, 2022 at 4:07 PM
    #1280
    GrundleJuice
    Michigan
    2016 TRD Bro
    Agreed. We use dry nitrogen for all of our instrumentation calibration and offset pressure in the test cells. If these are sealed assemblies I would assume that they were supposed to be purged with N2 at assembly, but I think there are unsealed light assemblies that work well.
    ktbell444[QUOTED] likes this.
