MESO X MORIMOTO Full LED Tail lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Aug 11, 2021.
  1. Apr 6, 2022 at 7:05 PM
    #1661
    howmuch4onerib
    howmuch4onerib i sure am hungry
    Marc
    Seattle
    '21TRDORDCSBLOLOMFGTLDRIDC
    yes! look a page back or two for a photo of mine. I feel in my case it might be nitpicking(def not MESO’s fault). My plan is to sand with fine grit and clear coat myself if needed.
  2. Apr 6, 2022 at 7:09 PM
    #1662
    JohnnyTRD06
    JohnnyTRD06 Well-Known Member
    2017 Tacoma TRD Pro
    Smoked WeatherTec rain guards Access roll up bed cover Tinted front side windows TRD Cold air intake TRD Billet oil fill cap Spartan X Customs hood scoop lightbar Meso Customs dual mode LED interior lights Meso Customs V1 mirror turn signal lights Meso Customs sequential taillights Meso Customs puddle lights and switch kit Putco Nitro Lux LED headlights CBI Off-Road rear skid plate CBI Off-Road gas tank skid plate Kicker DS series door speakers Kicker dash tweeters Overland Tailor Tuning tune
    These are absolutely awesome at night!
  3. Apr 6, 2022 at 8:33 PM
    #1663
    GreenMachine2021
    GreenMachine2021 Member
    2021 Army Green OR DCSB
    If anyone wants to sell their OEM pro taillights let me know. Especially if you’re around NYC. Thanks :thumbsup:
  4. Apr 6, 2022 at 9:59 PM
    #1664
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Mine had the same amount of moisture one morning and evaporated once the sun hit it. Pretty sure this is normal
    mokeiko likes this.
  5. Apr 7, 2022 at 12:15 AM
    #1665
    MGMDesertTaco
    Don't think it's normal. Water and electricity don't mix. Most likely isn't sealed all the way. :boink:
    CreoUCLA likes this.
  6. Apr 7, 2022 at 12:36 AM
    #1666
    Rainoffire
    Rainoffire Well-Known Member
    2017 QS DCLB TRD Sport
    I thought there is an instruction paper inside that indicates some condensation is normal. Someone posted a picture of it somewhere in this thread.
    Found it:
  7. Apr 7, 2022 at 6:32 AM
    #1667
    TacoQC1
    TacoQC1 Well-Known Member
    TRD Off Road
    Read links on thread 1287 too.
  8. Apr 7, 2022 at 7:50 AM
    #1668
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    2021 Midnight Black TRD Sport AT/DCSB
    TRD Lift,OTT Tune, LED HLs,TRDSkid, TalonCAT
    Thanks for the Lens style pics on Midnight Black!
    I'm still debating which ones I prefer.
    Also, I noticed you put black insert letters on your tailgate. I put reds on mine.
  9. Apr 7, 2022 at 8:01 AM
    #1669
    mclslee
    mclslee Well-Known Member
    2021 OR LB
    I'm biased owning reds but that glossy corners look with your current tails doesn't really go away much with clears. Not sure if you care about that.
    One minor nit pick with reds Ill throw in is that the turn signals during the day do seem a bit dim, unsure if clears are better on that front.
  10. Apr 7, 2022 at 8:13 AM
    #1670
    TacoTime55
    TacoTime55 TT59
    Ed
    Delaware
    Clears might be brighter considering the Reds are dipped in dark blood red...lol!
    That's why I've been kinda bitchy about brighter reds...hopefully, someone is reading this...??? lol
    Skydvrr likes this.
  11. Apr 7, 2022 at 8:13 AM
    #1671
    GreenMachine2021
    Even with clear lenses the turn signals seemed too Dim. Next to the MESO stage 1 it wasn’t even close. I ultimately decided to return the LED tails because of it. Sucks because Ive been waiting for these since pre-order
  12. Apr 7, 2022 at 9:03 AM
    #1672
    CreoUCLA
    CreoUCLA Well-Known Member
    West L.A.
    '21 Tacoma TRD OR, '21 Audi TT, & '22 Tesla M3P
    A foggy condensation is normal (like the photo included in the box), but I don't believe large water droplets/pooling water are. My passenger side housing had the foggy condensation in it that evaporated (and then stayed dry), but the driver side has noticeable water droplets and it keeps reappearing throughout the day indicating a leak in the seal. When the driver side housing is in the sun for a while (as the truck is parked outside), it clears up/evaporates a bit, but I can distinctly see a small puddle of water at the bottom the housing in that corner which shouldn't be happening.
  13. Apr 7, 2022 at 9:50 AM
    #1673
    MESO
    MESO [OP] Major Modder Vendor
    State of Jefferson
    2016 DCLB TRD HELLCAT SWAP
    If there is a PUDDLE of water, definitely not normal. I would do a visual inspection on the back to make sure all wire grommets are seated before installing. If there is a "fogging" inside, then that is normal condensation. It will evaporate out. (FYI- ALL lights no matter what brand; OEM or aftermarket are NOT Sealed Air tight) If that were the case..as soon as you drive up into the mountains/higher elevation the pressure couldn't equalize and the lights would probably crack.
    There are pros and cons that can be had for both products. Total Tail VS MESO/MORIMOTO. I will say the best "bang for the buck" will definitely be the Total Tail. However..it will still look "stock" in the end. The New LED tails have the unique look and the performance is still nothing to balk at. We have just been spoiled with the output on the total tail which uses the reverse reflector bowl. I have a few things in mind to improve on these new tail light housings though;)
    Both are the same output. I personally can't tell if one is brighter than the other. Here's a pic of both lit up (RED LEFT/CLEAR RIGHT)
    BRAKE
    TURN
  14. Apr 7, 2022 at 9:53 AM
    #1674
    aturk
    aturk Well-Known Member
    Tony
    Charlotte, NC
    A random guy in a Tundra waved for me to roll my window down yesterday to compliment the tail lights and asked where I got them from.
    @MESO guess you better get started on a Tundra version
  15. Apr 7, 2022 at 9:57 AM
    #1675
    GreenMachine2021
    If you do a version with a switchback in the reverse bucket I will buy it immediately :spending: one recommendation I have is to keep the reverse color temp the same as the total tail
    MESO[QUOTED][OP] likes this.
  16. Apr 7, 2022 at 10:05 AM
    #1676
    JManning1423
    JManning1423 Well-Known Member
    Jacob
    Columbus, GA
    2017 M/T Sand Tacoma TRD OR
    Too many to count
    I would assume Meso was involved in this, but they are already live on Morimotos website.
    ktbell444 likes this.
  17. Apr 7, 2022 at 10:08 AM
    #1677
    MESO
    State of Jefferson
    The same design was carried over to the Tundra. I did not have a hand in that product. Also..they are preorder so take that with a grain of salt:cookiemonster:
  18. Apr 7, 2022 at 10:44 AM
    #1678
    Rainoffire
    I know it is based off Meso's design, but I really do not like how those look on the Tundra...
    It looks like there is a lot of unused space.
    The "bars" also feel out of place as it doesn't really follow the lines of the tail light assembly or even the body lines of the truck.
    E.T., MGMDesertTaco and Skydvrr like this.
  19. Apr 7, 2022 at 10:47 AM
    #1679
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    Well said.
    Rainoffire[QUOTED] likes this.
  20. Apr 7, 2022 at 10:50 AM
    #1680
    pnwtacoma_
    pnwtacoma_ Well-Known Member
    Matthew
    Portland, OR
    Solar Octane '23 Tacoma TRD PRO
    BuiltRight Industries Bedside Rack, Baja Designs Amber S2 Pro on CBI ditch mount brackets, Baja Designs Amber Squadron, Switch-Pros PowerTray for SP9100
    My set arrived, along with a few other goodies. Got back from work and these promptly went onto the truck. No broken tabs! Stoked on how the clears look against Army Green. Thanks again to @MESO & company for the many hours of hard work getting these sent out :bowdown:
