MESO X MORIMOTO Full LED Tail lights
Discussion in '3rd Gen. Tacomas (2016-2023)' started by MESO, Aug 11, 2021.
  1. May 9, 2022 at 2:56 AM
    #1841
    Aggie23
    Aggie23 When in doubt, figure it out.
    James
    BCS, TX
    2016 White TRDOR DCSB
    Just come across a weird issue, not sure if it's related to the Tails at all but it's only occurred since I installed them.
    Occasionally let's say I'm about to turn left and so I have my left blinker on. It will randomly just stop working, like the flashing in the cab will stop completely as well. It stays off if I turn on my hazard lights, i.e. only the right one starts blinking, and if I switch my turn signal from left to right and then back to left, the right turn signal will work fine but the left still will not work.
    Any ideas y'all?
  2. May 9, 2022 at 3:06 AM
    #1842
    skeletron
    skeletron Disgraced Member
    Clark
    Sakerlina
    2020 TRD Broh
    Sounds like a loose connection. Have you gone back and looked to make sure everything is secure?
  3. May 9, 2022 at 3:09 AM
    #1843
    ktbell444
    ktbell444 One who throws exceptions
    ᚺᛖᛚᚺᛖᛁᛗ
    I recently found I had the same issue. Left turn only. I've been in contact with Austin and I'm testing stock tails currently. It's so random that I'm going to test for 1 to 2 weeks because I never know when it is going to happen.
    There's another instance here:
  4. May 9, 2022 at 5:59 AM
    #1844
    doublethebass
    doublethebass aspiring well-known member
    Antoin
    Minneapolis MN
    ’17 6MT Pro
    I had the exact same problem on my old Harley and it turned out to be a loose connection
    skeletron likes this.
  5. May 10, 2022 at 9:27 AM
    #1845
    vorkuta775
    vorkuta775 Well-Known Member
    Texas
    tesla truck
    I would recommend using some di-electric grease on all the connectors. given where the taillights are mounted there are holes there in the body frame that allows a alot of dust, dirt, water/snow/ice in that area. I plugged them up with some thin rubber so less gets in there.
    doublethebass[QUOTED] likes this.
  6. May 10, 2022 at 11:25 AM
    #1846
    JaTe
    JaTe Well-Known Member
    Maryland
    2017 Tacoma TRD OR DCSB
    Are you running custom ovtune with AGM battery changes? Had something similar happen when I was using LED turn signal bulbs with wrong sized resistor added depending on which AGM changes I was running.
  7. May 10, 2022 at 2:38 PM
    #1847
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    No, I have stock battery, no need for changes to alternator voltage. Issue did not exist prior to tails being swapped out. Closest thing was hyper flash after installing V5's in conjunction with the total tails.
  8. May 10, 2022 at 4:06 PM
    #1848
    Aggie23
    James
    BCS, TX
    I am, I haven't gotten round to checking my connections yet but that could be a possibility.
  9. May 11, 2022 at 12:32 PM
    #1849
    _FREEDOMTACO
    _FREEDOMTACO Brewmaster
    Greg
    2017 TRDOR DCSB 4x4 M/T
    Fresh install :cheers:
    Clear lens on the MGM looks insane! And the quality of the lights is insane.
  10. May 11, 2022 at 12:44 PM
    #1850
    memario1214
    memario1214 Hotshot Offroad Moderator Vendor
    Colton
    Missoula, MT
    SOLD - 05 Dub Cab TRD Sport 4x4, CURRENT - '21 Tundra MGM Limited
    Beautiful rig! Followed :cool:
    _FREEDOMTACO[QUOTED] likes this.
  11. May 11, 2022 at 10:19 PM
    #1851
    _FREEDOMTACO
    Greg
    Thank you! :thumbsup:
  12. May 14, 2022 at 7:46 PM
    #1852
    20tacoma17
    20tacoma17 Well-Known Member
    2017 DCLB Sport AT
    Kings, 275/70/17, a few custom items, lots of Meso mods.
    Mine arrived today. Now to figure out how to get them apart? :devil:
    Rainoffire likes this.
  13. May 14, 2022 at 7:59 PM
    #1853
    Gmak621
    Gmak621 Łøādîñg…
    Nørth Çøast
    2024 TRD ØR
    Shake n BAKE
    20tacoma17[QUOTED] likes this.
  14. May 14, 2022 at 8:04 PM
    #1854
    20tacoma17
    2017 DCLB Sport AT
    I figured that. Can see the sealant bead inside. Just need to find out temp tolerances and most importantly an oven. I Did many OEM's to modify them but OEM's have to be cut open. :hattip:
    Gmak621[QUOTED] and Rainoffire like this.
  15. May 14, 2022 at 8:25 PM
    #1855
    ktbell444
    ᚺᛖᛚᚺᛖᛁᛗ
    Here's what @MESO mentioned earlier in this thread:
  16. May 16, 2022 at 1:58 PM
    #1856
    phocas
    phocas Well-Known Member
    I have an extra set that I bought for my neighbor, still in the box unused with receipt. I live in the Seattle area. Will to discount since I cannot return them to Meso.
    Ultimate Tacoma Tail Lights FULL LED × 1
    CLEAR LENS
    howmuch4onerib and skeletron like this.
  17. May 30, 2022 at 4:41 AM
    #1857
    ChrisIz
    ChrisIz Well-Known Member
    Texas
    2023 TRD Off-road
    I’ve been rocking these for over a month now and I love them. I had a family member drive my truck recently while I followed and noticed how dim the turn signal is compared to the brake and reverse. Anyone else notice how dim they are during day light?
    Boy.Bray likes this.
  18. May 30, 2022 at 4:44 AM
    #1858
    Ahomeofbones
    Ahomeofbones Member Well-Known
    2021 TRD OR
    They are a little dim in direct sun. Still effective and better than stock imo but I really miss the amber in the buckets from my Total Tails. Those things could been seen from a mile away and that's during the day.
  19. May 30, 2022 at 7:37 AM
    #1859
    denuir
    denuir Member
    Love the look and that topo, man.
  20. Jul 19, 2022 at 1:04 PM
    #1860
    Tacospike
    Two Trucks
