Messed up my transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LilTexan22, Feb 11, 2023.
  1. Feb 11, 2023 at 6:32 PM
    #61
    TexasWhiteIce
    TexasWhiteIce Well-Known Member
    Texas
    2022 White DCLB SR5 - Blackout
    Maybe my mindset is different, I wouldn’t care if it meant damaging my $40k+ vehicle.
  2. Feb 11, 2023 at 6:36 PM
    #62
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  3. Feb 11, 2023 at 6:38 PM
    #63
    LilTexan22
    LilTexan22 [OP] Well-Known Member
    2017 Tacoma
    Eh mines paid off and wasnt close to 40k but i get were you are coming from lol
  4. Feb 11, 2023 at 6:44 PM
    #64
    lbhsbz
    lbhsbz Well-Known Member
    1: 10mph is not "slow" when changing direction.
    2: Regardless of how busy your street is, you need to come to a stop anyway to change direction...it's just physics. Use the brakes.
    3: Doing what you did could in no way have damaged that sensor.
  5. Feb 12, 2023 at 7:07 AM
    #65
    jmneill
    jmneill Well-Known Member
    SE
    2018 Tacoma Sport ACC CB Inferno
    Allow me to be the first to say, it's not going to turn out to be just the sensor..
  6. Feb 12, 2023 at 7:25 AM
    #66
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Yeah, I've been thinking the same thing. He'll know soon but the description of what it was doing and the bad noises sure sounds like some internal gearbox damage has occurred.
    Hoping for a good outcome for the OP, but I don't know!
    SR-71A, FredRed315, Chew and 2 others like this.
  7. Feb 12, 2023 at 9:20 AM
    #67
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    Part out prediction is what you guys are saying ?
    Blak Shinobi and J Williams like this.
  8. Feb 12, 2023 at 10:30 AM
    #68
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    With the sensor removed, you might check the shift shaft sticking out of the case and make sure is moves through all positions when the shifter is moved. It's possible it may be broken inside the valve body. That could explain the trouble code
    landphil, SR-71A and Kev250R like this.
  9. Feb 12, 2023 at 10:37 AM
    #69
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    Very likely…sorry OP!
    AM6217[QUOTED] and TexasWhiteIce like this.
  10. Feb 12, 2023 at 11:24 AM
    #70
    Bcjammerx
    Bcjammerx I'm not ALWAYS an a-hole, I swear
    North East Texas
    ‘17 TRD Off-road 4X4
    damn...I thought the transmission wouldn't let you put it in reverse if moving forward...might be speed limited to over 30 but figured it was any forward speed.
    Good luck finding a rebuild kit, when I hit a deer and lost the cooler my transmission burnt out...these things REALLY don't like running dry...well what transmission does lol. Found ONE company claiming to make a rebuild kit but they said it wasn't ready for release for another year and a half, so like mid this year. you might find one now, even toyota dealerships didn't have just the clutchpacks and other internals.
    I had to just call around junk yards, called every one in central and east texas and east to central louisiana...finally found ONE company that had a wrecked 3rd gen 4x4 v6 tacoma, my truck had 44k and the transmission they found had only 10k. I think it cost like 3k, 800 for a mechanic to install it for me.
    I thought I bookmarked them, I'll find the paperwork and post up the company, they had to ship it to my location too
    RedDemolisher likes this.
  11. Feb 12, 2023 at 11:40 AM
    #71
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    It's just a tranny
    Pat out....pshhhhh
  12. Feb 12, 2023 at 12:05 PM
    #72
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    the transmission won't let you shift into reverse while driving forward. it has a safety-lockout. you could shift into reverse at 50 mph and it would be fine.
  13. Feb 12, 2023 at 12:05 PM
    #73
    greengs
    greengs Well-Known Member
    AB, Canada
    2022 Tacoma Pro, 2023 Gladiator Mojave, 89 W126
    You can throw it in R at highway speed and all that happens is rear cam comes on. Not sure why it wouldn't have the same protection at 10mph. Maybe that limit is higher?
    cryptolime likes this.
  14. Feb 12, 2023 at 12:07 PM
    #74
    US Marine
    US Marine Semper Fi
    Chuck
    Gallatin Tennessee
    02 Pre Runner supercharged 4cyl
    TRD supercharger , Doug Thorley header , K&N CAI 265/75-16 Toyo open country mud terrain , 15x8 Method Racing wheels , Rancho 3" lift , 4.88 gears , Detroit Locker
    Sounds like it grenaded the Sun gear and or the Planetary gears . Very common when going from drive to reverse at speed to quickly
    Kev250R and Bcjammerx like this.
  15. Feb 12, 2023 at 4:39 PM
    #75
    USMILRET
    USMILRET Tacoma Owner
    1998, 2007 and 2020 Tacoma
    Damaged internal components for sure. You might luck out with the range switch so I wouldnt give up all hope on that. Chances are it is internal.
  16. Feb 12, 2023 at 5:05 PM
    #76
    twtaco$
    twtaco$ Well-Known Member
    If you put the truck in reverse while driving at around 35 mph the truck goes into neutral instead of reverse a safety feature. Guess not 10
  17. Feb 12, 2023 at 5:07 PM
    #77
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Engineers can only protect people making bad decisions up to a point.
  18. Feb 14, 2023 at 11:29 AM
    #78
    kahanabob
    kahanabob Well-Known Member
    Maui
    16 TRD 2WD 4DR
    Update OP
    Chew, cryptolime and LeakyAC like this.
  19. Feb 14, 2023 at 12:26 PM
    #79
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    Damn
  20. Feb 14, 2023 at 12:27 PM
    #80
    TXpro4X4
    Bryan
    Costa Mesa, CA
    2011 TOY
    amyracecar and LeakyAC like this.
