Messed up my transmission
Discussion in '3rd Gen. Tacomas (2016-2023)' started by LilTexan22, Feb 11, 2023.
  1. Feb 15, 2023 at 3:35 PM
    #161
    Buck Henry
    Buck Henry Well-Known Member
    2019 White TRD Off Road
    Good for you OP! Sometimes (actually many times), it's the simple stuff!
    But I am curious, did your little Speed Racer shift stunt cause the fuse to blow or was this just a bizarre coincidence?
    Chew and J Williams like this.
  2. Feb 15, 2023 at 3:37 PM
    #162
    LilTexan22
    LilTexan22 [OP] Well-Known Member
    2017 Tacoma
    Scanned it using my scan tool and the P0705 is gone.
    TRDSport10 and J Williams like this.
  3. Feb 15, 2023 at 3:38 PM
    #163
    LilTexan22
    2017 Tacoma
    See its weird i dont know what it was exactly. The whole reverse thing could have been a coincidence
    J Williams likes this.
  4. Feb 15, 2023 at 3:40 PM
    #164
    J Williams
    J Williams Well-Known Member
    Jeff
    Central MN
    2021 TRD Pro
    Could try it again to see if you can reproduce the same results?? :)
    FredRed315 likes this.
  5. Feb 15, 2023 at 3:40 PM
    #165
    AM6217
    AM6217 Well-Known Member
    2021 SR-5 DCSB Silver metallic
    So the part out is not happening
  6. Feb 15, 2023 at 3:40 PM
    #166
    LilTexan22
    2017 Tacoma
    I should huh? Make everyone angry at me again for shifting it into reverse while in motion:rofl:
  7. Feb 15, 2023 at 3:42 PM
    #167
    2016Tacoman
    2016Tacoman Well-Known Member
    J
    2016 Tacoma 4x4 V6 Metallic
    I would love to see the wiring diagram on that because how can a back up light fuse cause an issue like this. :confused::confused::confused:
    kahanabob likes this.
  8. Feb 15, 2023 at 3:44 PM
    #168
    J Williams
    Jeff
    Central MN
    2021 TRD Pro
    Yeah…nothing to see here anymore. LOL
  9. Feb 15, 2023 at 3:46 PM
    #169
    Vlady
    Vlady Well-Known Member
    Issy, WA
    2017 White SR5 DCSB V6 4x4
  10. Feb 15, 2023 at 3:54 PM
    #170
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    they were too scared to even look at it lol
  11. Feb 15, 2023 at 4:01 PM
    #171
    LilTexan22
    2017 Tacoma
    True 2 shops i called pretty much refused to work on it after i told them the issues.
  12. Feb 15, 2023 at 4:08 PM
    #172
    LilTexan22
    2017 Tacoma
    This was basically my fix right here. Led me in the right direction
    mtip, TRDSport10, Steves104x4 and 2 others like this.
  13. Feb 15, 2023 at 4:14 PM
    #173
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    Perhaps replacing the part caused the fuse to blow??? Glad it worked out and good thread!
    Chew likes this.
  14. Feb 15, 2023 at 4:23 PM
    #174
    LilTexan22
    2017 Tacoma
    So this is a huge guess but im thinking my aftermarket trailer wiring harness could be the culprit. Few days back when i was researching i read something about people having a p0705 code for tail lights that shorted out or something. After i read that i went and checked all my connections to make sure they were tight and did a much cleaner job because that harness is connected to the tail lights. Im not sure if a wire mustve got loose and shorted something out. I redid everything really well though so if thats what caused it hopefully its fixed for good.
  15. Feb 15, 2023 at 5:23 PM
    #175
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    glad you got it fixed!
    I was going to ask, why did the fuse blow. Regardless, it's still much cheaper and easier to fix a bad connection, than to replace the transmission.
    Junkhead likes this.
  16. Feb 15, 2023 at 5:46 PM
    #176
    Junkhead
    Junkhead TRDude
    Serge
    Prince George, BC
    Black 4x4 Sport MT 2018
    Some Serious Tires
    Fantastic !!!
    StayinStock likes this.
  17. Feb 15, 2023 at 7:44 PM
    #177
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    Much easier. Always room to learn with vehicles that's for sure!
  18. Feb 15, 2023 at 7:54 PM
    #178
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  19. Feb 15, 2023 at 8:22 PM
    #179
    desmodue
    desmodue Unsprung member
    2016 TRD OR AC
    Excellent.
    You do know that the Toyota dealer would have found the blown fuse that caused the issue
    Sometime after they installed the new transmission that miraculously had the same issue.
  20. Feb 16, 2023 at 5:38 AM
    #180
    MGB
    MGB Well-Known Member
    2017 manual TRD Sport
    Somewhat related to the last comment:
    My sister suffered a hydraulic clutch failure in her Subaru (the pedal went to the floor). Dealer replaced the clutch then wrote a note that after the new clutch was installed, the clutch pedal went to the floor, so they very generously replaced the clutch master cylinder for free. Took a few months but she finally got the $2000 clutch cost refunded...
