Metal ball help
Discussion in '2nd Gen. Tacomas (2005-2015)' started by ABN, Apr 29, 2023.
  1. Apr 29, 2023 at 3:22 PM
    ABN
    ABN [OP] New Member
    2006 Tacoma. I was in 4wd and noticed it was hard to turn/grinding a little bit. I was in mud so was unable to stop and then noticed afterwards a new metallic grinding sound, as well as what looked like a couple metal ball bearings on the ground after. Now, even back in 2wd I don’t have the hard turning, but have the metallic sound as I drive. Any help is appreciated.
    wilcam47 likes this.
  2. Apr 29, 2023 at 3:28 PM
    wi_taco
    wi_taco My skid plates give rocks taco flavored kisses
    Adam
    2015 Toyota Sienna with rear locker
    Sounds like a front hub bearing but no way for us to know over the internet. Go wash off all the mud, crawl underneath, and look for things that don't look right.
    sparkystaco likes this.
  3. Apr 29, 2023 at 3:34 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
  4. Apr 29, 2023 at 3:45 PM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Did you look at your CV joint?
    b_r_o and sparkystaco like this.
  5. Apr 29, 2023 at 5:50 PM
    Waasheem
    Waasheem
    2007 xrunner
    Describe your balls in detail.
    Lol, silly Saturday.
    I’d get it up on jack stands. Grab a wheel at 3 and 9 o’clock. Push in at 3, pull out at 9, then reverse to pull at 3 and push at 9. Repeat at 12 and 6. Listen for odd noise, watch for abnormal movement. Spin the wheel listening for odd noises. Repeat at every wheel.
    08TacoTrD, Geeves77 and TnShooter like this.
